Old 02-01-2010, 01:08 PM   #11566
cwoods34's Avatar
Ran 17.5 rubber TC yesterday, Duo 2 with 0* on the motor.
Drag Brake: 25
Brake Strength: 100
Throttle Profile: 4
Timing Boost: 50
Turbo Boost: 10
Turbo Delay: .4
Turbo Ramp: 3
Start RPM: ~1500
End RPM: ~6750
Don't know exact track dimensions, but it's a big carpet track (R/CAR, Marion County Fairgrounds in Indy).
FDR was right around 5.8 or 5.9 (can't remember exact number) and the motor came off after 6 minutes around 130*F. I should've went to about a 6.0-6.1 FDR but the car was fast, no one was catching me on the straight (except my friend's 13.5) and I had plenty of rip through the infield. Thanks Tekin
Now I just need to work on my chassis setup!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-01-2010, 01:14 PM   #11567
matt d's Avatar
im sure this was discused before but here is the problem i am having. i bought a losi regulator and a thunderpower 2s 350mah lipo. v203 with a novak 13.5ss. i can pull the trigger and throttal works fine. then i pull triger and turn sterring and get all sorts of gogging and stuttering. the 1s box is checked and when i went back to a 2s setting and put my 2s back in the car without reciever pack it works fine. so im kinda lost here. any help would be appreciated. i will try to answer any other information you might need. thank you again
Sauce it up my Friends
TLR - Team Spektrum - Horizon Hobbies - Team Orion - MIP - Team Gravity RC - Motive RC - F3A Unlimited - Gator RC - Trackside Hobbies&Raceway - HobbyTown USA Lake In THe Hills & TimeWarp Raceway - Windy City RC
matt d is offline   Reply With Quote
Old 02-01-2010, 01:41 PM   #11568
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks for the setup. I will be running the same motor setup, but on a fairly open asphalt track. I will use your settings as a starting point. Not knowing your track size, any recommendations on things you'd change if you were running on a track with an assumed ~20ft longer straight, and probably a bit less technical? Perhaps one tick of timing on the motor?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-01-2010, 01:58 PM   #11569
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Ditch the regulator! WE can take the 2s lipo rx pack just fine. It's you servo that may need the help.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-01-2010, 02:18 PM   #11570
matt d's Avatar
Thanks Randy. I just want to get this straight so I dont blow anything up. Take the 2s receiver pack ( 7.4 volts) and plug it in right into the receiver? My servo is a futaba 9551 brand new never been used, Futaba 4pk with a 603 receiver. What about a switch for the receiver pack.
Old 02-01-2010, 02:21 PM   #11571
matt d's Avatar
reading my post from earlier , I faild to mention that this is for a wgt car wtih a single cell pack. Thats why I have the receiver pack and the regulator
Old 02-01-2010, 02:27 PM   #11572
theisgroup's Avatar
btw, futaba says no to 2cell lipo rx packs for their rx and servo
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 02-01-2010, 02:42 PM   #11573
oeoeo327's Avatar
Trader Rating: 74 (100%+)
+1 - Futaba doesn't advise applying over 6V to the receiver and servos. Maybe the regulator is the source of the problem. Try attaching the regulator to the receiver pack, and get a voltage reading from the regulator's output plug. If the voltage is greater than 6 volts, that could be the source of the problem.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 02-01-2010, 03:17 PM   #11574
pakk's Avatar
Trader Rating: 79 (100%+)
I put 8.4v to my futaba servo (s9650) with no issues.
Again, futaba does say not to exceed 6v. So if your servo blows up, don't blame me.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 02-01-2010, 03:35 PM   #11575
Just need a confirmation-
The only difference between the RS and RS Pro is the internal resistance and the lower motor limit on the Pro, correct? I'm about to order a new speed controller, and around here we never run below a 10.5, so if I can save $50 or so, I wanted to go with the standard RS. I still wanted all of the tuning features offered by the new Vegas software, though. The dynamic timing/boost are added to the regular RS as well once updated with the hotwire, correct?
Serzoni is offline   Reply With Quote
Old 02-01-2010, 03:42 PM   #11576
oeoeo327's Avatar
You are correct. The RS has all of the functionality of the RS Pro, including the dynamic timing capabilities. The only differences are the # of FETs, size and weight, and the motor limit for the RS (5.5 turn)...
Old 02-01-2010, 03:57 PM   #11577
Yes.
As you don't go lower than 10,5T the RS is your choice.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-01-2010, 04:33 PM   #11578
LBSR415's Avatar
Originally Posted by DaredevilD View Post
get a short servo extension and unplug it from that instead of the receiver.
ahh did not think of that,,thanks
Team OHP
Razor Graphix
East Coast R/C
Pantheon Motorsports
These fish,,,are frozen.
LBSR415 is offline   Reply With Quote
Old 02-01-2010, 04:42 PM   #11579
Thanks fellas. RS and Hotwire ordered.
Old 02-01-2010, 04:58 PM   #11580
Yang you have a PM
Jeremy Otis is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
