Tekin RS ESC sensored >
Old 01-17-2010, 11:45 PM
  #10786
bender's Avatar
I've just bought an RS Pro and I am having problems calibrating it.
It appears to be calibrated fine...but I couldn't do it the way the manual describes
The esc would not chime when moving the trigger to the full forward position, and the only way I got it to work was to wait until the neutral chime, then go full foward, full brake, then wait for the chime.
Also, the throttle direction is supposed to be set to normal...but mine only works if it is set to reverse.
Not sure whats going on...i have always found Tekin esc's to be really easy to set up in the past.
Radion is a EX10 Helios.
bender is offline
Old 01-18-2010, 12:17 AM
  #10787
theisgroup's Avatar
you have to set the radio to reverse on the throttle. I run a helios as well
theisgroup is offline
Old 01-18-2010, 01:43 AM
  #10788
Team-RTR's Avatar
Originally Posted by wingracer View Post
Am I the only one that finds it funny that Tekin's latest development has helped Novak sell a bunch of product?
Maybe they will keep producing them now that people are buying them.
Yeah i find it quite funny aswell..
trying to get my hands on one now
Team-RTR is offline
Old 01-18-2010, 02:17 AM
  #10789
bender's Avatar
Yeah done that, but it doesn't fix the problem.
Like I said...it appears calibrated correctly...but lord know how considering I couldn't perform the set-up steps like the manual suggested
bender is offline
Old 01-18-2010, 02:20 AM
  #10790
I use a KO ex1ur and I remembered 1 time, I need to reset the profile to calibrate properly, so maybe try to reset your profile on your tx. good luck
hardmankam is offline
Old 01-18-2010, 02:59 AM
  #10791
cannon's Avatar
Trader Rating: 35 (100%+)
Yes start with a completely new model and reset that model. Sometimes you have some trims set that cause problems
cannon is offline
Old 01-18-2010, 03:00 AM
  #10792
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
bender, it does neutral/throttle/brake so after the reverse throttle calibrate and your fine
20 SMOKE is offline
Old 01-18-2010, 03:25 AM
  #10793
Where can I download the latest 203 firmware?
billythekid is offline
Old 01-18-2010, 03:30 AM
  #10794
You can get it from the Tekin website.
rnd_tang is offline
Old 01-18-2010, 04:12 AM
  #10795
Does the Turbo Boost adds timing "in addition" to the Timing Boost? What would happen if I set the Timing Boost to 5 and Turbo Boost to 10, would the total timing be 15 or 10 or 5?
Thanks.
Old 01-18-2010, 04:16 AM
  #10796
wingracer's Avatar
Trader Rating: 24 (100%+)
Thanks.
Go back about 15 pages and start reading. TONS of good info back there.
wingracer is offline
Old 01-18-2010, 04:21 AM
  #10797
stiltskin's Avatar
Trader Rating: 103 (100%+)
Thanks.
Turbo adds timing in addition to the boost timing. Boost 5 plus turbo 10 would be 15 degrees of timing. Boost will come in when the motor hits your beginning RPM and will continue to increase up until your end RPM. Turbo will increase timing after your preset delay from full throttle. If you blip the throttle, it will start the delay over again.
stiltskin is offline
Old 01-18-2010, 06:00 AM
  #10798
lochness42's Avatar
Anyone has suggestion how to setup RS Pro with SP v3 13.5T for ETS race?
I tried to setup it by myself this weekend but unfortunately I had to race SPX for finals as my motor was too hot and not very fast during qualify.
lochness42 is offline
Old 01-18-2010, 06:04 AM
  #10799
20 SMOKE's Avatar
what were your settings
20 SMOKE is offline
Old 01-18-2010, 06:15 AM
  #10800
oze
I do not know much about TCs so I can not help. Try to better specify what you are looking for. What motor do you use, what is the size of the track, is it fast or technical, etc. I think it would also help those who help you if you give the setup you used. Maybe someone can tell you what was wrong.
oze is offline
