Tekin RS ESC sensored >
Old 01-24-2010, 03:38 PM
  #11101
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
another great day with 17.5,got faster all day
20 SMOKE is offline
Old 01-24-2010, 03:51 PM
  #11102
Trader Rating: 35 (97%+)
Originally Posted by wingracer View Post
Back your throttle profile down to 3 or lower. That might help a bit.
Thanks, I was going to try that last night but destroyed my car in main. Now for sure I am going to try.
Originally Posted by ShaunMac View Post
Raise your end RPM. (14000 - 18000) It will help smooth out the rate at which the boost is applied.
Thanks will try
Originally Posted by LOW ET View Post
what size track, and how hot is the car after a run?
i have the x12 13.5 and i'm looking for tc setups.
I think track is 120X70 It is WestCoast racetrack.
I am not using a fan and motor is coming off at 175 temp.
King of B Main is offline
Old 01-24-2010, 03:58 PM
  #11103
jammincrtjames's Avatar
Default Strange Problem
last night racing i made some changes on the speedo. I turned everything off then back on again and I only had servo movement, but not throttle. I thought it might be that the radio needed to be re-calibrated, but once I tried to re-calibrate, the speedo never found the neutral point.
I hooked the hotwire back up, hit apply settings again, closed out everything, turned everything back on and then the car worked.
Does anybody have any idea what might have been going on? I have also had the speedo lose the calibration once after a setting change. Is this normal?
jammincrtjames is offline
Old 01-24-2010, 04:02 PM
  #11104
LOW ET's Avatar
Trader Rating: 98 (100%+)
i may have to raise my timing then. i think it's set at 40 or 45 with no turbo. i'll be running on a 90X40 track.
LOW ET is offline
Old 01-24-2010, 04:06 PM
  #11105
also my High Point on my radio is at 130. I am using Ko radio.
Old 01-24-2010, 04:07 PM
  #11106
LOW ET's Avatar
and what does having it set at 130 do?
LOW ET is offline
Old 01-24-2010, 04:11 PM
  #11107
20 SMOKE's Avatar
mine goes to 150,didn't really see anything
20 SMOKE is offline
Old 01-24-2010, 04:15 PM
  #11108
wingracer's Avatar
Trader Rating: 24 (100%+)
But, but, but ours go to eleven.
wingracer is offline
Old 01-24-2010, 04:16 PM
  #11109
20 SMOKE's Avatar
20 SMOKE is offline
Old 01-24-2010, 04:32 PM
  #11110
The higher you go, the more power you get. Atleast thats how it feels to me. I use to run mine at 150 too.
Just wondering did anyone else lose there trottle trim ? I've been trying to add a little roll into my car and doesn't seem to work?
Old 01-24-2010, 04:39 PM
  #11111
Senna Racing's Avatar
You could drop your throttle profile to 3
start rpm 4800 end 18000
Im running 13.5 LRP X-12 Motor
drag brake off
brake strength 100
limiter off
neutral width 5
voltage cutoff 2
motor type 1
throttle profile 5
timing boost 48
turbo boost 8
start RPM 4700?
End RPM 10000
Turbo ramp rate .2
final gearing 7.98
I have to much rip coming out of turns. Any idea how I can calm my motor down??? besides using my finger to control throttle. Any help would be much appreciated.
Senna Racing is offline
Old 01-24-2010, 04:41 PM
  #11112
wingracer's Avatar
Use the push control in the esc for that.
Old 01-24-2010, 05:20 PM
  #11113
Kas$
I set your profile pretty close to what I set Robbies, Spence, Arvin, and Dannys to. Are you running a fan? If not you might want to add one. We need to adjust if you changed the motor timing to the middle hole. We are all running the middle hole on the duo1.
I'm headed to the birds but see arvin next time your at the track as he is in charge of tekin profiles in my absence.
Pm me and I'll send you my number.
munrath is offline
Old 01-24-2010, 05:24 PM
  #11114
Default TC 2S motor cogging? hesitating momentarily?
Hi Guys:
Running a TC, 2S, 17.5 Novak SS Pro, V.203, FDR = 5.0 (track approx 75'X34'), timing boost = 50, turbo = 10. Spektrum receiver
Due to my new settigs mentioned above with V.203, I recently added a motor fan (integy) to keep motor cool, just ran 2 qualifiers with no problem, 1st race there was two moments where the car cogged or hesitated momentarily. Didn't happen on the next race, albeit, I did lower the timing boost to 40.
Some say the sensor harness might have been involved, some say that perhaps a capacitor may help.
Could this be due to the spektrum receiver going below min voltage, therefore shutting on and off? In this case, the capacitor could help? Temps on the motor are not too high....
Any comments / advice would be greatly appreciated.
Regards,
MH
mhavlena is offline
Old 01-24-2010, 05:32 PM
  #11115
20 SMOKE's Avatar
the novak ss has around 25deg of timing and with 50 time boost that 75,i would lower the timing boost to 30-35 gear down a tooth and turn of turbo for now.start rpm 2-3k end 9-10k.is the track ft or meters
20 SMOKE is offline
