Old 01-09-2010, 08:25 PM   #10366
Don't know, it doesn't say in the instructions or on the box. I just bought it last Saturday.
I'm not sure if this helps but after I recalibrate my radio and esc a single led is lit - # 4neutral width. It will stay lit for about 5seconds the go out and then the # 1 led will light for a second . After that the # 4 led lights up.
outlandr91 is offline   Reply With Quote
Old 01-09-2010, 08:27 PM   #10367
LOW ET's Avatar
Trader Rating: 97 (100%+)
randy, do you have any comment about the timing advance feature while in sensored mode?
LOW ET is offline   Reply With Quote
Old 01-09-2010, 08:28 PM   #10368
Trader Rating: 21 (100%+)
will the hotwire software work on windows 7? Looking at getting a netbook just for the hotwire and wanna make sure it will work.
VA_Racer is offline   Reply With Quote
Old 01-09-2010, 08:29 PM   #10369
looking at Randy's 13.5 asphalt set up and it uses a RPM range of 3500 to 12500. When I try to do this, I can set the end RPM to 12500, but then the program automatically gives me values to choose for the start RPM. Gives me 28XX and 45XX so I can get no 3000 range. Am I doing something wrong? Thanks
inpuressa is offline   Reply With Quote
Old 01-09-2010, 08:33 PM   #10370
wingracer's Avatar
Trader Rating: 24 (100%+)
So far, it's working perfectly on a friends new notebook with 32 bit windows 7.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-09-2010, 08:35 PM   #10371
is that ricks laptop sean?
Old 01-09-2010, 08:35 PM   #10372
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I alway set my timing advance to 100 when I'm running sensored only mode JUST in case I have harness come unplugged. This will give maximum speed.
Yes we're windows 7 compatible.
I had a version that would allow exact settings so just get as close as you can. I should go revise those sheets!
So run the 28xx setup. No you're not doing anything wrong.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-09-2010, 08:35 PM   #10373
LOW ET's Avatar
you're doing it right. i think randy's software is slightly different than ours.
Old 01-09-2010, 08:39 PM   #10374
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
if it is new and you have not done anything to it it is on 180(factory),the #4 led and #1 led flashing in a sequence is the temp indicator. other than that what is the problem you are having
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-09-2010, 08:43 PM   #10375
The problem is the motor isn't running fast. It's a Duo I , there is no pinion gear installed. At full throttle I thought the motor would be screaming.
Old 01-09-2010, 08:46 PM   #10376
20 SMOKE's Avatar
put a pinion on it and test run it,it will be
Jamie W
Old 01-09-2010, 08:49 PM   #10377
wingracer's Avatar
No, Tommy got a little notebook PC for Christmas. His 64 bit Vista laptop just did NOT want to do it but his little 32 bit 7 notebook is working great. I'm not sure what Ricky's laptop is.
Team Shepherd USA
Old 01-09-2010, 08:54 PM   #10378
20 SMOKE's Avatar
I'm using a dell notebook with xp32 bit and work awesome
Jamie W
Old 01-09-2010, 09:10 PM   #10379
Okay,one last question, I'm goint to be running at a 100 X 36 track with a 17.5 Duo I. What FDR should I be running at?
Thanks for your help Smoke.
Old 01-09-2010, 09:29 PM   #10380
20 SMOKE's Avatar
start in the 4.5 range,its kinda hard since your on the very old version,just run for 2-3 min and temp it.your going to have to play with gearing because in dual mode you don't use any motor timing
time to watch more SX
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
