Old 01-25-2010, 07:52 PM   #11206
Still Bill's Avatar
Originally Posted by 20 SMOKE View Post
what size is the track
42' x 85' with tight lanes. More built for 12th scale.
No more "California Freeways" here.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-25-2010, 09:53 PM   #11207
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Chris Furman View Post
What was the RPM range? it is not listed.
The RPM range is 2473 to 7500. Sorry, I forgot to list it.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 01-25-2010, 09:56 PM   #11208
Team Pink's Avatar
Originally Posted by Still Bill View Post
Derek,
Any WGT setup info to share?
Bill
Bill I do have a 10.5 Wgt setup that I use at A-main other than that I still need to play with 13.5. Will try to post it soon.
Old 01-25-2010, 10:17 PM   #11209
Still Bill's Avatar
Thanks kiddo.
Old 01-25-2010, 10:59 PM   #11210
avs
avs's Avatar
Originally Posted by Randy_Pike View Post
No, on a redline run it at 12.
wow, just so i don't misunderstand. that is 50 boost+10 turbo on top of 12 motor timing?
Tony Shimko
avs is offline   Reply With Quote
Old 01-25-2010, 11:28 PM   #11211
razzor's Avatar
Forgot to mention in my earlier post the only hassle i had with 203 is that i needed to fit a cap to my Spektrum reciever.
When i throttled out of teh slowest corner i got radio glitches and thought it was my radio seeing the aerial had broken on the Module.
Aftre the 2nd heat i fitted a cap and viola all glitches stopped.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-26-2010, 12:08 AM   #11212
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Strange WGT Thing Happened
I was running in the A-main with my 13.5 turn motor in my WGT and about 3 minutes in the car acted like the battery dumped within one lap it slowed down and then died. I am running a qualiyt life RX battery that was just charged and I run with both RX Switch and ESC Switch on. After the race I turned everything off and disconnected the main battery and hooked everything back up and it ran fine agian but then did the same thing in about 1 min or less. The 1s lipo was fully charged as well.
Anyone have any ideas that of what causes this issue?
JFuel11 is offline   Reply With Quote
Old 01-26-2010, 12:12 AM   #11213
Skitee's Avatar
I had the same thing at the K90 pre nats over the weekend but only with one of my RS's, both setup the same and both cars running the micro receivers.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-26-2010, 01:11 AM   #11214
Originally Posted by 008-Racer View Post
Confused!!!
Do the RPM settings affect the timing etc even if the turbo is not being used?
If so what should the start and max RPM range be for a Speed Passion 13.5 ver.3?
Medium tractio carpet with a 30m straight I was geared at about 5ish?
Thanks for your advice in advance
Can anyone give me some advice?
Please
008-Racer is offline   Reply With Quote
Old 01-26-2010, 01:42 AM   #11215
FuBlimey's Avatar
x2
I have been thinking it is my battery which is a 1s Thunderpower. It seems to happen to me after several cycles of the battery but I haven't found someone to tell me what the problem is. When I recharge the battery after this happens, the charger puts in only 2500 mah on a 5000 battery.
FuBlimey is offline   Reply With Quote
Old 01-26-2010, 04:58 AM   #11216
marcel p's Avatar
Send a message via MSN to marcel p
Please
rpm seting works only with boost
try end rpm at 22000 start rpm at about 5500
turbo 4 and ramp at 2 delay 0.7
fdr at 5,35+-
motor timing in the midle
greetings marcel
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 01-26-2010, 05:30 AM   #11217
Senna Racing's Avatar
Please
Randy explained this a few pages back
But It works something like this I'm sure someone will jump
in a correct me
Say
You have your start rmp at 1000 and end at 10000
with boost set at 10
You will 1 deg every .1 of a sec
Or somthing like that but click on Randy's post and you should
find it
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-26-2010, 07:19 AM   #11218
in a correct me
Say
find it
Change sec to RPM and you're there.
Boost is purely RPM based adding timing between your start and end RPM's.
Turbo is purely time based adding timing at full throttle after a time delay at a set increase based on time.
Motor timing is there always in sensored mode. With or without boost and/or turbo.
Fred_B is offline   Reply With Quote
Old 01-26-2010, 07:23 AM   #11219
Thank you Tekin for checking my Hotwire and finding no problem.
I updated the new RS to 203 and had the same comm fialure as before but this time the LED stayed on. I reconnected the RS and restarted Hotwire and saw that the update did take. Ran it again and everything worked smoothly and it is now sitting in my WGT ready for action on Sunday.
AreCee is offline   Reply With Quote
Old 01-26-2010, 07:32 AM   #11220
again tekin service next to none
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
