Tekin RS ESC sensored
Steve this booster is not going to work well because it's not grabbing power directly from the battery. Rather it's taking the BEC voltage from the speedo and trying to boost that up. This is defeating the purpose. A good booster will grab power directly from the 1s battery pack.
Yeah that sounds good. Pulling off of the battery post on the RS is just tapping the battery in a different spot. As long as you're not pulling current/power through the BEC on the RS for a booster you should be good.
Could anyone tell me what speedo Brad Johnson was running in 1 12 scale 13.5 before he ended up switching to tekin for the mains at the Novak race?
Inquiring minds would like to know.
Hi is it ok for me to use a LiFe receiver pack on the RS?
I used one the otherday for a couple of runs and it seemed ok but the voltage when you charge it up (i think) goes to 7.2 which was higher than i was expecting.
Thanks,
Martin
Actually thats a dumb question considering thats 6 cells anyway was thinking of lipo with the voltage regulator although im not sure what that brings it down to for the receiver
Thanks,
Martin
I don't think that will be a problem with the RS at all, if anything was going to have a problem it would the servo if it wasn't rated to operate at over 6 volts.
Thanks,
Martin
Thanks,
Martin
When you turn you ESC on do you immediately start moving the throttle/brake trigger, this can cause what you are describing and was the issue with a member at my local track. When you turn your ESC on don't touch the throttle/brake trigger for at least 5 seconds.
1st thank to tekin wit is sw 203 running awesom,but only got 1 prblem,calibrate with my rs k no problem but after shutdown i need to calibrate again and again and again fyi i am using futaba 3pks i try adjust nw on rspro led 4,5 on hotwire 25 so anybody who use 3pks have this problem and have solution to fix it
*fyi- after shutdown an on again led1,3,5 blink and need to calibrate i had this prblem seen i use rspro and i asking in this thread but i havent got any answer to fix it or rspro running like that? not with other brand setting only once then no need to everytime to calibrate
Comments please
OK really looking for peoples comments good or bad on the following setup
This was the 1st time I got to use this speedo with version 203 and at a good sized track
I use a Speed Passion ver.3 13.5 in a 2S Touring Car geared at 5.00 overall (track size was 30m x 16m)
Ambient air temp was 8 deg c, and the motor was coming off after 5 mins at about 70
Drag Brake - 25 (Looking to increase)
Brake - 95 (looking to increase)
Neutral width - 5
Profile - 3
Timing Boost - 50
Turbo Boost - 15
Turbo Delay - 0.2
End RPM - 7800
Start RPM - 2527
Turbo Ramp - 2
The car was a missile in a straight line but I could do with a little more power out of the turns can anybody suggest what to do next
Please any feedback welcome
Neutral width - 5
Profile - 3
Timing Boost - 50
Turbo Boost - 15
Turbo Delay - 0.2
End RPM - 7800
Start RPM - 2527
Turbo Ramp - 2
Just wanted to say that I am thrilled to be able to use my Hotwire on my 64bit system. Thanks Randy and everyone at Tekin.
