Old 01-26-2010, 01:23 PM   #11236
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by twelvegauge View Post
reinstalling the new version seemed to help. Also I recalibrated the esc again.
Glad to hear it.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-26-2010, 01:26 PM   #11237
jeppesen's Avatar
Originally Posted by wingracer View Post
Longer turbo delay with ramp 1 or 2. Less total timing, higher rpm points.
What will be the difference in driving/power performance when changing the ramp?
And will lowering the the timing boost give less total timing?
Thanks again
Large scale racing with RS5 Touring car, Sanwa, Sav÷x, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Old 01-26-2010, 01:40 PM   #11238
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by jeppesen View Post
Hi Guys
Need a quick help, is at the track right now, running with a rs pro and 17.5 redline motor, is very impressed with the power, but i am running a little hot a the end of a 5 min run, running 1/10 touring.
My settings are.
Boost 50
Turbo 10
Delay .2
Ramp 3
Start 2550
End 8000
FDR 6.6
The speed and punch is good, but what could i change to run it a little cooler?
your settings are pretty close to mine. Try raising your delay to .4 seconds and going up a few teeth on your gearing. I'm running a 5.8 FDR on a 96x40 carpet track with rubber tires. Motor temp usually around 145 with a Duo2 17.5 motor with 0 motor timing.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-26-2010, 01:42 PM   #11239
theisgroup's Avatar
Originally Posted by VRacing View Post
Hey guys, speaking of sandwich?? Did you notice StewartFan20 right in the middle of your posts? Even asked a question that went right with Yang's offer to make changes to match the track. Spreading the PB&J a little thick on the edges and forgot all about the middle?
not exaclty the same. I am offering to help with changes from a person that has run the setup. he can tell me if the car is slow out of a corner or if the car is too punchy or the car does not accelerate down the straight. I am making changes base on feed back of an existing setup.
I find it hard for people to be able to give any setup advise just with dimensions of a track. now if he would have run my setup and told me what he felt the car lacked, then I might be able to suggest some changes to the setup
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-26-2010, 01:43 PM   #11240
theisgroup's Avatar
Originally Posted by RedBullFiXX View Post
Really it's already so good I don't know what more I could want for.
Perhaps you could train it to make me a sandwich in the middle of the day
pretty easy, you need to run at Mike's. Mr Dumas's wife runs the deli at the track and well, I get lunch delivered to my pits by a national champ. lol
yang lai
Old 01-26-2010, 01:49 PM   #11241
wingracer's Avatar
Trader Rating: 24 (100%+)
Nice, but I would rather be delivered a national championship.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-26-2010, 01:51 PM   #11242
jeppesen's Avatar
Changed to this setup
Boost 50
Turbo 10
Delay .3
Ramp 2
Start 2800
End 11000
FDR 6.6
The power whas okay, but it felt like there whas a little less punch.
Raced for about 7 min and the temp was around 200! , i now it is way high, but for a 5 min race it should be ok.
How much timing is the redline motor set at from the start?? (17.5)
Old 01-26-2010, 01:59 PM   #11243
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Quick Q. i have the 203 on my main pc, but not on my labtop, that i plan on bringing to track, i have only the vegas software on it, and it shows that im running 203, but i cannot make any adjustments under that paramiter,how can i get the 203 sent to me again?, so i can save on my labtop, when i registered off the site, it keeps sending the vegas, says 4.0 tho? Thanks
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-26-2010, 02:03 PM   #11244
theisgroup's Avatar
i am telling you the food in the deli is much better then dumas. so I would choose the food. lol
yang lai
Old 01-26-2010, 02:07 PM   #11245
MikeXray's Avatar
Trader Rating: 73 (100%+)
clear out your temp internet files, or open the link in a different browser. Or just copy the exe to a usb stick and copy it to the laptop.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-26-2010, 02:07 PM   #11246
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
do you still have the downloaded file on your PC?? If so, copy it to a pendrive or something to put onto your laptop
I used the same file on my laptop and netbook
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-26-2010, 02:11 PM   #11247
stiltskin's Avatar
Boost 50
Turbo 10
Delay .3
Ramp 2
Start 2800
End 11000
FDR 6.6
I've got my start RPM at 2400 and end RPM at 7000. The lower gap in the RPM range provides more punch. The Redline motor comes from the factory set at 12 degrees. Rotate it to 0 and gear up a few teeth on the pinion. I tried gearing down for more torque and got to a point where it didn't give any more power and just created more heat. If you're worried about gearing up while you're already running hot, try running it for a few laps and temp the motor. Then temp it every minute until you feel comfortable running longer.
Tony Rumple
Old 01-26-2010, 02:40 PM   #11248
jeppesen's Avatar
I think i will go back to my starting setup, and then go to 0 timing on the motor, that should also cool it down, the feeling whas better before.
Just to be clear, the timing boost is how much timing in total + turbo?
And the ramp, is how much it increases the timing over rpm??
Or please explain it to me
Old 01-26-2010, 02:45 PM   #11249
rc-racer-kirby's Avatar
Send a message via MSN to rc-racer-kirby
Hey Guys
Im trying to decide between the Tekin RS Pro, LRP Stock Spec and Speed Passion GT2.0. I run in pro stock ( 10.5 lipo ) and sometimes mod ( 6.5 lipo ) Although i have never seen anyone running tekin here in ireland i have heard nothing about good reviews in other countries. Is there still the same issue with bringing a laptop to the track to change the updates? It is the disadvantage i find with the Speed Passion and the advantage of the lrp is this dosent have to be done. When i get to a new track i have enough to fiddle with without having to bring the laptop out to install updates. I am currently running a Novak GTB so any of these ESC's will be quicker for me but i want easy enough to use but i do want ajustability. It will be run in a Schumacher Mi4 with a Speed Passion V3 10.5 motor.
rc-racer-kirby is offline   Reply With Quote
Old 01-26-2010, 02:54 PM   #11250
Originally Posted by rc-racer-kirby View Post
Hey Guys
Tekin is the best choice as you ask me.
Soon Tekin will come with a new software so that you can choose your program with the buttons on the speedo.
You can choose than just like LRP your setup on your speedo, so you don't need to bring your laptop to your club.
When I drive on my home track, I set my setup right and than I leave my laptop most of the time ad home.
With the Tekin RS/ RS Pro you can also run the 6,5T.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
