Old 01-09-2010, 07:37 AM   #10336
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by lochness42 View Post
Question that is not about speedo. How to gear Redline 6.5T with lipo in TC for indoor race (for ETS)? Any suggestions about fdr? Thank you very much.
i would be some where around a 10-11fdr that's where i was in offroad so it should get you in the right direction
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-09-2010, 07:37 AM   #10337
Can you drive now in sensord mode with a 6,5T motor?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-09-2010, 07:39 AM   #10338
Trader Rating: 23 (100%+)
Originally Posted by MaxSp97 View Post
Here is the specs. of the booster and both are made by the same company.
  • Operating Voltage : 2.7V - 4.2V
  • Operating Current : 1A
  • Max operating Current : 1.5A
Thanks but I am more concerned about how it gets wired in. I have seen that the TQ booster gets wired off the + battery post of the esc and plugs in to the bat/aux slot of the receiver and the esc goes straight to the receiver. This one is in line with the esc power lead to the rx. Anyone know for sure?
SteveL is offline   Reply With Quote
Old 01-09-2010, 07:54 AM   #10339
fire929's Avatar
Default Can anyone help
Does anyone know how to set the endbell timing to 0 on a redline 13.5 BL mtr. What are the settings I remember someone saying that endbell marks let's say 15deg = 0 or 10deg but the numbers weren't dead on.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 01-09-2010, 07:56 AM   #10340
10 days out from v203 D-Day. We've added 75 pages to this thread. Crazy stuff man! Thanks Tekin!
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-09-2010, 07:56 AM   #10341
Turn the endbell as you look ad the back clock wise till you cant turn further. Than it's on 0.
The other way is 24 and the middle is 12.
From the factory it's standard timed on 12.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-09-2010, 08:26 AM   #10342
Trader Rating: 20 (100%+)
Originally Posted by LOW ET View Post
keep in mind the lrp motors like to run around 200*. that's where they are the fastest.
I did not know that. I love learning new stuff. Thanks everyone.
storytyme is offline   Reply With Quote
Old 01-09-2010, 09:11 AM   #10343
Be care full not every motor can handle to much temp. The LRP can handle a lot of temp before it brakes down. The GM about 10C lower and the Speedpassion even lower.
Best is keep the motor ad max 180F
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-09-2010, 10:11 AM   #10344
Krio's Avatar
Trader Rating: 150 (99%+)
You have always been able to run sensored mode with any mod motor. The only thing you have to worry about is that sensored mode is not as efficient and runs a little warmer. If you're temps are fine run whatever mode you want.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-09-2010, 10:16 AM   #10345
Ok but I was thinking now with the timing not coming at once that you can use it now better than before.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-09-2010, 10:43 AM   #10346
cheehtae's Avatar
Trader Rating: 15 (100%+)
Forgot to thank you mikky32.anyways, Thank you.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-09-2010, 10:47 AM   #10347
What did I do that you thank me?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-09-2010, 11:03 AM   #10348
Krio's Avatar
Yes, it is now easier to run sensored only for sure. I have always run sensored only with my 6.5 and with 198 and 200 ran 5 degrees on the motor and 5 to 10 boost depending on the track. With 203 I tried 0 motor and 20 to 30 boost with end rpms towards the upper limit (30,000?) and it worked great. Uber smooth response with more pull than v200.
www.kriostasis.com
Old 01-09-2010, 11:32 AM   #10349
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by SteveL View Post
Need some help with using a booster with my RS in 1/12 scale as I toasted my receiver pack and can't get another 6v one until next week. I have a booster that I got from a racer at our track that he said did not work with his RS, but after plugging the power lead from the esc in to it and then plugging the booster in to the receiver, everything seems to power up normally. Get the normal beeps and lights. Throttle works as normal and seems to get full speed as it did with the receiver pack. I ran this without any issues with a KO esc for a few weeks wired this way.
The booster does not have a brand name on it and there is no switch. Just a female plug on one end to go to the receier and three pins that go in to the power lead. I really don't want to fry anything but would love to race Sunday if at all possible. Am I safe running it?
And before anyone asks, I can't use a lipo rx pack as I'm running an older JRZ3550 that does not like anything over 7 volts. The booster looks a lot like these but does not have a label on it. It does have black shrink like the first pic.
Steve this booster is not going to work well because it's not grabbing power directly from the battery. Rather it's taking the BEC voltage from the speedo and trying to boost that up. This is defeating the purpose. A good booster will grab power directly from the 1s battery pack.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-09-2010, 12:07 PM   #10350
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've used this booster up to Vegas version 200, and will try 203 on Sunday. The booster will work if you install a lead off either the ESC (+)(-) post or to the connector to the battery. Plug the booster into the lead and then into the esc. Don't need to turn on the RS and your good to go. I've run one of these for over a year at this point. Just remember to plug the power in correctly and into the "Battery" slot in the receiver.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
