Old 01-12-2010, 03:59 PM   #10516
stonedgti's Avatar
Trader Rating: 15 (100%+)
It seems like there weren't any Tekins in the A main of the DHI cup. I'm wondering how it compares to the BD and SXX Stock Spec.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-12-2010, 04:02 PM   #10517
Don't worry, they are as fast as them on a indoor track without the Turbo.
Can't wait till they drive on a big track against each other.
Tekin was last year very fast on the large tracks because of the Turbo.
I believe that the SXX and Black diamond will be surprised.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-12-2010, 04:09 PM   #10518
there aren´t that many tekins racing in europe. and the best drivers are using the lrp or bd so it is not only the esc winning it is as much the man behind the sticks/wheel
MartinBasse is offline   Reply With Quote
Old 01-12-2010, 05:35 PM   #10519
Trader Rating: 21 (89%+)
Default current setup help
mike or anyone else here is my following setup. Is there anything you see i should be doing differently. Car was fast but not much faster than my previous setup? Temps were in the 150s
Track is 160 feet x 70 feet My current setup on v203 is as follows..
V203 Software
tc5r
Spur 72
Pinion 25
FDR 5.76
Tekin Redline 17.5 Timing set at 0
Drag: 0
Throttle: 3
Boost: 50
Turbo: 5
Delay: 0.4
Ramp: 3
Profile 3
Start rpm: 5000
End 13000
RC4ODC is offline   Reply With Quote
Old 01-12-2010, 06:36 PM   #10520
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Are you sure you had 203 loaded in your speedo? The motor temp is fine but you should have noticed a HUGE improvement in speed vs. 200.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-12-2010, 07:05 PM   #10521
tallyrc's Avatar
V203 Software
tc5r
Spur 72
Pinion 25
FDR 5.76
Drag: 0
Throttle: 3
Boost: 50
Turbo: 5
Delay: 0.4
Ramp: 3
Profile 3
Start rpm: 5000
End 13000
160' straight? more turbo and little more delay..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 01-12-2010, 07:52 PM   #10522
racer x 1's Avatar
Trader Rating: 27 (100%+)
does anyone kno why my tekin would be giving me the three blinking leds after just dwnloading from the hotwire?
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-12-2010, 07:54 PM   #10523
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
does it blink when you hook up the hot wire
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-12-2010, 07:55 PM   #10524
Krio's Avatar
Trader Rating: 150 (99%+)
After a firmware update you need to perform the initial setup again. The 3 flashing lights are saying you are not at neutral.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-12-2010, 07:59 PM   #10525
Going to run 2 cell touring car with a 13.5 motor for the Snowbirds. Have not used V203 yet so I need to know what would be a starting point. Thanks
Ginsu is offline   Reply With Quote
Old 01-12-2010, 08:02 PM   #10526
20 SMOKE's Avatar
here is cuffs http://www.teamtekin.com/hotwire/ESC...03-13-5-TC.pdf
Jamie W
Old 01-12-2010, 08:32 PM   #10527
great thanks
Old 01-12-2010, 08:41 PM   #10528
My local track has a 80feet (25m) back straight. (top section in the attached pic) Outdoor, asphalt.
background info:
T2'008, 2sLipo + Tekin RSPro + LRP 10.5R
Spur: 84, Pinion 21, FDR = 7.6
RS setting:
motor = 0deg
profile = 3
boost = 40
turbo = 10
delay = 0.8
end = 12000
start 45xx
ramp = 1
(these are Randy's 'general' recommendations)
motor temp is 40C ish, outside temp is 15C
I find turbo kicks off a little late ... almost near the end of the straight,
thus I need to brake earlier / harder.
Would you guys recommend to run turbo for this distance?
no turbo VS lower delay & lower end RPM?
any suggestions? many thanks!
hardmankam is offline   Reply With Quote
Old 01-12-2010, 08:51 PM   #10529
haywood's Avatar
Trader Rating: 49 (100%+)
Default Rs
Trust me, I just got back from the Novak Race and the V203 RS would eat the Black Diamond alive down the straight.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-12-2010, 08:56 PM   #10530
Senna Racing's Avatar
I would start by dropping the delay to
.6
Then try increasing the end rpm
But you should be able to get the turbo
kick in on that straight easly
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
