Tekin RS ESC sensored
#1141
K Feath,
I would try turning timing to 0 on motor. Then try these settings with hotwire. If it does same thing try clicking sensored only box try again not changing settings. If you still have any issue lmk
drag = 25
rev = 0
brake = 75
neutral = 10
blfw
throt = 5
volt = 0
push = 0
timing = 100
current = off
drag = 25
rev = 0
brake = 75
neutral = 10
blfw
throt = 5
volt = 0
push = 0
timing = 100
current = off
#1143
Are you using Hotwire? Check white box on right hand side seen here in this screen shot from mo's 4wd setup.
#1145
push
what exactly is the push control doin? doesnt drag brake sort of act as a push control?
#1146
Without either, the motor would just coast without slowing the motor. One thing that brushless doesn't need is push control, since most brushless motors have almost zero drag brake naturally. Push control is generally used on brushed motors, drag brake on brushless.
#1147
Hi All
Do you guys ever try the R1 pro the senserless one?
Does it works better than other senserless ESC?
Thanks for any advise!!!
#1148
Hi Randy,
Any updates on the software?
Hey Stocker,
I spoke to our engineer about this. The version of Hotwire software you have goes about checking for internet differently then the update that's coming out.
Currently the hotwire will look for you network card, internet, then ping our site. The update now just pings the site to verify internet.
Make sure that once you plug in the Hotwire(no speedo) go ahead and click on "check for updates."
Make sure you're running the latest software. The current one can find conflicts in certain network settings and come to the conclusion that there's no interent.
I'll post something when the new Hotwire software is out.
#1149
#1150
#1151
The R1 is a great sensorless esc. You really can't beat it's size, user interface(right on the unit with full led sequence) as well as it's ability to be updated with any new release software. Running any of the Redline sensorless motors is a very potent combination.
We're working on the Hotwire software update as we speak. We insist on it being rigth so bear with us.
#1152
As mentioned the R1 is good with sensorless motors.
It will also run sensored motors but there are some issues when you start to use sensored motors which are not of the mod variety. IE anything with a 10.5 or more winds starts to have weird stuff happening.
There is also a minor launch delay when using mod sensored motors.
One thing to however watch out for is that unfortunately the Tekin Sensorless motors are not Roar legal (i think also not legal in most of Europe, i dont think it was EFRA legal).
The Redline Sensored motors are however roar legal
#1153
We're still working on Vista 64 bit. It's different enough to cause problems. We also want to test it over and over again and check for bugs.
The Hotwire is due for another update soon. Some new features will be added.
(I'm sorry you had to use your very first post to take a shot at us)
Bummer....
Bummer....
Keep working at it.
#1155
hi guys, im planning to buy Tekin RS ESC,
what brushless motor do you think is compatible to it ? im looking for 19t brush motor equivalent. thanks
