Old 01-26-2010, 02:55 PM   #11251
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by rc-racer-kirby View Post
Hey Guys
Im trying to decide between the Tekin RS Pro, LRP Stock Spec and Speed Passion GT2.0. I run in pro stock ( 10.5 lipo ) and sometimes mod ( 6.5 lipo ) Although i have never seen anyone running tekin here in ireland i have heard nothing about good reviews in other countries. Is there still the same issue with bringing a laptop to the track to change the updates? It is the disadvantage i find with the Speed Passion and the advantage of the lrp is this dosent have to be done. When i get to a new track i have enough to fiddle with without having to bring the laptop out to install updates. I am currently running a Novak GTB so any of these ESC's will be quicker for me but i want easy enough to use but i do want ajustability. It will be run in a Schumacher Mi4 with a Speed Passion V3 10.5 motor.
Honestly with motors that fast you could put in a conservative software setup and just adjust your gearing for each track. Its not like if you have the settings off a little bit the car is garbage, most of us are running high wind motors where every little bit counts. I've driven a 8.5 car with the tekin and it was retarded fast, I don't think I even got the boost to kick in.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-26-2010, 03:15 PM   #11252
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by jeppesen View Post
I think i will go back to my starting setup, and then go to 0 timing on the motor, that should also cool it down, the feeling whas better before.
Just to be clear, the timing boost is how much timing in total + turbo?
And the ramp, is how much it increases the timing over rpm??
Or please explain it to me
motor timming and timing boost are added through the rpm range that you set with the start/end rpm,turbo is added on top of both after a set delay and come's in as a ramp rate of 1/2/3 that you set
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-26-2010, 03:43 PM   #11253
I'm confused, I keep hearing people say a narrow RPM band gives more torque/punch.
I equate timing steps to changing gears in a car. You will increase the time to shift from 1st to 5th to gain acceleration. So a narrow RPM range would decrease your torque/acceleration wouldn't it?
malkiy is offline   Reply With Quote
Old 01-26-2010, 03:51 PM   #11254
A narrow RPM range gives you a more aggressive feel but less torque.
Because of the lower torque, you should gear lighter.
With a wider RPM range you can gear heavier.
A wider RPM range makes the car less aggressive.
For larger tracks I would go for a wider RPM range.
For smaller tracks the narrow RPM range.
Set your Throttle on 3 and try some RPM ranges till you have something you like.
This way you change your throttle without changing the throttle settings.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-26-2010, 04:03 PM   #11255
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by k_bojar View Post
do you still have the downloaded file on your PC?? If so, copy it to a pendrive or something to put onto your laptop
I used the same file on my laptop and netbook
i did the hidden file deal to remove, just whatever i do i cannot get 203 on this labtop??? do u guys have that link so i can send randy the email to have 203 sent back? thanks
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-26-2010, 04:12 PM   #11256
Originally Posted by razzor View Post
Forgot to mention in my earlier post the only hassle i had with 203 is that i needed to fit a cap to my Spektrum reciever.
When i throttled out of teh slowest corner i got radio glitches and thought it was my radio seeing the aerial had broken on the Module.
Aftre the 2nd heat i fitted a cap and viola all glitches stopped.
I has a similar problem with my TC. Not too sure whether is was cogging, too much timing or even a problem with the sensor wire, but the car hesitated twice and made strange noise (as if the spur broke). I'm banking on the fact that I need a cap on my spektrum receiver. do you think it is due to the fact that the voltage dropped too far, below a certain cut-off within the receiver?
Thx
mhavlena is offline   Reply With Quote
Old 01-26-2010, 04:14 PM   #11257
anybody racing with a fan on their motors? Is this a worthwhile investment?
I would assume that one run a more aggressive setup since one could save approx 30 deg on their motor with a fan..opinions?
Old 01-26-2010, 04:28 PM   #11258
20 SMOKE's Avatar
check and make sure you have a zip program with out it it wont work
Jamie W
Old 01-26-2010, 07:00 PM   #11259
Trader Rating: 114 (100%+)
Just wanted to share my 5th Tekin RS installation with everyone... also my new ride for TCS.
Can't wait!
Chris Furman is offline   Reply With Quote
Old 01-26-2010, 07:23 PM   #11260
ShaunMac's Avatar
Can't wait!
If you find yourself still hunting for a few tenths. Even after your RS is all maxed out. You might try cutting a foot or two off those front body posts. Thats got to be good for at least a tenth per post!!!
Nice ride Chris.
ShaunMac is offline   Reply With Quote
Old 01-26-2010, 07:52 PM   #11261
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
A buddy of mine needs some help. We're at West Coast RC Raceway in SoCal on a track that i guesstimate is about 100'x60' and fairly technical. He says his car feels like the turbo kicks in too late (delay is at 0.3, ramp at 1) and that the car overall feels soft (it looks okay in the infield though). This is with a nemesis 17.5. Any tips or can someone share a setup to put on this tekin? Thanks.
Syber Serulean is offline   Reply With Quote
Old 01-26-2010, 07:53 PM   #11262
bukil's Avatar
Trader Rating: 39 (100%+)
Randy posted Barry Baker's Tekin setup a few pages back. Try that.
bukil is offline   Reply With Quote
Old 01-26-2010, 07:59 PM   #11263
hes running FDR at 5.7 and running a 17.5. Im not sure if Barry's tekin setup would apply for a 17.5 or would it?
Old 01-26-2010, 08:05 PM   #11264
20 SMOKE's Avatar
drop a few more teeth,i am at 6 with a redline and the track is bigger,don't be afraid to gear down more start with around a 2-3 start rpm and a 10-12k end delay .4 ramp 2 timing boost 45-50 motor 0-5 turbo 5
Jamie W
Old 01-26-2010, 08:27 PM   #11265
big al's Avatar
Can't wait!
Hate to be that guy, but I believe your dremeled chassis is illegal. I miss TCS!
big al is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
