Old 01-11-2010, 02:08 PM   #10456
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I'd leave the RPM window as is if you have a few slow corners on the track. If there aren't any slow corners and the average RPM is 8600, I'd suggest a starting RPM of 6000 and an ending RPM of 10K-11K. I can't say for sure how much the RPM will change with 40 degrees of timing boost - you'd probably need to use a data logging system to find an answer to this question.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-11-2010, 02:29 PM   #10457
Victory Side's Avatar
Send a message via Skype™ to Victory Side
Can anyone give me a good starting point for v203 with a 13.5 Ballistic in TC5 on a 70x70 track? Thanks
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 01-11-2010, 02:47 PM   #10458
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Try this setup with different gearing:
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-11-2010, 03:12 PM   #10459
Trader Rating: 20 (100%+)
Originally Posted by Krio View Post
Don't lower your boost at all, but rather up your end rpm to 18000 and give it a try. With the end rpm at 13000 you are at 50 degrees of boost when your car is only at half speed. You keep pulling down the straight because you have the right high end rpm timing, but its just coming in too fast leaving you with weak low end.
So from what I read to increase performance in general with this new software you should turn turbo boost to zero which means delay is irrelevant and pump up the end RPM. I have timing at 45 boost, turbo at about 7 and end RPM at 7000. Delay is at .5. Indoor carpet medium bite, medium size track. Thoughts????
storytyme is offline   Reply With Quote
Old 01-11-2010, 03:57 PM   #10460
Krio's Avatar
Trader Rating: 150 (99%+)
To start, yes turn turbo off completely and play with boost, start rpm, and end rpm. My rule of thumb for quick setups is this:
Take your motors kv and multiply it for 1s (3.7) or 2s (7.4)
17.5 is around 2200 kv and 13.5 is around 3300
Assuming 17.5 and 2s: 2200 x 7.4 = 16,280
Subtract around 10%: 16,280 x .9 = about 14,600. This is a good end rpm to start with. Set your start rpm around 10% of the end rpm, so 1,500.
Start with 0 on the motor and 45 on boost as a conservative setting. When you don't smoke anything bump it all the way up to 55. Re-gear accordingly for infield supremacy. If the car feels like it bogs at mid speed before launching then increase the END rpm. If it feels like its bogging from a dead stop, increase the START rpm.
Now AFTER doing the above setup and you are topping out on the straight for some reason, THEN add turbo. Roughly time how long it takes from the instant you grab full throttle going onto the straight till it starts to wind out. Subtract a quarter second and there is your delay. Add 10 degrees with ramp one to start and increase turbo timing until you accelerate down the whole straight. Then play with the ramp to make the acceleration smooth the whole way.
Again, this is (my current) in GENERAL findings. Different motors react VERY differently to timing and most of my testing has been with either the tekin motors, peak/orion, and novak velociti.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-11-2010, 03:58 PM   #10461
hana166's Avatar
Hi, I was wondering if anyone knows if the high speed brakes have improved over the last few software releases. I loved my RS Pro but had to let it go because of this reason.
hana166 is offline   Reply With Quote
Old 01-11-2010, 04:17 PM   #10462
For what I have field, they improved a lot.
I drove with Turbo max and normally the brakes a a bit weaker with full Turbo but now they were very good.
I drive now with 0 Turbo and they are fantastic. I lower them each time.
I'm now ad 70%
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-11-2010, 04:49 PM   #10463
MarkBrown's Avatar
Originally Posted by mikky32 View Post
May I put the doc on my website?
Sure, but a link would work better, since I update the doc pretty often.
MarkBrown is offline   Reply With Quote
Old 01-11-2010, 05:14 PM   #10464
aussierevo's Avatar
Trader Rating: 14 (100%+)
Have just been able to run my F104 pro with the initial settings and I'm seeking some input;
Tekin Rs with Redline 21.5T, rollout 80.82mm
DB: 10
RS: 50
BS:50
NW:50
MT:B/L F/R
TP:4
VC:N/A NIMH batteries
PC:Off
Tim B:18
Tur B:10
Sensored Mode only
End RPM: 7001
Start: 2437
Ramp: 1
I only got to run around my house, but after 2 minutes motor temp was 110-115 degrees F. Is that about right or a little too hot for such a short run.
Car feels like it's a little slow to begin, but once up to speed seems fine. What changes could be made to ensure motor temp stays low...lower/higher rollout or changes to above settings.
Any information or advice would be greatly appreciated.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 01-11-2010, 05:18 PM   #10465
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by oeoeo327 View Post
... I can't say for sure how much the RPM will change with 40 degrees of timing boost - you'd probably need to use a data logging system to find an answer to this question.
You called? Barry, how much real estate does your 1/12 have in it?
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 01-11-2010, 07:12 PM   #10466
oeoeo327's Avatar
Real estate is at a premium in the "Solid Gold" gen xl, especially when factoring in the use of a receiver pack. However, I'm sure some "creativity" could allow the data logging hardware to fit . We might have to investigate further to see if we could come up with a solution...
However, I used the information from the graph you've posted and revised my starting/ending RPM points along with my rollout. I'm looking forward to performing some on-track testing Wednesday afternoon.
Old 01-11-2010, 08:13 PM   #10467
Thank you Randy for the starting point.
Old 01-11-2010, 09:16 PM   #10468
bukil's Avatar
Trader Rating: 39 (100%+)
Tekin users were flying at our track. Speed was insane especially in our 13.5 class. They looked like they were modified class . And this is with no turbo ..... yet.
Thank you Tekin.
bukil is offline   Reply With Quote
Old 01-11-2010, 09:21 PM   #10469
It will be interesting to see the difference in RPM changes between 2c and 1c batteries.
The question was asked what difference 40' of timing boost would make to the upper RPM range. I can only comment on 2c 17.5, but here's what I saw on the datalogger. Without any timing boost and with no load on the motor, an orange 17.5 (@ N/30' endbell timing) spun up to ~17,000. With MAX timing boost at the default start/end RPMs, the same motor spun to 26,000. But most interestingly, out on track, at the end of the straight, towing a 1420g 4x4 up to max speed at the turn-in to the sweeper, that same 17.5 still spun up to 23,000.
Strangely, with just 10 points of Turbo Boost, the motor will attain a cool 30,000 RPM at the end of the straight. Seems like an awfully big jump for just a few more degrees of timing.
Old 01-11-2010, 10:10 PM   #10470
wallyedmonds's Avatar
Originally Posted by Bandit17 View Post
Just wanted to say that I am thrilled to be able to use my Hotwire on my 64bit system. Thanks Randy and everyone at Tekin.
i 2nd that and im loving it loving it i say ................
wallyedmonds is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
