Old 02-09-2010, 12:29 PM   #11956
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Ok, try 30 timing boost, 10 turbo with .4 delay to start out.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-09-2010, 12:34 PM   #11957
Technique550's Avatar
Default thanks
right on appreciate the quick response Randy
XRAY☼ Tekin☼ Spektrum☼ PRS☼ Ko Propo☼
Technique550 is offline   Reply With Quote
Old 02-09-2010, 01:50 PM   #11958
sonic31's Avatar
hello, can anyone please help me out ... i bought an rs pro w/ 17.5 combo for my 416x, what i need to know is whats the best spur/pinion combo, fdr and best possible speedo settings for the 17.5? any feedback is greatly appreciated.
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 02-09-2010, 03:29 PM   #11959
bfong13's Avatar
Trader Rating: 17 (100%+)
Contact M-Technic. He has a 17.5 in his Tamiya and it's rediculously fast. Actually, he posted his setup a few back. Just try to find it.
bfong13 is offline   Reply With Quote
Old 02-09-2010, 03:57 PM   #11960
Regional Moderator
Darkseid's Avatar
Alright, looking for a little trouble shooting help here.
Just got a RS and I can't get it to calibrate to my radio properly. Heres what I'm using:
Futaba 4pk
Futaba R604FS
Heres whats happening:
-Turn on radio
-Turn on speedo
-Hold mode button 3sec
-Speedo enters calibration mode
-(#4 LED blinks) I leave throttle at neutral...Neutral calibration sets
-(#7 LED blinks) I pull throttle to max...nothing.....(#7 LED continues blinking)..
Then I realized that it would actually set forward throttle if I pushed rev on the trigger. Basically meaning that pushing forward on the trigger made the car go...not good. So logic said simply go into my radio settings and rev my throttle in my radio and try calibrating the speed control.
Sure enough, this worked.
Question is, will this cause any problems? Tekin made sure to mention several times in the manual to make sure that your radio throttle was set to "normal", then here I am only able to get it to work with the throttle set to "rev".
Just want to be sure this will not cause any issues. Throttle and brake seem to be working normally in the limited space I have to test them. I haven't had a speed control need the throttle in "rev" since my novak rooster way...way back in the day.
TLR 22...Tamiya F104...
Old 02-09-2010, 04:03 PM   #11961
theisgroup's Avatar
ko require that throttle is in reverse as well
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 02-09-2010, 04:09 PM   #11962
Darkseid that should be fine...my Futaba 3PJ had to do that as well.
Old 02-09-2010, 04:18 PM   #11963
TrevCoult's Avatar
As theisgroup and InspGadgt have said, there is no problem with having to set your throttle to reverse to get the RS to calibrate properly. All Futaba radios, and I also think all KO radios (certainly the Universe) need to be set to reverse for the RS to calibrate properly.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 02-09-2010, 04:20 PM   #11964
Regional Moderator
Darkseid's Avatar
Kool, thank you much for the quick responses.
Old 02-09-2010, 05:41 PM   #11965
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Tekin RS Pro Question
Hi all
Well I got my Tekin RS pro yesterday and put it in my sonís car, if it goes like it sounds, man itís no wonder he was getting beaten using his LRP SPX.
I have one question regarding the lipo voltage cut off setting, is it in volts or number of cells, ie: 2 cell Lipo, this was the one thing I forgot to check to see if I set it right, everything else was fine.
He will give it a run tonight and see how it goes
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 02-09-2010, 05:51 PM   #11966
mcdogboy's Avatar
Cells, setting 2 is for 2S lipos.
mcdogboy is offline   Reply With Quote
Old 02-09-2010, 06:26 PM   #11967
Originally Posted by Senna Racing View Post
Ha guys heading to Thailand next week
to race in the titc
We will be running hand out 11.5 speed
passion motors
Any ideas would be aprecated
here's a link
http://www.titc.in.th/
Anyone got a suggested starting point?
I had quite a good setup for a small indoor track, i also used the snowbirds setup apporach and it was slightly slower, but much more driveable.
The SP V3 10.5 motor seems to like max timing on motor, and 50 odd on Timing, with around 10 on turbo for the smaller track.
I would imagine using a normal setup, you could go a lot more Turbo on a big track. Or a snowbirds style by maxxing the Timing boost.
Any ideas apreciated.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-09-2010, 06:55 PM   #11968
wingracer's Avatar
Trader Rating: 24 (100%+)
Both. 2 and 3 are 2s and 3s. If you take the slider all the way up, it gives you an option to type in your own voltage setting.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-09-2010, 07:33 PM   #11969
Still Bill's Avatar
Originally Posted by Tabushi View Post
And here is the video of last 8 minute round, wich gave me the victory :
+ YouTube Video
Hope you enjoy.
Under our racing regulations, race start doing "oval" or at least not entering into the layout until first lap ... crazy uh ? lol !!
Absolutely cool amigo. Great post!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-09-2010, 08:05 PM   #11970
Senna Racing's Avatar
Thanks. Brad
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
