Tekin RS ESC sensored >
Old 02-05-2010, 03:42 PM
  #11791
Trader Rating: 8 (90%+)
How are the Tekin Redline motors holding up against the others at the moment?
Tha Skinny is offline
Old 02-05-2010, 04:59 PM
  #11792
R/C Tech Elite Member
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Originally Posted by RedBullFiXX
Randy posted this about the time 203 came out.
May help the follks new to RS
I talked to Chris at Tekin today and he explained the ramp rates totally different. That .1 is 10th of a sec, .5 is half a sec, and 1.0 is one sec. That is the elaped time before the full turbo timing setting is maxed out.
JPMSRacing is offline
Old 02-05-2010, 05:07 PM
  #11793
lavaandy's Avatar
Originally Posted by Donny Lia
Here is what I used to TQ 10.5 1/12th at the Birds.
Push control - 20
Neutral Width- 10
Brake strength- 100
Timing Boost- 43
Turbo Boost- 7
Delay - .1
Start/End - 4000-8500
Ramp- 3.0
Trinity duo-1, Mid timing
32/78, 1.68" tire
Tried uploading setup sheet but file too big. Any questions let me know
Will try to get my Mod setup on here soon too.
you missed profile thanks
lavaandy is offline
Old 02-05-2010, 05:26 PM
  #11794
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
ramp 1 will take 1 sec to achieve full turbo
ramp 2 will take 1/2 sec or .5 tenths to achieve full turbo
ramp 3 will take 1 1/2 time faster or .3 tenths (est)to reach full turbo
ramp 1 is 2 deg every tenths
ramp 2 is 4 deg ll ll
ramp 3 is 6 deg ll ll
20 SMOKE is offline
Old 02-05-2010, 05:27 PM
  #11795
20 SMOKE's Avatar
just fine,i wont run anything else
20 SMOKE is offline
Old 02-05-2010, 05:36 PM
  #11796
JPMSRacing's Avatar
Maybe I am missing something, are yal looking at the esc or the time you acually type in on hotwire?
Old 02-05-2010, 05:40 PM
  #11797
20 SMOKE's Avatar
what do you mean by time
20 SMOKE is offline
Old 02-05-2010, 05:48 PM
  #11798
JPMSRacing's Avatar
When in sensored mode, on the bottom right there is a place to type in the time for the turbo ramp. This is also the newest version of software. Chris at Tekin explained it very well, but on the forum I dont really know how to explain because I was looking at it when he was explaining it to me.
Old 02-05-2010, 05:54 PM
  #11799
20 SMOKE's Avatar
i know what you mean its hard to explain something in writing,i don't really know how to answer i think my post explains how the rates work
20 SMOKE is offline
Old 02-05-2010, 05:57 PM
  #11800
JPMSRacing's Avatar
I do have a question why from a stop if you ease into the throttle really slow the motor chatters and makes bad noises before the motor actually takes off. I am sure its a Novak motor sensor problem because I have seen the same thing using the GTB. I just dont know how to correct it. Any ideas out there??
Old 02-05-2010, 06:05 PM
  #11801
20 SMOKE's Avatar
it soulds like a cog,if you roll the drive train and watch 5,6,7 led they should flicker if they dont you have a bad sensor wire or bad sensor on the motor
20 SMOKE is offline
Old 02-05-2010, 06:19 PM
  #11802
Team Tekin
Randy_Pike's Avatar
I believe you misunderstood him. The delay time for turbo is like you've got it written.
However ramp rate is the rate at which the turbo timing is applied:
ramp 3 will take 1 1/2 time faster or .3 tenths to reach full turbo
20 Smoke had it right!
Randy_Pike is offline
Old 02-05-2010, 06:20 PM
  #11803
Team Tekin
Randy_Pike's Avatar
This could also mean your start and end rpm aren't set properly.
What motor in what car?
Old 02-05-2010, 08:23 PM
  #11804
avs
avs's Avatar
just after intalling v203, i had a motor that would 'chatter' under certain conditions and then be fine. it turned out to be the solder connection between the stator coil and power bars. when i removed the cover on the sensor side i touched the bar and it felt 'loose'.
apparently after several collisions the solder joint had been weakened? a local motor guru offered to resolder it for me with high temp solder. i had already redone it with whatever i had laying about, but will definitely take him up on the offer if the problem reoccurs.
Last edited by Kraig; 02-05-2010 at 09:07 PM. Reason: fixed so Randy doesn't get a headache. :)
avs is offline
Old 02-05-2010, 09:02 PM
  #11805
Team Tekin
Randy_Pike's Avatar
Please don't post that you have V204, that's not possible since it doesn't exsist...
You will start utter Chaos! LOL
