Tekin RS ESC sensored
#1156
The 19T equivalent is a 10.5 motor
Unfortunately i havent got one but apparently the tekin redlines are pretty good, otherwise when looking around for a motor aim to get one with adjustable timing (these days most are adjustable though) as this will give you more tuning options when you are playing with your RS
#1157
hey guys i was just wondering what kind of finnal gearing i should be having? right now im at 4.4 on a smaller sized track and cant get any speed? any ideas?
#1158
Ok what motor and what is it in?
#1159
you probably need to know that right lol its a sensored red line 13.5 also mine is reading the esc as an R1 insted of an rs i have tried to re install it and got no where
#1160
Uninstall your hotwire software though Control Panel in your puter. Restart your puter and download the latest version off of our site.
You should be good after that.
#1161
I have a quick question for Tekin.
I will hopefully be trying the single cell lipo trick in my 12th scale. I will be running a small lipo receiver pack to support electronic duties.
If I run the receiver pack, will I have to disconnect the BEC? I assume you remove the red wire from the speedo receiver lead. Or will the receiver be OK with voltage coming in from both terminals?
Thanks guys.
Thanks guys.
#1162
For the reasson my budget for now is for Tekin RS ESC only (i invest good esc first worry the motor later) so i need to settle first for a cheap sensored brushless motor.
Can i buy Less than 10.5 turn sensored brushless motor (let us say 17.5) then program it, to run as 10.5 turn only. (sorry cant explain clearly due to my poor knowledge in RC and grammar ) Hoping you know what my question are?
#1163
The 17.5 is slower than the 10.5 so it is not really possible to get it as fast as the 10.5.
But even if you got a 10.5 getting it to run like a 17.5 would take a lot of trouble with experimenting trying to get it similar and if you are club/competition racing i would be surprised if they allowed it.
#1164
#1165
for money reason, Im sure with my driving skill now I can not handle lower than 10.5. But sooner or later I will be used to it, and I will crave for more punch and speed.
What im asking is using Tekin RS ESC can i program it to slow down my motor?
By the way Im not a racer, just a happy basher
#1166
With hotwire you could turn down the timing to reduce punch and change the EPAs on the transmitter throtle. But getting the same response (if possible) would take a LOT of time.
You would need to check with your club in the first place to see if they would allow it though.
As long as you drive smart you can handle any motor! But ive seen a lot of drivers driving mod for the first time pretend to drive them who just end up smashing their cars.
#1167
Thanks guys.
Thanks guys.
Just plug the rs into the receiver like normal.
Run a switch on your receiver pack, when you turn that switch on it will turn everything else on, don't turn the the Rs switch.
If you need any help hit me up.
later
Dayton
#1168
Just ran my RS Pro for the first time today, and with the SP 9.5T its really fast. I started with Sensored only mode and geared it, then turned to Dual Mode with 50% timing, and it just ran SO fast and it wasnt even warm the ESC was half full in temp. and the motor i was able to touch right after the run...
But really need to get familiar with BL as it requires other driving style compared to brushed. But the power low end was just incredible and turning up the timing only made the top end better...
Now i am excited about the races i am going to run!
#1169
Thanks Dayton.
What about the 7.4 volts on the electronics? What do you guys do in nitro racing if your running lipo receiver packs? I'm not sure how the big burly servo you use in truggy compare to the dinky 12th scale servos. Are they made to run @ 7.4 volts or do you step it down with something?
#1170
Thanks Dayton.
Some of the servos can handle it, I'm not sure about the mini servos though.
I would run a voltage regulator.
Novak, losi, Much more and a few other companies make them.
later
Dayton
