Old 02-02-2010, 02:43 PM   #11656
Begin with a basic setup. See what the motor temp does and what the speed is and acceleration. Keep the Turbo on 0.
Than look to the acceleration of the car. Id that is right the gearing is good. Look ad the moment of the Boost is coming in ad the right time. Not to fast and not to late. If so look ad the total acceleration. If that is to low narrow the RPM range or start adding some Boost.
As you than come top speed to short, first ad some motor timing and if that's not enough you can use the Turbo.
Start with a high Turbo delay and not to much Turbo. Turbo ramp on 2
If it's enough speed that the car keeps accelerating, than look ad the moment that the Turbo comes in.
Lower it till you get a smooth acceleration till it's top speed.
Than you can set the Turbo ramp to 3 if you want.
You don't need max Turbo on smaller tracks. 5 to 10 is enough on most tracks and the smaller even 0.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-02-2010, 02:59 PM   #11657
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by M-Technic View Post
This thread is an (overwhelmingly) awesome source of knowledge and information. Before I continue with any more questions I'd like to thank everyone for sharing their knowledge and debating in a mature matter. I'd especially like to thank those who have PM'd me to share their setups and bounce theory back and forth!
Alright, so on to my next theory. From what I have seen, besides a few "different" setups such as Schreff's Snowbirds setup, it seems like there is a general consensus on a lot of the main aspects of the setup. So my question now is:
When I put my car on the track and I know the setup on the speedo is close, but not perfect, do I keep going back to the ESC settings on the Hotwire and continually tweak that? Or is there a point where the ESC is close and I should start experimenting with gearing again?
With the SPX the process was pretty much: set to profile 8, maybe adjust the timing on the motor a little, and it was mostly gearing for temps. Now there are so many more variables that I'm not sure where the starting points are anymore.
T.J.:
I try to make things as simple as possible anymore as I'm like everybody else here. All these wonderful settings we have to play with get a little overwhelming. The setup I used at Birds is what we've (Larry, Hanulec, and myself) been using for the past 4-5 weeks at our home track (Horsham R/C) without changing a thing. We've really only played with car setup and gearing. It felt fast, but our home track is all Tekins. No LRP or Black Diamond to really compare to. When we went to Snowbirds and saw we were really fast, I guess we hit on something. That just means we can really focus more on gearing and car setup. The same happened with 2.00 and 1.99. We found something we really liked and just left it be. I think 2.03 can be much the same. Find something you like and stick to it.
Also, just an FYI... The setup Randy posted that I provided for 13.5 is GREAT for Duo1 at middle hole, Duo2 at 1 mark from full timing, and Speed Passion type motors. It WILL cook LRP motors in like 5-10 laps.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-02-2010, 03:05 PM   #11658
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
The setup Larry put on my RS at the Birds is nasty, too nasty for me a few hours before the mains with a few minutes track time (my fault). I can see it tearing up my home track though. Gotta get the hotwire this week after I recover. I have no doubt that I will be happy now that I finally got one and may or may not vary much from what Larry put on there.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 02-02-2010, 03:05 PM   #11659
Originally Posted by schreff View Post
T.J.:
Ok so I can use this setup for the Speedpassion V3 also?
Do you have a good setup for a 10,5T LRP X11?
With this setup, do you have more acceleration power because of the Turbo delay on 0 and that you use the Turbo to accelerate the first meters?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-02-2010, 03:08 PM   #11660
wingracer's Avatar
Trader Rating: 24 (100%+)
Has anyone tried this zero delay set-up in 1/12th yet? If not, any idea where to start with it for 10.5 1/12th? I might want to play around with it at the next race. Could be fun
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-02-2010, 03:24 PM   #11661
Chris Adams's Avatar
Man, def. kicking myself in the a$$ now. I kept telling my roomates at snowbirds how I thought that a zero delay would work... never had the balls to try it. Oh well... I guess .1 was still pretty fast haha.
Im extremely happy with my tekin and dont see a change anytime soon.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 02-02-2010, 03:32 PM   #11662
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
There is a saying,you never know unless you try
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-02-2010, 03:34 PM   #11663
What was your setup?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-02-2010, 03:44 PM   #11664
schreff's Avatar
Yes, the setup will work with a Speed Passion 3.0. I don't know what timing you'd want on that motor though. I know Larry tried a 3.0 and didn't like it much as the Duo was still quicker. Then again, it just might have been motor timing/gearing that wasn't right, but we had limited time to work on stuff. I don't have any info on the X11 motors as I've never had one nor has anyone in our crew.
Acceleration is pretty strong on the 0 delay. I wouldn't say it's crazy as you won't notice a huge difference with it at 0. It felt almost as if the timing boost was working hard first, then turbo took over from there. You just have to try it to feel it. Some might like it, some might not.
I ran older model Speed Passion 10.5 (black can) with a mod rotor in it for Modified. It was crazy fast cuz you could use all the timing and turbo available. I also ran a Duo2 10.5 at 1 notch from full timing and ran the following setup...
22500 end rpm
5300 start rpm
Throttle Profile 5
Brake Power 80
Drag Brake 40
Neutral Width 10
No Current Limiter
3.0 Ramp
0 turbo delay
55 timing boost
10 turbo
BL Forward Only
8.0 final drive
The higher timing boost let the motor hit harder off corners, but it did get the motor up to about 170 degrees. I wasn't much worried about temp, I just wanted it to accel hard as it had to keep up with 4.0 motors... and it did.
As for 12th scale 10.5... here's what I remember... (Fairtrace has all my racing stuff so I can't exactly hook it up to check. )
8500 end rpm
1500 start rpm
2.0 ramp
0.2 turbo delay
45 timing boost
20 turbo boost
Throttle Profile 3
80 Brake power
0 drag brake
10 neutral width
no current limit or lipo cutoff
1 cell mode checked
Gearing was 80/35 with 1.68" tires
Duo2 10.5 at 1 notch up from 0 timing
This setup was stupid fast in 12th, but you had to be smooth on the throttle. If you pushed too hard, you would get the motor up over 200 degrees and I even dumped one round. That's right, dumped a 5000mah pack with a 10.5. LOL. It could've used lower gearing, like 80/33, which would've helped off the corner at no sacrifice to top speed. I'm sure Donny had a different setup than me as we really didn't talk much about it. He was running a different motor timing setup and gearing too, so I'm not sure what he had in the speedo.
Hope some of this info helps.
-Jason Schreffler-
Old 02-02-2010, 03:56 PM   #11665
22500 end rpm
5300 start rpm
Throttle Profile 5
Brake Power 80
Drag Brake 40
Neutral Width 10
No Current Limiter
3.0 Ramp
0 turbo delay
55 timing boost
10 turbo
BL Forward Only
8.0 final drive
8500 end rpm
1500 start rpm
2.0 ramp
0.2 turbo delay
45 timing boost
20 turbo boost
Throttle Profile 3
80 Brake power
0 drag brake
10 neutral width
1 cell mode checked
Thanks,
The LRP X11 is between the speedpassion and the Tekin by gearing. It can handle a lot of head and runs better as it gets around 200F
I want to keep it under the 180F but I will try your 0 Turbo delay setup on it.
I have only 2 races to go with this motor and than I can dump it. I think that I don't even race 2 races any more with it and that I will run the Speedpassion V3 13,5T in the 10,5T class.
I can't train for Sunday so I will try it just before the race and by the qualifications.
I think as I don't feel that it works in the first few try's that I go back to my own setup to reach the A final. I want all races this year to race in the A final.
I have now 3 races raced and all 3 in the A final so I have only 2 to go.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 02-02-2010, 04:00 PM   #11666
Ya, only had one motor for the week. Wasn't gonna burn it up trying something that no one had said anything about prior to Birds.
18 dbreak
5 tprofile
50 timing
10 turbo
.1 delay
10 neutral width
8500
5000 starting
100 brake
6.08 fdr
Texas EOS 2018!
Old 02-02-2010, 04:36 PM   #11667
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Duo's and the black can SpeedPassions share guts (same part numbers on the sensor sensor boards and rotors and the stators look identical). A Duo 1 in the lowest timing hole is identical to a black can SpeedPassion. I haven't thoroughly investigated the 3.0s, like I have the black can versions, but after tearing a couple down they look to be the same internally also. The only differences I have found between the two are the outer cases. Its just a matter of finding equivalent motor timing positions IMHO.
Old 02-02-2010, 05:02 PM   #11668
I am no pro and don't have as many hours into the Sentry software as Yang, but I thought I would throw up some data I down loaded from my 13.5 XXX-CR and my 13.5 Mi3 that I ran in practice last Saturday.
I'm just an average driver so don't look too carefully at these
1. 13.5 Rubber Tire Sedan-1 Lap
2. 13.5 2wd Buggy-1 Lap
Look for the flat part of the throttle curve to identify the straight. RPMs ran as high as 34,600 in Sedan and 32,000 in Buggy. Both tracks have a roughly 100' straight.
Tekin RS ESC sensored-ss02022010175443.jpg   Tekin RS ESC sensored-ss02022010175947.jpg
Old 02-02-2010, 05:10 PM   #11669
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
interestin stuff
R
UltegraSTI is offline   Reply With Quote
Old 02-02-2010, 05:13 PM   #11670
KHoff7's Avatar
It sure was Tekin city this week at the Snowbirds.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
