Old 01-09-2010, 12:13 PM   #10351
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yeah see that's what I didn't like about it, no direct battery hook up. If you did that it would be just like the others.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-09-2010, 12:30 PM   #10352
Goingfast's Avatar
Trader Rating: 29 (100%+)
ygpm
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 01-09-2010, 01:18 PM   #10353
Trader Rating: 23 (100%+)
Originally Posted by Grenade10 View Post
I've used this booster up to Vegas version 200, and will try 203 on Sunday. The booster will work if you install a lead off either the ESC (+)(-) post or to the connector to the battery. Plug the booster into the lead and then into the esc. Don't need to turn on the RS and your good to go. I've run one of these for over a year at this point. Just remember to plug the power in correctly and into the "Battery" slot in the receiver.
Thanks guys! I have run leads from the + & - posts of the esc through a switch to the booster and then to the bat/aux plug. Seems to work fine on the bench. Does running the esc switch on do anything wired this way? Seems to work with it on or off. Will report tomorrow night if there are any issues.
SteveL is offline   Reply With Quote
Old 01-09-2010, 01:21 PM   #10354
Team Tekin
Randy_Pike's Avatar
Switch on: Voltage cutoff will work
Switch off: no voltage cut off
Old 01-09-2010, 03:48 PM   #10355
LOW ET's Avatar
Trader Rating: 97 (100%+)
does the timing advance on the dual mode screen have anything to do with the sensored mode settings? if i turn it all the way down/up, it will not affect anything when in sensored mode?
LOW ET is offline   Reply With Quote
Old 01-09-2010, 03:53 PM   #10356
TrevCoult's Avatar
It will have no effect on sensored mode at all.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 01-09-2010, 03:56 PM   #10357
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no once you click sensored it goes away,only the current limiter works on both
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-09-2010, 03:58 PM   #10358
LOW ET's Avatar
ok, that's the exact reason i was asking
Old 01-09-2010, 04:12 PM   #10359
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The only connection between the timing advance slider in dual mode and how the car functions in sensored only mode is what happens if the sensor wire becomes unplugged during operation. The esc switches to dual mode when the sensors are not read, which I believe means it runs with whatever settings you have selected in dual mode. IE if your running a race in sensored mode and somehow the sensor wire gets unplugged, the car will still run, just in dual mode with a constant amount of timing; the amount selected in the dual mode screen. I have heard of some using this as a fail safe of sorts. They set a significant amount of advance in dual mode, then switch over to sensored only to make their adjustments. This way, even if the sensor wire fails, they will still be able to finish the race with some speed.
Someone please correct me if I am wrong.
Old 01-09-2010, 04:30 PM   #10360
20 SMOKE's Avatar
good point,completely forgot the feature of the rs
Jamie W
Old 01-09-2010, 04:45 PM   #10361
Moderator
Clegg's Avatar
Yeh that booster above works fine as long as you wire it to take power off the battery leads instead of the ESC BEC wire like it wants to.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-09-2010, 07:50 PM   #10362
I've reset the esc to factory defaults and recalibrated with my radio.Is there any way I can fix this without resorting to hotwire? I've tried to install it on my computer but didn't have any luck.
TE=mikky32;6826671]Put it back on your hotwire. There are on the rigt site 4 small white boxes that you can chose. One of them is sensord mode. Check that one and you see also that the 2 most right bars chaghe to timing boost and turbo boost.
I think that it's best to reset the speedo furst, than recalibrate with your redio and after that connect it to the hotwire and set it into sensort mode and set your settings.[/QUOTE]
outlandr91 is offline   Reply With Quote
Old 01-09-2010, 07:55 PM   #10363
20 SMOKE's Avatar
first what version do you have in the esc
Jamie W
Old 01-09-2010, 08:15 PM   #10364
Con
Realy???I didn't know that. So if you set the current limiter in Dual mode it also works in sensored mode??
Con is offline   Reply With Quote
Old 01-09-2010, 08:24 PM   #10365
Team Tekin
Randy_Pike's Avatar
Yes,
We simply ran out of room on the interface to keep current limiter up. So if you set the limiter in dula mode IT WILL carry over to sensored only mode.
We felt this was fair since if you're looking at a sensored only mode you're looking for power anyhow! LOL
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
