Old 09-17-2008, 02:32 PM   #1066
My Tekin arrived from Tekin. (Tanks Tekin. Is mine all arrived yet?)
I have tested it with a 9,5T Speedpassion. Started the end ratio on 4.9 and ended on 4,7. The speed didn't inprove because the track is to short for the top speed.
I moved it back to 4,9 and it went great. topspeed was good and accelteration was verry good.
Car reacted good. Head of the motor stayed under the 50degrees celcius and the esc only the 1 led.
100% timing and accelleration on 5.
Tomorow i'm going to change my cars setup for indoor and i'm going to put my 4,5 in it.
I have used a bigger cap. 4700/16v.
It worked gread.
Let you now how it goes indoor with a 4,5T
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-17-2008, 03:13 PM   #1067
m3ndo5a's Avatar
Let me say thank you Randy.
And for those having any concerns about there RS/Pro write Randy. Very fast reply.
Did he fix my RS/RS pro......ahhh
And "OH MY GOD"
The first thing my 10yr son said "its too fast taking off." I am still wearing this cheese.
m3ndo5a is offline   Reply With Quote
Old 09-17-2008, 03:48 PM   #1068
TRF415boy's Avatar
And "OH MY GOD"
Care to tell us whar it was?
TRF415boy is offline   Reply With Quote
Old 09-17-2008, 04:45 PM   #1069
m3ndo5a's Avatar
Basicly reset the software....if your RS/RS pro working fine no need.
Old 09-17-2008, 08:37 PM   #1070
Originally Posted by Randy_Pike View Post
16 gauge wire should be ok for 1/12.
Randy is this ok for a 17.5BL also what temp should I watch for?
any help with a starting roll out would also be nice
-=light=-
light is offline   Reply With Quote
Old 09-17-2008, 10:35 PM   #1071
It worked gread.
I guess it was in dual mode this setup? because the SP 9.5T Ultra Sportsman have locked timing, the only way to adjust timing is via Dual Mode...
Foodie is offline   Reply With Quote
Old 09-18-2008, 04:06 AM   #1072
no not in dual mode.
I will try that sunday. So that's even faster?
i used sensord only but is it better to drive the speedpassion in sensord/ sensorless mode?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 09-18-2008, 05:18 AM   #1073
Well according to this thread, yes! Gear the motor with zero timing, and find the right FDR, then to get top end adjust timing in Dual Mode, and then you should be flying... But on those tracks i run there is like 30-50 metres straights, and got to know it should be geared 5.5-6.0...
But tbh i havent even tried it myself, i got the SP 9.5T, but still waiting for the RS Pro to arrive...
Old 09-18-2008, 10:53 AM   #1074
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hey guys,
On the motor wire I'd just be cautious about running to small guage of wire. I know it helps with the T plate movement but be aware that you could be necking down the power. Try some really fine(ie high wire count) wire. You can try whatever you want but if the motor wires seem hotter then they should be, you're best off going with lower guage wire.
Running dual mode vs. Sensored only mode really depends on the motor. I still haven't seen where the SP motors are at in mechanical timing? If someone has that info I could make a strong suggestion. Until then My suggestion is to test them both.
I don't run 1/12 scale but I'm sure one of our team drivers will answer that for you quckly? Kenny L. You listening?
Please guys if you're having a set up issue with any tekin product hit me up via email: [email protected]
I'll work with you guys as fast as I can. We know we have some of the most advanced products on the market today. It's always nice to get a little guidance to get them to work at their best.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-18-2008, 11:09 AM   #1075
reenmachine's Avatar
Trader Rating: 26 (100%+)
Randy-
I haven't been able to find this info anywhere. Is there a way I can tell by taking apart my SP 13.5?
I will say that I assumed the fixed timing was low, run in dual mode, and set the timing to 90% and the thing hauls.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-18-2008, 11:33 AM   #1076
timmay70's Avatar
Originally Posted by reenmachine View Post
Randy-
That's pretty much what we did in Vegas with the 17.5 motors. I thought I heard Kenny say the timing was locked somewhere around 10 - 12 deg.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-18-2008, 11:44 AM   #1077
Kenny L's Avatar
Trader Rating: 16 (100%+)
I found the best running was to run Hybrid mode. I tried running sesored only and really gearing motor never could get topspeed as having lots of timing.Timing on speedpassion alone is somewhere between 13-15 from what I was told . Here is setup I'm running now. This is also same setup I did for Donny Lia's car too.
motor= Speed Passion 17.5
drag = 25
rev = 0
brake = 75
neutral = 10
blfw
throt = 5
volt = 0
push = 0
timing = 100
current = off
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 09-18-2008, 12:09 PM   #1078
is it possible we build up a database for the settings for different motors in different turns.
for example i don't know what is the motor of kenny.
for myself i am looking for a setup for 3 turn lrp motor and a very large track with a very long straight line.
khaledome is offline   Reply With Quote
Old 09-18-2008, 12:13 PM   #1079
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Has there been any study's done on if you go up in the timing, say from 80-90, that the change of 10 is equivalent to how much of a gear change?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-18-2008, 12:54 PM   #1080
Kenny L's Avatar
I would start with similiar settings to my 17.5 maybe turn up drag brake a bit, and turn down timing in esc to 50 to start with no motor timing and check heat. I have found lrp motors heat up when you time the motor.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
