Old 01-30-2010, 03:54 PM   #11461
mark79's Avatar
This question may have an obvious answer so bear with me
I downloaded the Marcell Pinkster 13.5 V3 set up for my esc to run at my local club.
It says 'timing advance 100' on the set-up sheet but i can't find 'timing advance' to set on the hotwire programme. Its the latest version and i can access the advanced features without any probs.
Am i missing something here?
AE RC8.2 powered by Picco Boost.
mark79 is offline   Reply With Quote
Old 01-30-2010, 04:01 PM   #11462
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Uncheck the "sensored" box, should reveal "timing advance" in the dual mode settings, then recheck sensored and set as normal.
Pushing the timing advance up should allow the motor to maintain some speed if a sensor wire becomes unplugged or damaged, in which case the ESC reverts to dual mode. Won't be as fast as sensored, but should minimize the damage from a rear-end collision
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-30-2010, 04:08 PM   #11463
Yes you can Finnish your race. Don't expect a that your car will still fly.
It helped me to finish my race one time and because it was in one of the last laps it didn't cost me a lot of time.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-30-2010, 04:09 PM   #11464
mark79's Avatar
Aaaaaaah! Thanks
Old 01-30-2010, 04:16 PM   #11465
Aaaaaaah! Thanks
The A main driver ad the ETS is going fast.
His setup must be very good with the Speedpassion motor.
I hope he will post it.
I try to get it from some drivers at the ETS. They must drive there with the Speedpassion V3.
You can also try these 2 setups.
This Eric his setup
Boost 55
Turbo 10
Turbo delay 0,3sec
Turbo Ramp 2
Start RPM 3000
End RPM 18000
Gearing 7,2FDR
timing on the motor 5
or this one
Boost 50
Turbo 10
Turbo delay 0,2
Turbo ramp 3
Start RPM 2700
End RPM 9000
Gearing 7,0
Motor timing 5
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-30-2010, 06:36 PM   #11466
morris's Avatar
Trader Rating: 40 (100%+)
my settings for 13.5 on foam tire...this seems to be really fast w/no fade.
fdr..6.75
timing boost..50
turbo boost..10
throttle profile..5
delay..0.2
nuetral width at 25
24xx start
10000 end
set your drag break as desired
set you break strengh as desired
motor temps at 150 and only i flash on rs pro....
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-30-2010, 06:39 PM   #11467
fdr..6.75
timing boost..50
turbo boost..10
throttle profile..5
delay..0.2
nuetral width at 25
24xx start
10000 end
With witch 13,5T motor? speedpassion?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-30-2010, 07:00 PM   #11468
morris's Avatar
oh sorry...forgot to add that.
im using the orion vortex 13.5
Old 01-30-2010, 10:36 PM   #11469
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Guys...what does the dual mode mean?....
KELVIN KHNG is offline   Reply With Quote
Old 01-30-2010, 10:39 PM   #11470
wingracer's Avatar
Trader Rating: 24 (100%+)
Dual mode uses the sensor to get the motor started but then switches to sensorless mode. Most racers don't use it anymore, except maybe for some mod apps.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-30-2010, 10:45 PM   #11471
So i guess when the esc is on factory mode...without the hotwire..i am assuming that it is on dual mode right?
Old 01-31-2010, 01:38 AM   #11472
This Eric his setup
Boost 55
Turbo 10
Turbo delay 0,3sec
Turbo Ramp 2
Start RPM 3000
End RPM 18000
Gearing 7,2FDR
or this one
Boost 50
Turbo 10
Turbo delay 0,2
Turbo ramp 3
Start RPM 2700
End RPM 9000
Gearing 7,0
Motor timing 5
What motor are you using with these settings and above gearing?
008-Racer is offline   Reply With Quote
Old 01-31-2010, 03:14 AM   #11473
Went for a test yesterday at my local club using V203. The track is carpet and is 36metres x 12 metres. I was using a T2 009, Redline 10.5 and Sorex 28's with 5000 40c lipo's.
Here are my settings:
Drag Brake = 0
Reverse Strenght = 0
Brake Strenght = 100
Neutral Width = 10
Motor Type = BL/FW
Trottle Profile = 3
Voltage cut off = 7V
Push Control = 0
Dual Mode = No
Sensored = Yes
Timing Boost = 55
Start RPM = 2000
End RPM = 6000
Turbo = 0
Delay = N/A
Ramp = N/A
Motor Timing = 0
FDR = 6.09
After a 5min run at race pace, the esc was only flashing 2 lights and the motor came off at 36 degrees (97 F).
RSCosworth is offline   Reply With Quote
Old 01-31-2010, 04:38 AM   #11474
kamen's Avatar
hi.... can anyone help me with fdr and esc setting..?
im using rs pro with hotwire and team power 11.5 motors..
our track is about 100-140 feet long(speed zone) with some tight corners..
and its about 35 celcius at 5pm (malaysia)... please advice..
aku main keta pekak ja.... (-_-)
kamen is offline   Reply With Quote
Old 01-31-2010, 05:15 AM   #11475
Julius's Avatar
Default Snowbirds 10.5 1/12 setup
@Randy,
Pleasy be so kind to post a 1/12th 10.5 setup from your Snowbirds drivers when you get back.
Would really like to get a ballpark setup as most that are posted are 13.5 TC and 17.5 setups
Julius
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
