Old 02-08-2010, 08:22 AM   #11911
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by skyshen View Post
what u mean by wrack the car? ... i put the tamiya spec motor but with RSpro esc ... cuz it can run brushed motor on that esc ~ but I'm really want to ask is the hotwire work on my mimi spec motors? or only the brushless?
There isn't much you can change with brushed motors. I don't know what features are available in brushed mode but the only things you might be able to change are things like neutral width, throttle profile, brake strength, drag brake and push control.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-08-2010, 11:31 AM   #11912
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Lost Aggresiva View Post
Check your servo. After loading 203 on mine, I had nothing but trouble. Ended up switching out a JR servo and went with a Futaba. No problems since.
Bill
no the servo is fine because he is using hisspx at the moment and everything else is the same.
2wdrive-all the wires were checked and even re-soldered. we also did a factory reset drove it around and it was fine then tried to re-load v203 and then the same problems occured . it works with all the other versions but for some reason it doesnt like v203?
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 02-08-2010, 11:55 AM   #11913
hey just wondering if anyone knows what cuff's set-up was in 17.5 tc at the birds. thanks.
Old 02-08-2010, 12:21 PM   #11914
Krio's Avatar
Trader Rating: 150 (99%+)
For all those having cogging appear after updating to 203 what motors are you using? I posted on one of these forums about too little motor timing causing cogging. 0 degrees is relative on the many brands out there. 0 degrees on the tekin motors actuallY has the sensors at about 25-30 degrees relative to the center of the coils. Look inside whatever motor you have and try to emulate 0 degrees compared to a tekin motor.
Again, too little motor timing can cause cogging.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-08-2010, 12:54 PM   #11915
how do i post up my set up sheet ??
it is in Adobe but i cant add it as an attachment or picture
sidecarphil1 is offline   Reply With Quote
Old 02-08-2010, 01:27 PM   #11916
I do it by setting it on my web server.
mail it to me I will post it for you.
[email protected]
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-08-2010, 01:51 PM   #11917
[email protected]
done
Old 02-08-2010, 01:54 PM   #11918
done
Here is your setup online.
http://www.mikky32.com/fotomap/Tekin...naarlo%201.pdf
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-08-2010, 01:57 PM   #11919
How did the GM motor go with the Tekin speedo?
I now that the V200 didn't do well with the GM motors.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-08-2010, 02:09 PM   #11920
it goes well
got loads of punch and great speed
i am as fast in a straight line as Dennis Popken and he is using the Mamba Max Pro and an LRP X12 13.5
AND HE IS QUICK !!!!!
but mine is too agressave for me , i tend to HIT the throttle out of the corners and the it just picks the front end up ond pushes me straight on
Dennis can drive it well because he drove Modified for years so he is smoother on the throttle
Old 02-08-2010, 02:19 PM   #11921
Set your Boost down and replace it with Turbo.
As you lower your boost to 45 and set 10 Turbo, You will have a smoother acceleration.
What you also can do is use this setup.
Boost 50
Turbo 10
Turbo delay 0
Turbo ramp 2
Start RPM 5100
End RPM 17000
Throttle 5
Gearing 7FDR (to start with) Watch the motor temp.
As you don't do full throttle, your car drives easier away.
So for the infield this is better to drive.
When you hit the straight. give full throttle and you fly away.
As you want even more acceleration set your Turbo ramp to 3. Hold on this is fast.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-08-2010, 02:33 PM   #11922
2wdrive's Avatar
I drive with a 13.5t duo2 and 2s and before the crash it worked flawless for 3-4 days of testing. After the crash it did screeching and coging. I could reproduce the effect on the bench while holding the throttle a little and was shaking the wires a little, so at this moment it does seem that it is a wire problem somewhere but didn't find out where yet. .
2wdrive is offline   Reply With Quote
Old 02-08-2010, 02:42 PM   #11923
Check also the soldering on the wires.
Some times they come loose.
I think also that it's a wire problem.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-08-2010, 03:09 PM   #11924
mark79's Avatar
I use a SP V3 motor set at 0 degrees timing on the motor in a HB cyclone TC. i have been using the marcell pinkster set up as i race indoors on fairly small tracks.
I reduced my 5200-20000 rev range down to 5200-18000 in an attempt to give more punch out of the turns but i didn't notice much difference.
Should i reduce the timing rev range to 4200-18000 ? I don't think my tracks require turbo boost etc as the straights are short but midfield punch is vital.
Thanks.
p.s my FDR is as 5.4 and my motor temps are 70degree if that makes any difference.
pps. is there a 13.5 TC set up from the recent snowbirds?
AE RC8.2 powered by Picco Boost.
mark79 is offline   Reply With Quote
Old 02-08-2010, 03:24 PM   #11925
Thanks.
Try this setup
I tested it and it field better.
Boost 50
Turbo 15
Turbo delay 0
Turbo ramp 3
Throttle 5
Start RMP 5100
End RPM 17000
7.1 FDR motor timing 5.
You can also try motor timing of 10 but I think 5 is enough.
Watch the temps but the Speedpassion can handle the timing.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
