Old 01-13-2010, 08:17 PM   #10591
Trader Rating: 38 (100%+)
Originally Posted by TeamTekin View Post
OK I can recreate the boost rpms going back to default. The only way I can make it happen is to not fully select the start rpm after hitting 'calc rpm's'. There is a ghost box around the rpm's that has to also be black background and may take more than 1 click. There may be more to it, but it seems as long as you click the start rpms a few times and make sure it is selected and highlighted it works correctly. We will put in some checks and balances to make sure it cannot happen.
Please get rid of the black and red background and use standard windows controls. Should go a long way in addressing some of the UI issues.
I found the RPM settings often don't take if I make those changes and then go and change one of the values on the left hand side.
I also suggest getting rid of the advanced button and slide out and just have it expanded always. That button is often slow to respond.
or8ital is offline   Reply With Quote
Old 01-13-2010, 09:36 PM   #10592
oze
The values on the left hand side are taken into account when the start rpm options are calculated that is there is a mathematical link between those values and the rpm values. So if you make changes on the left hand side, you have to re-calculate the start rpm as the previous is not right anymore. This means that you have to follow a certain rules i.e. after any change on the left hand side you have to set the rpm values again. It is like setting up your car: you have to follow a certain order because for example changes of front ride height will change right height in the middle, therefore you set your front ride height first and then you set your mddle value.
oze is offline   Reply With Quote
Old 01-13-2010, 09:39 PM   #10593
Trader Rating: 23 (100%+)
Agree with the black and red background. Very difficult to see on a netbook in a dark track. And also agree with eliminating the advanced button. No need as anyone with any brains would be running the latest software anyway. Would also be cool to allow the user to select their own start rpm instead of from a forced list of options, unless that could casue other issues. Or maybe just have a box to type in a desired rpm split.
And lastly, a link button to a list of example settings for those using it for the first few times. Not a link to the web site though as a lot of people don't have web access from a track.
Oh, and an I-phone and Blackberry app too.
SteveL is offline   Reply With Quote
Old 01-13-2010, 09:50 PM   #10594
pakk's Avatar
Trader Rating: 79 (100%+)
I'd like to be able to save and name settings. I know I could download the setup PDF, but with in the UI would be a lot nicer.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-13-2010, 09:51 PM   #10595
syndr0me's Avatar
Trader Rating: 32 (100%+)
Unless Tekin does it themselves, or releases the spec, I don't think we'll see the software ported anywhere. Plus the other side (to the ESC) is probably 1-wire, which is way more complex than plain old serial. (And patented.)
syndr0me is offline   Reply With Quote
Old 01-13-2010, 09:55 PM   #10596
Trader Rating: 21 (89%+)
Default thank you all... for your help
Originally Posted by InspGadgt View Post
Make sure any ABS is off on the radio if yours has that option and after you switch the throttle reverse you have to recalibrate the ESC.
thanks for all your help.. apparently the last message seemed to help. along with using factory defaults on my transmitter...
I just want to say one thing to the tekin guys,,... *&^##$( this is fast. amazing.. i cant wait till sunday when we race... its gonna be so much fun.
im using an fdr of 5.76 and it sounds like it can go lower.....im gonna try at the track.. thanks for everything once again...
RC4ODC is offline   Reply With Quote
Old 01-13-2010, 10:02 PM   #10597
Still Bill's Avatar
Default WGT
Interesting dialogues.
Any suggested settings for my new RS using the 203 software in my WGT? Have a Duo 13.5 motor on a medium carpet track (NorCal). Thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-13-2010, 10:09 PM   #10598
morris's Avatar
Trader Rating: 40 (100%+)
i am also new to this stuff.1st esc and just got a hotwire.had a friend set up the esc for me with the 203.seems good but could be faster.that was with a 17.5 duo2 motor.i usually run 13.5 with a orion motor.any thoughts on starting point with a 13.5?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-13-2010, 10:11 PM   #10599
How many cells, TC or 1/12? also how large is your track? ESC settings are very track and application dependent.
Tekin site has some pdf for reference:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
hardmankam is offline   Reply With Quote
Old 01-13-2010, 10:12 PM   #10600
morris's Avatar
im sorry running tc...losi type-r.
2s lipo
Old 01-13-2010, 10:18 PM   #10601
I posted this several pages back. My application is similar to yours.
My local track has a 80feet (25m) back straight. (top section in the attached pic) Outdoor, asphalt.
background info:
T2'008, 2sLipo + Tekin RSPro + LRP 10.5R
Spur: 84, Pinion 21, FDR = 7.6
RS setting:
motor = 0deg
profile = 3
boost = 40
turbo = 10
delay = 0.8
end = 12000
start 45xx
ramp = 1
(these are Randy's 'general' recommendations)
motor temp is 40C ish, outside temp is 15C
I find turbo kicks off a little late ... almost near the end of the straight, so next time, I would lower the delay to 0.5 / 0.6 and see how it goes.
This setting blows away my friend's xray with GTB + 10.5, while his FDR is at 5.8 and his temp at about 50C
Old 01-13-2010, 10:24 PM   #10602
morris's Avatar
background info:
RS setting:
motor = 0deg
profile = 3
boost = 40
turbo = 10
delay = 0.8
end = 12000
start 45xx
ramp = 1
ok thx...i hope i will learn this stuff.
im not sure how to come up with the fdr.
but my rollout is going to be like a 4.77 i think.
Old 01-13-2010, 10:36 PM   #10603
A little off-topic, but...
FDR = Spur / Pinion x Internal Ratio
eg xray t2 Internal Ratio = 1.9
Spur = 84
Pinion = 21
84 / 21 x 1.9 = 7.6
(FDR means for 7.6 motor revolution = 1 tire revolution)
From FDR, you can calculate rollout
Rollout = 3.1416(pi) x Tire diameter / FDR
so for 62mm tires, rollout = 3.1416 x 62 / 7.6 = 25.6mm
(Rollout means for 1 motor revolution, the car will travel 25.6mm in distance)
So your 4.77 is not rollout, most likely its the FDR.
Old 01-13-2010, 10:40 PM   #10604
morris's Avatar
Spur = 84
Pinion = 21
84 / 21 x 1.9 = 7.6
yea i used to caculate my rollout this way when i ran brushed motors.
i just go to gearchart.com and do it that way.
losi type-r 1.83 ratio
116 spur
45 pinion
=4.72 ratio..........i think....lol
Old 01-13-2010, 10:44 PM   #10605
morris's Avatar
i just checked it out on gearchart.it would be 37.96mm rollout and 4.72 ratio
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
