Old 01-08-2010, 09:06 PM   #10321
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
don't worry about turbo for now
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-08-2010, 09:32 PM   #10322
mikel33's Avatar
Trader Rating: 2 (75%+)
Default 1S troubles
I'm having a great deal of trouble getting my 1s/13.5 (using an rx pack) to run for wgt, v203. speedo is brand new out of the box. Motor won't turn or cogs no matter what I do. I've tried no timing on motor and esc and every combination of on/off switch and 1s / non 1s setting I can find. I took the motor apart nothing's crossed up and it works fine with an spx. Tried 3 different sensor wires. The only think I have left to try is wire diameter. Using smaller wire that worked with spx. I'm at a complete loss, any ideas would be appreciated.
Also, any starting set-ups for a tc w/ redline 17.5 on v200? Fairly large carpet track.
thanks in advance.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 01-08-2010, 10:02 PM   #10323
Magnet Top's Avatar
Just throwing an idea or two out there, Have you tried to reflash it with a previous version ( 198 or 200 ) . Also, does the speedo make the beeping noise it is supposed to make or is it virtually silent ? Is the RX pack connected properly , I know some speedo's require a different wiring scheme for a booster / RX pack ( but I don't know the specifics. ) Maybe try the speedo with a 2S battery ( with 1S unchecked obviously ) just to ensure it is functioning properly.
thanks in advance.
Magnet Top is offline   Reply With Quote
Old 01-08-2010, 10:22 PM   #10324
cheehtae's Avatar
Trader Rating: 15 (100%+)
I love this speedo, I was running 21.5 and it was side by side with a 17.5. My temp was 110 amd it was balzing fast. Max out my timing and turbo is only 16, starting RPM is 2000ish and ending in 7000ish. We have a short track and it was very well suited for it.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-08-2010, 10:55 PM   #10325
Trader Rating: 23 (100%+)
Need some help with using a booster with my RS in 1/12 scale as I toasted my receiver pack and can't get another 6v one until next week. I have a booster that I got from a racer at our track that he said did not work with his RS, but after plugging the power lead from the esc in to it and then plugging the booster in to the receiver, everything seems to power up normally. Get the normal beeps and lights. Throttle works as normal and seems to get full speed as it did with the receiver pack. I ran this without any issues with a KO esc for a few weeks wired this way.
The booster does not have a brand name on it and there is no switch. Just a female plug on one end to go to the receier and three pins that go in to the power lead. I really don't want to fry anything but would love to race Sunday if at all possible. Am I safe running it?
And before anyone asks, I can't use a lipo rx pack as I'm running an older JRZ3550 that does not like anything over 7 volts. The booster looks a lot like these but does not have a label on it. It does have black shrink like the first pic.
SteveL is offline   Reply With Quote
Old 01-09-2010, 01:20 AM   #10326
MaxSp97's Avatar
Here is the specs. of the booster and both are made by the same company.
  • Operating Voltage : 2.7V - 4.2V
  • Operating Current : 1A
  • Max operating Current : 1.5A
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 01-09-2010, 02:31 AM   #10327
HarryLeach's Avatar
Send a message via AIM to HarryLeach
thanks in advance.
A fellow racer had a very similar issue with is 1/12 that I helped him sort out. He was running 4 cell 10.5. The motor acted like it was cogging badly, tried different sensor wires, sensor check was showing all 3 sensors on all the time.
We rolled back to v200, everything acted normally, with the previous speed it had.
Updated again to v203 and everything is good now.
Definitely try rolling back to an earlier version for testing, if it acts normally then, then push back to 203 and try again.
Not sure what caused it, but reflashing seemed to do the trick.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-09-2010, 04:21 AM   #10328
LOW ET's Avatar
Trader Rating: 97 (100%+)
Originally Posted by storytyme View Post
This software is pretty neat with all the adjustments that you can do. I am a rookie to the touring car scene and I went out and played with the new software today. I had some heat issues and wanted any suggestions that anyone has. This is what I was running:
Ran for 4-5 minutes. Very fast and then very hot - 191 degrees!
keep in mind the lrp motors like to run around 200*. that's where they are the fastest.
LOW ET is offline   Reply With Quote
Old 01-09-2010, 06:33 AM   #10329
I hope it's in F and that it's about the X12.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-09-2010, 06:52 AM   #10330
lochness42's Avatar
Question that is not about speedo. How to gear Redline 6.5T with lipo in TC for indoor race (for ETS)? Any suggestions about fdr? Thank you very much.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-09-2010, 06:57 AM   #10331
Senna Racing's Avatar
I was under the impresion all lrps like the higher temps
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-09-2010, 07:08 AM   #10332
I drive mine on 110C but it was not good. The power went down.
Around the 80C it worked better with a max of 90C was working but I had the feeling that the 80 to 85C was better.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-09-2010, 07:18 AM   #10333
Ya I have been told that 90c is opp.
But the post previous was talk F. For sure
Old 01-09-2010, 07:26 AM   #10334
LOW ET's Avatar
yes 200* fahrenheit
Old 01-09-2010, 07:35 AM   #10335
LRP can handle a high temp. Most motors can't handle that.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
