Tekin RS ESC sensored
Yeah that is kind of the point in winning. They knew what they were doing and weren't upset about it melting down. I'm just pointing out that despite all these new timing things the fast guys are still pushing the limits on temp.
Ye I now more of them. Some of them don't go faster because they only thing that when you set your Boost and Turbo full open that they will go faster.
1. lower your throttle profile.
2. increase start rpm
3. if 13.5 increase end rpm.
the wider you have the rpm range the smoother the power comes on. 17.5 is probably the only class you want the car to shoot out of corners that hard.
Than they push it to the edge and it's there own fold.
Saturday I tried an other setup but the motor became above the 180F.
I changed gearing and my gearing. My motor temps went down but not my lap times. Whit the setup that I have now I'm a bit faster in the infield and a bit higher top speed.
I lowered the top speed so I could go true the corner full speed like the others. With the higher top speed I had to brake and lost all the advantage.
I played with the start RPM settings to get a better acceleration and that worked. My car accelerates now very smooth. It's also good to drive.
I had a faster setup but it was in the infield to fast and top speed to high.
I drive 10,5 2 cell lipo and the track is small and technical. So to much power will make it harder to drive.
keep learning
One great hing about this ESC and software updates is that it keeps people learning and something is constantly new which makes anything more fun. After reading this thread daily I have just a very basic general summary:
this is comapring 13.5 and 17.5 motors in TC:
13.5 motors should have a higher FDR (i.e. 7.0), a higher start RPM, and a wider RPM range
17.5 should have a lower FDR (5.5-6.0), a lower start RPM, and a narrower RPM range
Are these basic statements correct? Thoughts please.
I've found even a cheap 25mm fan wired into the ESC will drop the temps by 30F. I imagine a high RPM fan to the battery could really move some air.
Not sure how much the fans would have helped these guys though. The guy that TQed and won his motor was 230* when it melted down.
I've been running the Ballistic motor and it really falls off at 155 degrees. The fan is a necessity with that motor.
And they always will, regardless of the technology being used...
Hi,
can anybody say who the distributor for Tekin in Europe is?
In the Netherlands www.hanglooseracingproducts.nl is selling them and in the UK it's much more as I'm right.
More I don't now.
More I don't now.
Where you finding that 5cell losi pack?
I'd believe it. They just seem to come to a crawl at 155*s for me. I was talking to Brandon Shells about it and he said he found the same thing. I have had mine up to 172 degrees when my fan stopped working. It seems to still work fine but I was concerned. Kind of makes me want to go back to a Duo because those seem to be fine until a little over 200*.
