Old 01-08-2010, 01:43 PM   #10291
Company Representative
SweepRacingUSA's Avatar
Originally Posted by marcel p View Post
great idea
the in and out servo plug bugs me also great time
is it posible to do it with a y servo cable?
yes a Y connector works.
I dont like that mini USB idea, it will put more weight and foot print to it. just having a piece of tape on the plug works for me.
SweepRacingUSA is offline   Reply With Quote
Old 01-08-2010, 01:49 PM   #10292
oze
Are you sure about the Y connector? I think leaving the receiver connected will create a problem.
I tried the tape. Did not work because it made the plug thicker and therefore it was even more hard to pull out. Actually it was so hard that the tape itself teared.
oze is offline   Reply With Quote
Old 01-08-2010, 01:55 PM   #10293
Me software for a Blackberry would be nice with "camera style" usb. Talk about dialing in while running and not going back to the pits. That would be sweet. That's just me.
Isaac is offline   Reply With Quote
Old 01-08-2010, 02:10 PM   #10294
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the Y conector was talked about months ago and it powers the esc so there is a problem. but a plug like the sensor plug would be great
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-08-2010, 02:11 PM   #10295
yes few ppl tried a Y conn no problem, I run a Novak XXtra RX having no problem with a tape, maybe you can enlarge your Rx slot little bit?
I don't remeber reading that, I must missed that. it may turn RX on...hmmm
Old 01-08-2010, 02:18 PM   #10296
The minii usb does not need to be in the esc so the footprint will remain the same, it just needs to be incorperated into the on switch as in the pic above.
Toolmannz2 is offline   Reply With Quote
Old 01-08-2010, 02:25 PM   #10297
great idea
I think that somewhere Tekin advised not to do this as there could be a problem sending signals via the receiver.
Put a plug with a socket into the receiver, then plug the speedo into the socket. Solves all the problems! HTH
SlowerOne is offline   Reply With Quote
Old 01-08-2010, 02:28 PM   #10298
Sorry this is not a mini usb but is still better than unplugging the receiver plug all the time, and more accesible
Old 01-08-2010, 02:39 PM   #10299
MikeXray's Avatar
Trader Rating: 73 (100%+)
Seriously people? be happy you don't have a lathe and 50 brushes in your box, but unplugging one wire is too much work?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-08-2010, 02:50 PM   #10300
Dragula426's Avatar
I certainly am, and the amount of tunibility for track conditions makes these a real welcome to those of us that have to push the envelope for every last 1/10s per lap. If you can anticipate the track conditions between rounds, you can leave the car set-up as is, and just tweek the esc a little. I like the adjustability, and once you get used to it, its one of those learned things about racing that will stick with you and grow with you as the needs of the sport evolve. Use it if you feel comfortable with it, switch back to v200 if your not.
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 01-08-2010, 03:32 PM   #10301
mike ivy's Avatar
Trader Rating: 50 (100%+)
Man... if only they can make it hook up to a iPhone or iTouch that would be bad ass!!!
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-08-2010, 03:34 PM   #10302
Tim Stamper's Avatar
^ Win 100%
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 01-08-2010, 03:38 PM   #10303
Trader Rating: 114 (100%+)
+1
Chris Furman is offline   Reply With Quote
Old 01-08-2010, 04:36 PM   #10304
MarkBrown's Avatar
Using the receiver wire for programming works fine and is good engineering. Putting another socket on the device would add weight and add yet another mounting constraint (if the socket is on the switch, say, then you must mount the switch in an orientation that makes the socket accessible). It would be nice for the receiver connector to come with a strain relief, but adding one isn't hard (see for instance Section 4 of http://rcfaq.weebly.com/tekin-rs--hotwire.html ).
MarkBrown is offline   Reply With Quote
Old 01-08-2010, 05:01 PM   #10305
What I hope is, is that you can change the profiles to what you want and save them also on your pc and send them around.
And that you can download team driver setups. that will be great.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
