Old 09-22-2008, 06:24 AM   #1111
Trader Rating: 38 (100%+)
Originally Posted by Randy_Pike View Post
We're still working on Vista 64 bit.
Most mainstream apps don't even work on Vista 64. I work in IT and I don't even know anyone who runs it. Im surprised you are spending the time on that.
or8ital is offline   Reply With Quote
Old 09-22-2008, 07:33 AM   #1112
mangoman's Avatar
Actually i think you will find that is actually a common misconception and that a lot of apps do actually run, my understanding is that they dont work when the software requires device drivers.
Although i too am surprised that people are running 64 bit windows, although it is the trend of the future.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 09-22-2008, 12:10 PM   #1113
I'd be running 64bit now if it wasn't for incompatibilities with my anti-spyware software.
Old 09-22-2008, 12:18 PM   #1114
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I don't run 64 bit either. However some do and we're working on it.
The Mac stuff is going to be harder I'm sure. There are ways around it and I'm sure most of you Mac guys are familiar with it...
I blame it all on Bill Gates! LOL
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-22-2008, 12:23 PM   #1115
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
The mac programming should be fairly simple as its based on Unix...
In the mean time, if your a Mac user with an Intel processor, snag Win XP and use bootcamp, Parallels or Fusion. Crossover may or may not work, I am not sure.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-22-2008, 12:30 PM   #1116
mangoman's Avatar
Yep antivirus, firewall all that kind of stuff needs 64bit versions because they create virtual devices....
But im sure the tekin guys will get there
www.smaracing.org
Old 09-22-2008, 12:59 PM   #1117
MikeXray's Avatar
Trader Rating: 73 (100%+)
The long way to do it is use virtual PC 2007 64bit edition, and install xp 32bit in there, launch it when you need to run the hotwire.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-22-2008, 01:10 PM   #1118
trailranger's Avatar
Originally Posted by Trips View Post
I'm curious how you do that... It's probably just my crappy old monitor, but I'm having ahard time seeing the wire ends in the picture... If I had to guess, it looks like you tin them then squeeze them flat before the solder cools? Or do you flatten first and then tin?
Thanx
click the picture, it will show a larger pic.
I have a 30second process that whips and crimps the ends. I came up with this idea about a year ago when I was trying to solve excess wire fraying when I direct solder battery packs. A unintended benifit of the whipped taps is that solder does not flow upthe insulated part of the wire making it hard. I now use this any time I solder: Dean Plugs, Motors Connections, Battery Connection, and Now ESC connections.
I'll leave Wiki to explian "Whipping"
Step 1. Strip 1/4 to 3/8" of insulation off wire and loosed the stands.
Step 2. Wrap 26ga bare copper wire around the wire to be whipped.
Step 3. In one qucik motion Flatten the end using smooth jawed pliers.
Step 4. Flip the wire over and squeeze again
Step 5. Test fit the wire into ESC terminal slot, Repeat Step 4 tab is too thick.
Step 6. Hold tab in slot and solder inplace. **Once the end is soldered, you can no longer flatten and thin the profile.**
On step 3 i normally do the first flattening with a pair of larger pliers. In between the handles is a thin gap that helps get more leverage than the jaw alone. Some pliers have that gap with teeth, so don't use those.
A flat punch and a hammer will also work well on an anvil. Careful since you can hammer the whipped end foil thin. I would know.
trailranger is offline   Reply With Quote
Old 09-22-2008, 02:30 PM   #1119
ta_man's Avatar
Trader Rating: 151 (100%+)
I don't think I have ever tried to get my whipped wire ends that thin (I'll find out when I get my Tekin RS) but I crush mine in a 6 inch bench vise after they are tinned. It has a lot more leverage than pliers.
ta_man is offline   Reply With Quote
Old 09-22-2008, 03:51 PM   #1120
Giorgio's Avatar
Well, I might say I'm looking for an advice...
Try to make a long story short: not the fastest guy of the bunch, but a decent A-mainer at our club.
This year rules allows us to run touring, with lipo, BL, foam over asphalt.
So I grab a blue one, a 4.5 motor (blue as well).
First one: toasted in 4 laps... armature exploded... also the blue esc is gone.
Second one (warranty of the first package): 6 meeting plus some test. Then, out a turn...no more power. And the motor gone as well (simply times slower than before), finish the race with an orange esc, and a new blue 4.5 motor.
Third one: warranty over the second... 1 meeting and half. Same as 2nd. and motor as well same as above...
I start to have enough.... reliability is crucial as well the performance...
what will be the tekin package to go?
The Pro and which motor?
Any suggestion will be much appreciated...thanks
Giorgio is offline   Reply With Quote
Old 09-22-2008, 04:12 PM   #1121
Well if you are frying things that much I'd say you probably have a setup issue of some sort...either over geared or way to much bind in your drive train causing things to overheat badly.
Old 09-22-2008, 05:31 PM   #1122
Team Tekin
Randy_Pike's Avatar
If the blue 4.5 was on par for speed then go with the Tekin Redline 4.5 . If you're an a mainer you should be just fine.
I always recomend the Hotwire for tuning purposes outside of the norm.
Odd that you had such an issue with the blue. Any bad bearings in the car?
Old 09-22-2008, 05:58 PM   #1123
Pliers work fine for up to 12ga.
Old 09-22-2008, 06:06 PM   #1124
Hey Trailranger that looks great...your description doesn't mention but do you pre-tin the wires? It looks like they have solder all across them like they were tinned before getting soldered in.
Old 09-22-2008, 06:27 PM   #1125
no pre tinning. Once I know the tab fits the slot, I solder in place and the flux and bare copper will wick the solder into the joint. If you want to pretin or are reattaching wires the you would have to place the tab over the slot and flow the present solder while pushing the tab inplace. It is not a big deal if you use a solder-bulb to remove as much excess solder in the slot and tab first.
here is a better profile pic. click the picture for a larger view. Marco Shots are tough to focus..
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
