Old 01-12-2010, 09:19 AM   #10486
Fuzzy's Avatar
Originally Posted by EAMotorsports View Post
Anyone running the hotwire on a Mac using bootcamp or parallels?
EA
Eric,
I run the hotwire on VMWare Fusion and it works just fine. The tech's at Apple suggest running programs in VMWare or Parallels instead of bootcamp because if there is an issue with the program you're running, fixing it is just a matter of removing VMWare or Parallels and not having to rebuild your master hard drive.
Fuzzy is offline   Reply With Quote
Old 01-12-2010, 09:40 AM   #10487
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
I just purchased a Tekin RS combo with 17.5 Redline for stock racing...I plan on uploading the Vegas 2.0 software before the maiden voyage tommorow...im looking for a good FDR...guys at my local track are using 6.7 FDR...I have 38/20T (1.9) in a T2 009...I can achieve 6.7 FDR with a 30 tooth pinion...but what I dont understand is where did the notion of trying to achieve the 6.7 FDR that they are using come from? can anyone help? thanks
badKarma is offline   Reply With Quote
Old 01-12-2010, 10:02 AM   #10488
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It would depend on the track size and layout. Your best bet is to find somebody else running the RS and Redline 17.5 at your track who is having good results, and start from there. I think 6.7 is geared a tad short. Most people at my track run the redline closer to 5.5 or 5.0. That is on a very large track however, and there are too many variabls to give you a real starting point.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-12-2010, 10:06 AM   #10489
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
just what capt said,i have a 17.5 redline and i am in the 5-5.5 range,this is a good starting point unless the track you run on has a 50ft straight the 6.7 is way low.what size is the track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-12-2010, 10:11 AM   #10490
1shnot's Avatar
Has anyone try a orca 13.5t? http://www.muchhobby.com/shopping/images/OBM0135S.jpg
looks like speedpassion motor it has no timing adjustment so which set up woudld be the best? and fdr?
I run on about 90ft X 45ft carpet
thanks
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 01-12-2010, 10:24 AM   #10491
thanks
As it is like the Speedpassion motor, you must gear it heavier than the other motors.
Start with a FDR of 6,2 and lower it each time.
Try this setup.
Boost 45
Turbo 0
RPM 5500 - 18000
As the motor stays cool gear a bit heavier or higher the Boost. You must play a bit with it.
I think that the 5,6FDR will work but you must try.
Don't lower the start RPM. the motor has already a timing of 12 as it is like the Speedpassion.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-12-2010, 10:25 AM   #10492
dubble-m's Avatar
Joon,
Check out these recently posted set-ups on Tekin's website for 13.5.
http://www.teamtekin.com/hotwire/ESCsetups/index.html
Sell the ORCA......you should be runnin' a DUO anyway!
MM
dubble-m is offline   Reply With Quote
Old 01-12-2010, 10:45 AM   #10493
1shnot's Avatar
Originally Posted by dubble-m View Post
Joon,
MM
thanks mikky32...i'll try that
MM dont tell tags LOL its a lomg sotry, but i have to try that motor for a little bit, are you coming to FS for "john postman" race?
-Fast cats
-T.O.P
-Airtronics
Old 01-12-2010, 12:54 PM   #10494
badKarma's Avatar
ok, got the info...the track straight is approx 90-100ft, and the track surface it self is 100x50...so do you think the 6.7 is still too short for the 17.5 Redline? im going to by a 30 tooth pinion but whats another pinion to start with an compare? BTW im pushing a 106 spur gear...what motor temp is too hot and would indicate short gearing?
Old 01-12-2010, 01:01 PM   #10495
badKarma's Avatar
Old 01-12-2010, 01:05 PM   #10496
dubble-m's Avatar
Default RE:
Hey Joon,
I won't tell Mr. Tag
Yeah I'm all signed up for the Johnny P race. I'm heading to Action this weekend for Round 3 of the SOS.
Make sure you tell that Pill-major guy to put his off-road stuff away and get his TC ready!
MM
Old 01-12-2010, 01:27 PM   #10497
aussierevo's Avatar
Trader Rating: 14 (100%+)
Originally Posted by oeoeo327 View Post
Your motor temps seem to be fine. You should reduce your neutral width (NW) from 50 to about 10, and you should be able to raise the timing boost to a much higher number (30-40). If you are using any motor timing, make sure that you use 12 degrees or less. I'd also leave the turbo delay (which wasn't mentioned in youe setup) at a higher value until you're more comfortable with making timing adjustments; start at .8 seconds turbo delay, and work towards using smaller increments if necessary.
Thanks for your input, much appreciated.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 01-12-2010, 01:43 PM   #10498
Default Stormer Error Correction Formula
For you Tekin Guys who unfortunately have had v203 banned from your track, I found this link from a post Bob Stormer put out a couple of years back. Maybe you can print it out and post it at your local track. If it were only as easy as downloading some software, then becoming the best racer on the planet. Doesn't work that way. Handling/Power/Driver Error all produce the race result together and unfortunately for most of us - Driver has the larger part of the margin of error in the equation.
http://www.rctech.net/forum/electric...on-thread.html
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-12-2010, 01:54 PM   #10499
MaxSp97's Avatar
EA
I used Hotwire V203 with Bootcamp and never have any problem...
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 01-12-2010, 01:56 PM   #10500
baf1's Avatar
Default 203 ????
what pos had new 203 program for one day, with 17.5 in my losi and up in smoke it went... spoke to tekin. they said to send it back well i would but dont have time or money for this s**t every time an new program comes out. the car was very fast untill it just stopped,by the way i was running an rs...gearing was 7.3, motor temp was 159deg after 6 mins....
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
