Old 01-24-2010, 08:34 PM   #11131
jammincrtjames's Avatar
Originally Posted by CarbonJoe View Post
If your radio is close to the car (as it would be on the bench), the Tx might be overloading the Rx. This could cause the ESC to not see the neutral signal. If the ESC doesn't see neutral at powerup, it won't arm, so the motor won't run. If you move the Tx a few feet away, I'd bet that it would be just fine. Been there, done that.
Thanks. So you have made settings changes and have lost signal afterward as well? Strange thing is that I never did re-calibrate. i just opened the Hotwire up, hit apply setting again. closed it and then everything worked.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 01-24-2010, 08:52 PM   #11132
Regional Moderator
CarbonJoe's Avatar
You only need to re-calibrate after updating firmware. I have had the ESC not arm in the pits after powering up before putting the body on (Tx right next to the car). After the body is on, moving the Tx away from the car by more than about 3 feet, and the ESC arms. Never had to do anything with Hotwire to get it to arm again. This doesn't happen every time. By the time I walk from the pits to the track it is usually good to go.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-24-2010, 09:02 PM   #11133
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Tekin RS was balls fast in 12th scale today!! Just got to do some final tweaking at the birds and it should be goooood! Now gotta find one for the TC
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-24-2010, 09:06 PM   #11134
Trader Rating: 23 (100%+)
EA
Question is, what the hell did you do to that battery pack today? Looked kind of puffy in the picture on Drew's phone.
SteveL is offline   Reply With Quote
Old 01-24-2010, 09:07 PM   #11135
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Odd thing I noticed the last time I tried to re-calibrate. When I went there the modes. Once I got to the final setting of break. My speedo just keeps on beeping. As if it does not read my in a break position. Any clue what is going on.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 01-24-2010, 09:07 PM   #11136
Dragula426's Avatar
Originally Posted by mhavlena View Post
OK thanks! Spektrum cap on order..I would assume that you are using one?
Start RPM = 4500, End RPM = 12,500
Drop your lower rpm down as low as it will go. The car will be much smoother.
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 01-24-2010, 09:11 PM   #11137
Bryan Kendall's Avatar
Originally Posted by Randy_Pike View Post
I would upgrade to a Tekin Redline!
I wouldnt reccommend it. Not enough torque. My novak ballistic hauls ass or the lrp x-12 vector stock spec.
Bryan Kendall is offline   Reply With Quote
Old 01-24-2010, 09:11 PM   #11138
Still Bill's Avatar
The first time I used Hotwire 4/V2.03 to update my settings, a little windows dialog box came up saying the settings had been successfully installed on my RS. Since that first time, I have not seen that box come up again. Otherwise, the new settings seem to be there when I check after each update.
Any idea what is wrong? Thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-24-2010, 09:13 PM   #11139
Team EAM
It had been done charging for 10 minutes and was just sitting on the table. I heard something pop a few times and didnt think anything about it. A few minutes later something popped again a couple times so I looked around and seen it! It never did catch fire but it was HUGE! If it would have been in a lipo sack I bet it would have caught fire as we would have never seen it!
EA
Contact Us
Old 01-24-2010, 09:17 PM   #11140
HanIce's Avatar
Trader Rating: 12 (93%+)
EA
I also had my three rides at ballistic speed on the weekend in offroad
Especially, my 2WD X-6 Squared ride
Way to go Tekin...
# GRID FIVE RACING TEAM #
👑🔱 king AE B5M🔱👑
HanIce is offline   Reply With Quote
Old 01-24-2010, 09:19 PM   #11141
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
anybody using an RS with a sensorless motor? any problem?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 01-24-2010, 09:29 PM   #11142
Originally Posted by stiltskin View Post
Could be a bad sensor wire, dirty sensor board or LVC on the spektrum. You could try a different wire, clean the motor or install a spektrum voltage regulator. (plug in capacitor)
question:
Is there really a LCV on the spektrum? We all know of the LCV within the ESC, but on the receiver as well? It does not make any mention of this within the spektrum specs...there's mention of a volatge range between 3.5 and 9.6 volts...just wanted to make sure.
Thx!!
mhavlena is offline   Reply With Quote
Old 01-24-2010, 09:50 PM   #11143
RLMW VQ's Avatar
what are the specs to look for when looking to replace the cap on the speedo. i went to my local electronics store and the got one that is 16v. 330mfd and 105c. the standard cap says 16v and 330 but im not sure what the other numbers mean. any suggestions on what to look for
thanks
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 01-24-2010, 09:54 PM   #11144
oze
You will need a 16 V and 2500 uF (mfd) capacitor. Pay attention to polarity when you connect it.
oze is offline   Reply With Quote
Old 01-24-2010, 09:57 PM   #11145
RLMW VQ's Avatar
what is the standard caps mdf. what i see on the cap is 330 so is 2500 uf equal to 330mdf
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
