Old 01-24-2010, 10:05 PM   #11146
oze
No. mdf = uF = microFarad. Farad is the unit of caps capacity.
I have no idea what you mean by standard cap.
I have got a Spektrum cap and it is either 2200 or 2500 uF (I do not remember, but it is not that important, either of them will be okay). 330 uF is not enough capacity.
oze is offline   Reply With Quote
Old 01-24-2010, 10:08 PM   #11147
RLMW VQ's Avatar
and that is what you have on the positive and negitve terminals of the speedo.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 01-24-2010, 10:18 PM   #11148
oze
Sorry, not. I thought you need a power cap on your receiver. Sorry for the confusion.
Old 01-24-2010, 10:20 PM   #11149
RLMW VQ's Avatar
ok thanks i might have said it wrong but if any one has and input that would be great.
Old 01-24-2010, 10:21 PM   #11150
oze
See the tekin site:
http://www.teamtekin.com/accessories.html
If you have RS, you will need 16V and 1000 uF
Old 01-24-2010, 10:25 PM   #11151
RLMW VQ's Avatar
according the the tekin site it says that the rs uses part# tt3520 which according to the specs the its 16v and 330uf which is what i picked up but the one i got is a tick smaller that the standard one that come with it. so i guess i kind of ansawerd my own question but what are the the other numbers one the stock cap. and will smaller size cause any issues with the speedo.
thanks
Old 01-24-2010, 10:30 PM   #11152
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Our cap is not just a standard capacitor. Yes it's a 16v 330uf cap. It however has some special qualities.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-24-2010, 10:38 PM   #11153
RLMW VQ's Avatar
so will this cap i have work or will it hurt the speedo. of it wont work what is the max size cap i should look for to put on the speedo
Old 01-24-2010, 10:53 PM   #11154
niznai's Avatar
What you need and what Randy is trying to say is that they use a low impedance fast capacitor capable of rapid charging/discharging rates and with very little internal resistance and leaking currents. You can chase these down around on the web but you need to know where to find them. Farnell are one name, RS components are another. In the end I am not sure you're going to save any money though.
You cap might work but it is not guaranteed. Most likely it will be too slow.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-24-2010, 10:58 PM   #11155
RLMW VQ's Avatar
ok cool i dont care about the money i ording some from tekin but i want to run this week and dont know if they will be here in time so figured i would get one from the local electronic store to hold me over till they get here.
Old 01-25-2010, 12:00 AM   #11156
Dadaman's Avatar
Trader Rating: 20 (100%+)
Originally Posted by morris View Post
yes mine did the samething as yours.
i was told on here to use the same settings calibrate to radio at 90 or 95% on the epa.then after thats dont turn the radio back to 100%
i will try this friday when i go back there to race.
Tried it. it didn't make a difference
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 01-25-2010, 03:12 AM   #11157
Not problem at all, you can run with your cap, probably heat a litle more than normal, is you go to your local electronic shop, buy a low ESR (Equivalent Serie Resistance) cap, is you not have time to order the tekin unit, the tekin cap is very good quality component.
Or you can put 2 in parallels, for dismiss the impedance.
I use a 2200uf 16v, japanes cap, with very low esr, for mod racing in hot conditions, with good results.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 01-25-2010, 06:13 AM   #11158
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by King of B Main View Post
also my High Point on my radio is at 130. I am using Ko radio.
Don't change anything. Treat it like a mod motor and run a little negetive throthle expo. Say -10-15% and see if that clams it down some.
Originally Posted by LOW ET View Post
and what does having it set at 130 do?
Using the KO radio you have to set things a little differently for some reason inorder to for it to reconized full throtle. I set my radio up at 90 then bump it up to 135. This is the only way I get full punch everytime. It sounds weird but it works. When running a friends M11 I don't have to do this but with my KO I have to.
STLNLST is offline   Reply With Quote
Old 01-25-2010, 06:17 AM   #11159
STLNLST's Avatar
Originally Posted by BlackedOutREVO View Post
Haha to bad you were in the b main
Not bad at all. I damaged the car during the first lap or two in the 2nd round and the car wasn't the same then I finally just pulled it a few laps later. The main was a different story. I got taken out by Dujuan I made his car too fast with the settings I put in his speedo for the main.
Old 01-25-2010, 07:08 AM   #11160
theisgroup's Avatar
Originally Posted by EAMotorsports View Post
Now gotta find one for the TC
EA
glad you made up your mind on speedos. can't help on the tc front. but I am sure there will be plenty of sharing at the birds
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
