Old 01-08-2010, 06:10 PM   #10306
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by wingracer View Post
I wouldn't say this new version isn't better on a short track. The testing I did Monday with a friends 1/12th scale on a small track with the new version gave more infield rip then I have ever seen in a brushless car. Well set-up Tekins have always had great top end but the advantage with his car was the speed in the infield. It felt like an old brushed mod car. Despite the chassis being a bit off, I was running TQ times with his car. I'm dropping a nearly identical speedo/motor set-up in my car right now and have high hopes for a victory this weekend.
care to share how you set it up to rip on the small track, and how short a track was it? thanks bro...
tommy
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-08-2010, 06:15 PM   #10307
wingracer's Avatar
Trader Rating: 24 (100%+)
tommy
Unfortunately my buddy Ricky was in charge of esc set-up. He got it from someone that posted it in here though. I'll be racing tomorrow so I'll try to write everything down and post something on it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-08-2010, 06:25 PM   #10308
yea that would be cool, also whats the size of the small track, i have a local small track where i can do some practicing so id be real interested with what you come up with...thanx again man..track im talking about has a decent infield with a straight of maybe 48 feet,or less
tommy
Old 01-08-2010, 06:36 PM   #10309
wingracer's Avatar
I'm not sure of the dimensions but if you have ever been to The Track in MD, it's maybe just a bit more than half that size.
Team Shepherd USA
Old 01-08-2010, 07:07 PM   #10310
Hey guys, I'm having a small problem with my new RS. After I calibrated it and set it up for lipo and brushless I applied a little throttle, the motor didn't seem like it was moving very fast so I applied full throttle and it still didn't seem to go fast. I know you're not supposed to pull full throttle with a brushless in a no load situation but the motor wasn't moving that fast so there was no damage. I have a duo I, the timing is set in the middle hole. The led lights are moving in sequence as I pull the trigger. T he current limiter is set at 13, the motor is running in the right direction and I've calibrated it twice. Any help would be appreciated.
outlandr91 is offline   Reply With Quote
Old 01-08-2010, 07:13 PM   #10311
MaxSp97's Avatar
Current Limiter (OFF).
Are you using Hotwire?
Post the setting everyone here will help you out.
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 01-08-2010, 07:23 PM   #10312
Did you reset your speedo after updating it to the V203?
Recalibrate after it and set it in sensord mode?
What is your current setup?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-08-2010, 07:27 PM   #10313
LOW ET's Avatar
Trader Rating: 97 (100%+)
i'm guessing the current limiter is only able to be set with the quick setup buttons and not with hot wire? when using hot wire is the current limiter automatically turned off?
LOW ET is offline   Reply With Quote
Old 01-08-2010, 07:32 PM   #10314
Whit the buttons set. Did you set it ad 6 or 7?
That are custom settings and not there yet.
Set it ad max on 5.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-08-2010, 07:53 PM   #10315
Thanks for the fast responses! I haven't really got a complete setup
DB @1
BS @ 1
LM @ 13
NW @ 5
TP @ 5
MT @ 1
VC @ 2
I haven't used my hotwire or downloaded v 203
Something that Mikky32 wrote has me thinking. He mentioned setting it to sensored mode, how is that done?
Another thing I noticed is that after I turn the esc on it chimes, flashes the led lights and then the # 4 led turns on. Is that normal?
Old 01-08-2010, 08:09 PM   #10316
DB @1
BS @ 1
LM @ 13
NW @ 5
TP @ 5
MT @ 1
VC @ 2
Put it back on your hotwire. There are on the rigt site 4 small white boxes that you can chose. One of them is sensord mode. Check that one and you see also that the 2 most right bars chaghe to timing boost and turbo boost.
I think that it's best to reset the speedo furst, than recalibrate with your redio and after that connect it to the hotwire and set it into sensort mode and set your settings.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-08-2010, 08:18 PM   #10317
Trader Rating: 20 (100%+)
Default a little help
This software is pretty neat with all the adjustments that you can do. I am a rookie to the touring car scene and I went out and played with the new software today. I had some heat issues and wanted any suggestions that anyone has. This is what I was running:
motor: LRP vector X11 17.5
car: TC5R
battery: ProTek 2 cell 5000 mah 35C
track: indoor carpet
drag brake: 20
brake: 100
neutral: 10
throttle profile: 5
push: OFF
timing boost: 50
turbo boost: 10
delay: 0.2
end RPM: 7001
start RPM: 2437
turbo ramp: 3.0
FDR: 6.0
Ran for 4-5 minutes. Very fast and then very hot - 191 degrees!
My thoughts were to do the following or a combination there of:
up the end RPM,
gear for an FDR of 6.5-7.0,
lower timing to 45ish and
possibly drop turbo.
These are all some what guesses as what to do. Just hoping someone could give me anymore ideas or verify that my guesses are correct. Thanks in advance.
storytyme is offline   Reply With Quote
Old 01-08-2010, 08:21 PM   #10318
wingracer's Avatar
up the end RPM,
Also, increasing the delay could help.
Team Shepherd USA
Old 01-08-2010, 08:22 PM   #10319
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what size track,
on a small carpet raise the delay and try turbo down to 5,if it still gets hot raise the spur a couple teeth.
the x11 is set at 12 deg,lower the timing boost 43-45
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-08-2010, 08:53 PM   #10320
Not sure the dimensions of the track, maybe 60-70 feet on the straightaway. Thanks for the fact of the 12 degree timing on X11. That was something I wanted to know, but never could find out.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
