Old 01-22-2010, 01:18 PM   #11011
georgec's Avatar
Default RS When???
When will Tekin ship new stock to the LHS's so Ampdraw can ship my RS to me? I hope before 1/12 scale season is over
georgec is offline   Reply With Quote
Old 01-22-2010, 01:22 PM   #11012
JLock's Avatar
Originally Posted by bukil View Post
I read somewhere that with v203, you "would" gear your 17.5 like your 13.5 with v200 initially. Then tweak it from there depending on your track.
My 17.5 is geared at 6.2, and it's plenty fast.
Depending on motor, a 6.2 on our size track will get you lapped a bit. I am running about 5.0, running just behind my track's fastest 17.5 racer, and comming off the track less than 130 F degrees. I am will be experimenting more this coming weekend with different FDRs, different setting tweaks, and watching motor temps very closely.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 01-22-2010, 01:22 PM   #11013
Trader Rating: 16 (94%+)
Originally Posted by JLock View Post
At the carpet track that I run on, we had been running FDRs in the low fours. However, when I lost my Checkpoint motor, my FDR was between 4.7 and 5.5. My Pulse motor was at 4.71 FDR. It was apparent that I hit that initial glitch in v203 where the start/end rpm changed after setting (this was discussed a few pages back). When I rechecked my setting, the rpm range was not what I initially had set (closed the gap considerably between start and end rpm). If that rpm range is too close/short, it will build up heat very quickly and then poof, no motor. Now, I triple check it and have not had an issue since my Pulse incident.
JLock (Juan) - That FDR is too high. I have my Sedan's FDR at 5.7 using a Novak 17.5 Ballistic with Tekin 203 software.
My car was probably the fastest on the track last weekend, if I could only drive.
Your starting and ending RPM's need to be about 4000 - 12000, and timing at 50-deg. Add 10-deg Turbo with a .6 delay.
kn7671 is offline   Reply With Quote
Old 01-22-2010, 01:27 PM   #11014
JLock's Avatar
Kelly,
Well, your car's IR and mine are a bit different (1.7 to 2.16). With more conservative v203 settings, at 4.9, my motor temps did not get above 130 F degrees and I qualified second this past weekend and was hanging with Gilbert much of the early part of the main. Again, I will be experimenting with my car more this coming weekend to find a better sweet spot.
Texas 5
Old 01-22-2010, 01:43 PM   #11015
JLock's Avatar
.....Your starting and ending RPM's need to be about 4000 - 12000, and timing at 50-deg. Add 10-deg Turbo with a .6 delay.
Thanks for this tidbit of info. I will incorporate this in my testing this coming weekend.
Texas 5
Old 01-22-2010, 02:15 PM   #11016
Still Bill's Avatar
Was thinking of getting the newest Asus Netbook with Windows 7 Starter. Has a faster Atom processor. Will Windows 7 Starter work with the 2.03 Tekin Hotwire?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-22-2010, 03:00 PM   #11017
clparsons123's Avatar
i just got a tekin what kind of setup should i start with for 17.5 on a carpet track the size is 100ft/65ft
motor is a duo 2
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 01-22-2010, 03:20 PM   #11018
JLock's Avatar
motor is a duo 2
Try what kn7671 posted a few post earlier and work around it from there. What brand of car are you running? Also, with the Duo 2, you might want to retard the motor timing on the can a little to help in keeping motor temps down with certain settings.
Texas 5
Old 01-22-2010, 03:33 PM   #11019
Trader Rating: 23 (100%+)
Originally Posted by TommyBlazin View Post
that was a mistake,i have rollout down,just the start/ finish rpm for 13.5 1/12..203 software...just not sure of how high i go,and low i could start, the rest ill get to..thanks
On our small track, 66' straight, I have the start rpm at 2,490 and end at 9,000, boost at 45 and no turbo. Roll out is 64-65mm with a Duo 2 timing set to one notch above middle. Car is very fast and temps end up around 130-150 after 8 minutes. I tried the timing on the motor at 0* but it was just slow. I also smoked a Duo 2 with the boost at Max and Turbo at 10 so there is a window that you need to be in, just not sure where that window is for your track.
SteveL is offline   Reply With Quote
Old 01-22-2010, 05:15 PM   #11020
Send a message via AIM to AxiomJacob
What is a recommended FDR for a 80x50 carpet track 13.5 rubber for v203? I'm thinking 45 for timing on the speedo and the rest im wondering, first time racing onroad in 7 years.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 01-22-2010, 05:50 PM   #11021
an xray t2 009
Cory parsons
Old 01-22-2010, 06:30 PM   #11022
el salvador's Avatar
Thumbs up
I have this exact Netbook, and everythings good !
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 01-22-2010, 06:30 PM   #11023
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i would gear around a 7.0 to start
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-22-2010, 07:57 PM   #11024
Still Bill's Avatar
Many thanks El Salvador.
Old 01-22-2010, 10:07 PM   #11025
PDX-Spike's Avatar
From what I understand, the "long" timing mark on the endbell of the Duo 2 is not zero degrees of timing. If you look at the endbell with the timing marks oriented at the bottom of the endbell, the mark to the right of the long mark is 0 timing.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
