Old 01-18-2010, 07:35 AM   #10801
Trader Rating: 16 (94%+)
Originally Posted by lochness42 View Post
Anyone has suggestion how to setup RS Pro with SP v3 13.5T for ETS race?
I tried to setup it by myself this weekend but unfortunately I had to race SPX for finals as my motor was too hot and not very fast during qualify.
Several people at my track are running their 13.5 motors with the following Tekin RS settings:
Timing Boost - 50
Turbo - 10
Delay - 0.8
Turbo Ramp - 3
Start RPM - 5000
End RPM - 15000
kn7671 is offline   Reply With Quote
Old 01-18-2010, 07:42 AM   #10802
OK guys need help again!!
I am running a speed passion 13.5 ver.3 geared just over 5.0
I had been running Timing on about 45 and turbo 10 but I kept over cooking the corner at the end of the straight!! So I decided to try it with the turbo off this was much better as I didnt push wide
In the last run I set the Timing to max with the following RPM ranges
End RPM - 10,001
Start RPM - 2,721
Gearing now at 4.9ish this was plenty fast enough with lots of mid pull and top end
Straight at a guess was about 30m ish?
Did I have the timing silly high or is this fairly common also do the RPM ranges seem OK
Comments welcome please
008-Racer is offline   Reply With Quote
Old 01-18-2010, 07:47 AM   #10803
lochness42's Avatar
Originally Posted by oze View Post
I do not know much about TCs so I can not help. Try to better specify what you are looking for. What motor do you use, what is the size of the track, is it fast or technical, etc. I think it would also help those who help you if you give the setup you used. Maybe someone can tell you what was wrong.
Well as I mentioned it's Speed Passion v3 13.5T motor. Track will be European Touring Series in Czech Republic - http://www.youtube.com/watch?v=HggWopSBkJU.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-18-2010, 07:48 AM   #10804
lochness42's Avatar
Timing Boost - 50
Turbo - 10
Delay - 0.8
Turbo Ramp - 3
Start RPM - 5000
End RPM - 15000
what about fdr? Anyway thank you.
Pavel Balint
Old 01-18-2010, 07:48 AM   #10805
stiltskin's Avatar
Trader Rating: 102 (100%+)
End RPM - 10,001
Start RPM - 2,721
It's possible that your turbo was kicking in just as you were about to let off for the corner. You could try a lower delay (if yours was .5 or above).
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-18-2010, 07:49 AM   #10806
lochness42's Avatar
Wasn't your motor too hot? I had wider RPM range and my motor was getting to 200F, I also had FDR about 5.5 and higher.
End RPM - 10,001
Start RPM - 2,721
Pavel Balint
Old 01-18-2010, 07:57 AM   #10807
is this the layout for the next ets race?
MartinBasse is offline   Reply With Quote
Old 01-18-2010, 08:05 AM   #10808
lochness42's Avatar
Yes it's supposed to be the one. It was czech warmup race for ETS.
Pavel Balint
Old 01-18-2010, 08:16 AM   #10809
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
End RPM - 10,001
Start RPM - 2,721
what is the ramp.
if it is to fast take some turbo out,go down to 5.
there are a few other things you can do on a small track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-18-2010, 10:19 AM   #10810
End RPM - 10,001
Start RPM - 2,721
No my motor was only coming of at about 65ish!!
What would happen if I was to widen or shorten the RPM range?
Old 01-18-2010, 10:27 AM   #10811
20 SMOKE's Avatar
i think you are over geared.did you use 200
i would be at a 3500-4500 start and a 14-16k end
this is a tc
Jamie W
Old 01-18-2010, 10:47 AM   #10812
From my understanding ... Bigger RPM spreads should be better for motor heat .... Reason being, max boost is less likely to be applied in the tight sections where it isn't needed. Same for bumping up the lower RPM, that should also help with motor heat.
malkiy is offline   Reply With Quote
Old 01-18-2010, 10:55 AM   #10813
Skiddins's Avatar
Can anyone give any knowledge with regard to changing the start/end rpm's in the 203 software and how the changes have effected to car.
This is for TC.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-18-2010, 11:00 AM   #10814
niznai's Avatar
Default boost/Turbo ramp
This one is for the Tekin team.
What would you say the ramp was for boost and turbo before v203? (I mean is it equivalent to 1, 2 or 3 in v203?). I need to decide what ramp to start with.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-18-2010, 11:11 AM   #10815
Use this setup. It's without the Turbo but it goes fast.
Motor temp under the 80C.
http://www.mikky32.com/index.php?opt...d=35&Itemid=49
Marcel Pinkster his setup.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
