Old 01-20-2010, 03:42 PM   #10921
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by boosta1276 View Post
the profiles are like throttle expo 1 giving a negative expo effect (smoother)and 5 giving a positive effect (more aggresive)
thx
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-20-2010, 03:46 PM   #10922
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Originally Posted by morris View Post
so basically i can turn down the turbo boost but up my timing to the max.
and it will still go pretty fast?
on another note if i left the turbo on and say started it at 2000 rpm vs 5400 that the turbo will kick in sooner?
and the throttle profiles do what.
as i am using 3 now.
Turbo is controlled by the delay setting, which is activated after full throttle is applied. Turbo is being used exclusively under full throttle conditions.
The Starting/Ending RPM range controls the rate that timing boost is applied between the RPM range you specify. This setting doesn't control turbo boost timing rates.
Check this link for better explanations of the turbo and timing boost functions, along with a general overview of how the RS and RS pro work:
http://rcfaq.weebly.com/tekin-rs--hotwire.html
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-20-2010, 04:04 PM   #10923
jeppesen's Avatar
Hi guys.
Today it happent, it really happent, the postman came with my tekin rs pro an a 17.5 combo kit, it looks good, and i cant wait to get on the track with it.
But i need your help, please PM me your favorite settings, i will be using the redline or a speed passion v3 motor, ive got the hot-wire cable.
Most of the time the racing will be on a small technical track, maximum 25 meters strait and alot 180 deg corners.
thanks
Large scale racing with RS5 Touring car, Sanwa, Sav÷x, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Old 01-20-2010, 04:30 PM   #10924
Jeppesen - I hate it when guys do this to me, but if you go back to about page 626 in this forum Randy of Tekin posted settings which are actually a pretty good starting point. I'm racing rubber tire on a medium size AC track, so my settings may not be good for you, but here they are if you want to consider. Whatever you do, when you change settings run for 2 minutes and check temps. If not bad run for 4 min and check...don't want you to smoke your motor. I'm running a Speedpassion 17.5 also.
Timing Boost Max
Turbo 10
Neutral width 10
Brake 100
Voltage cutoff 2
RPM range about 4500 - 12,000
Turbo delay 0.4
Sensored
Throttle profile 3 (or 4)
I didn't change the motor timing - so whatever it came with out of the box.
After a 5 min run my motor was coming off at about 120 deg F, geared at a FDR of about 5.5.
Thats all I can remember right now...I know its a lof of infor to pour back through but there's a lot of good info sprinkled back through this thread.
Good luck - Mark
markg is offline   Reply With Quote
Old 01-20-2010, 04:33 PM   #10925
Just read your post again. With a track like that I would bet you will get limited use from the turbo...you may want to gear more for infield at about 5.6, increase the ramp to 3, change throttle profile to 4, and tighten up the rpm range just a tad to 4000 - 10,000.
Try it and see what you think, and remember to temp your motor just to make sure its not getting too hot...
Old 01-20-2010, 05:43 PM   #10926
Trader Rating: 14 (100%+)
Hey Guys I know i have read of this problem before but I can't find the answer. I registered and downloaded vegas_3_32_200 zip file. Extracted and saved, deleted old hot wire, ran setup batch file. A am running XP so I assume there is no hidden file? My problem is 200 is the highest version I see in options side bar. What am I doing wrong?
Sorry for the repeat Question
rushrush1 is offline   Reply With Quote
Old 01-20-2010, 06:00 PM   #10927
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You're downloading the wrong file. When you get to the Hotwire page to register make sure to hit F5 and refresh the page. Then once you register you will get the link to the download.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-20-2010, 06:13 PM   #10928
Thanks Randy
I regestered again hopefully it will work this time.
Old 01-20-2010, 08:00 PM   #10929
cheehtae's Avatar
Trader Rating: 15 (100%+)
If you change your motor from a 21.5 to 17.5 do you have to change your esc parameters?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-20-2010, 08:05 PM   #10930
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
its not needed but you may have to make small changes to the end/start rpm and timing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-20-2010, 08:13 PM   #10931
cheehtae's Avatar
OK, I should have added would it make a difference if your racing from a smaller to larger track or vice versa.
Old 01-20-2010, 08:24 PM   #10932
This is what I find:
For a smaller track, use a larger FDR (smaller pinion), larger boost, smaller rpm window and no turbo.
For a larger track, use a smaller FDR (larger pinion), smaller boost, larger rpm window and turbo.
This is assume to use the same motor. It is best to temp your motor and make small adjustments.
hardmankam is offline   Reply With Quote
Old 01-20-2010, 09:30 PM   #10933
Default redline 13.5
I have just received my first redline
13.5 motor. I see the markings0 to 24, howevver I am not sure where the timing is actually set.
Can anyone assist please.
splarity is offline   Reply With Quote
Old 01-20-2010, 09:41 PM   #10934
Assuming it's the same as my 21.5, there's 3 screws on the end with the sensor wire. I believe they're 2mm hex. Loosen those up a bit, and the whole black part rotates. There's a notch that should be around 12 to start with. That's the notch that indicates the motor timing.
-Mike
Old 01-20-2010, 09:45 PM   #10935
niznai's Avatar
There's a little notch in the platic endbell against the timing scale. That's your pointer.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
