Old 01-26-2010, 08:06 AM   #11221
timmay70's Avatar
Originally Posted by JFuel11 View Post
I was running in the A-main with my 13.5 turn motor in my WGT and about 3 minutes in the car acted like the battery dumped within one lap it slowed down and then died. I am running a qualiyt life RX battery that was just charged and I run with both RX Switch and ESC Switch on. After the race I turned everything off and disconnected the main battery and hooked everything back up and it ran fine agian but then did the same thing in about 1 min or less. The 1s lipo was fully charged as well.
Anyone have any ideas that of what causes this issue?
Only thing I see, I never turn on the ESC switch. I hid the switch and put tape over it to ensure that it remained off. The switch essentially turns on or off the low voltage cut-off in the ESC for the latest firmware releases. If you have your LV cut-off too high, the RS may be reading this and going into fail-safe. It may be cutting out even though you have a Rx pack.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 01-26-2010, 08:13 AM   #11222
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by theisgroup View Post
the short answer is that you are adding timing at the wrong time.... if the motor has not spooled up enough for that much timing, then the motor can not handle the timing load that you are asking for. I am not sure why with v203, but that does not generate heat.
Thank you Yang for a great starting point on 13.5 1S for 12th scale.
I pulled your settings from the Tekin website to start.
Ended with settings of
50 boost
no turbo
27xx start
12000 end
profile 3
84mm roll with Redline
80mm roll with Nemises
Track is fast paced infield medium run to 100'+ straight
Cool winter temp asphalt
Camarillo Park, Ca
Plenty of punch, could not use more
Still pulling revs as entering decreasing radius sweeper at end of straight.
Near .4 drop during last min.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-26-2010, 08:17 AM   #11223
StewartFan20's Avatar
50 boost
no turbo
27xx start
12000 end
profile 3
Camarillo Park, Ca
What kind of changes could be made to this setup for a carpet track with a 80' straight?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 01-26-2010, 08:47 AM   #11224
theisgroup's Avatar
50 boost
no turbo
27xx start
12000 end
profile 3
Camarillo Park, Ca
np buddy, let me know if you wanted anything else out of the speedo. that setup was a good starting point and then we can make changes to match the track
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-26-2010, 09:05 AM   #11225
How is Tekin doing on the snowbirds?
How are they going against the mamba's, Advanced and SXX speedo's?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-26-2010, 09:58 AM   #11226
Really it's already so good I don't know what more I could want for.
Perhaps you could train it to make me a sandwich in the middle of the day
Old 01-26-2010, 12:12 PM   #11227
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Default V 203 motor cogging
I just put v203 in my VTA car and it is cogging or studering from a start. It did not do this with V200. Any ideas what is wrong?
I will have to ck my settings for more info.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 01-26-2010, 12:16 PM   #11228
50 boost
no turbo
27xx start
12000 end
profile 3
Camarillo Park, Ca
Hey guys, speaking of sandwich?? Did you notice StewartFan20 right in the middle of your posts? Even asked a question that went right with Yang's offer to make changes to match the track. Spreading the PB&J a little thick on the edges and forgot all about the middle?
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-26-2010, 12:22 PM   #11229
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Had this problem on a buddy's 1/12th. Seems like the firmware didn't load completely clean.
Roll back to v200, test that everything is back as it was, then update to v203 again, and if it's the same problem we ran into, you'll be good.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-26-2010, 12:28 PM   #11230
Post your settings and someone will help. Sounds like way too much timing too soon.
jeffb is offline   Reply With Quote
Old 01-26-2010, 12:48 PM   #11231
Default rs settings with cogging
motor 21.5 novak timming 0
boost 24
turbo delay 0.0, probably the problem set to 1.0
ramp 1.0
I have had a chance to play with the new version and settings yet so I am still figuring it out.
Old 01-26-2010, 01:05 PM   #11232
jeppesen's Avatar
Hi Guys
Need a quick help, is at the track right now, running with a rs pro and 17.5 redline motor, is very impressed with the power, but i am running a little hot a the end of a 5 min run, running 1/10 touring.
My settings are.
Boost 50
Turbo 10
Delay .2
Ramp 3
Start 2550
End 8000
FDR 6.6
The speed and punch is good, but what could i change to run it a little cooler?
Large scale racing with RS5 Touring car, Sanwa, Sav÷x, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Old 01-26-2010, 01:14 PM   #11233
tandman's Avatar
Send a message via Yahoo to tandman
Try moving your rpm end point higher maybe 10,000 or 11,500 this should help smooth out the power and should drop the temps.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 01-26-2010, 01:15 PM   #11234
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by jeppesen View Post
Hi Guys
My settings are.
Boost 50
Turbo 10
Delay .2
Ramp 3
Start 2550
End 8000
FDR 6.6
Longer turbo delay with ramp 1 or 2. Less total timing, higher rpm points.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-26-2010, 01:19 PM   #11235
reinstalling the new version seemed to help. Also I recalibrated the esc again.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
