Old 01-07-2010, 03:03 PM   #10231
Send a message via AIM to A-Ko
Originally Posted by or8ital View Post
I would love to see Tekin get rid of the turbo boost / delay. I think a better approach would be a multi-part timing curve where you set RPM ranges, amount of timing advance in that range and ramp rate for that range.
Or better yet complete dynamic timing. Not sure if dynamic timing is possible but it would be cool if the ESC could determine the load and set the optimal timing on the fly.
I don't know if they would really need ranges. If going back to the car example it could be interesting to look at it like a gearbox. Depending on your track and vehicle you could have 1, 2, 3, 4 or maybe even 5 speeds (RPM points) then have various things that can be set at those points like timing, boost, turbo for last setting, ramp and drag brakes. Although it might be helpful to have a radio in sync to those points with some sort of feedback to your finger.
I don't know if dynamic timing would work well. I keep seeing it picking a wrong value to slow you down in a race.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 01-07-2010, 03:39 PM   #10232
Im pretty sure the GM range of speed controllers, use a RPM point to when the timing ramps up....so no waiting for the madness to happen!
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 01-07-2010, 04:20 PM   #10233
Originally Posted by VRacing View Post
The last few pages have shown that many of us are coming to the same conclusions.
I run on a short track (1s 1/12 17.5 Redline) 50x25 with a sweeper entering the full length straight (Very slow chicane prior to the sweeper, motor is probably under 1000rpm). There is "room" to be on WOT for around 60' before getting off the throttle for a 180* turn. With Timing Boost @50 (1425 start & 6000 end) I had Turbo set on ramp 3 and 0.7 delay initially. I couldn't feel the Turbo kick in and got a temp of just under 160* ( I was bogging down the motor with the Turbo). I moved the delay out to 0.8 and could obviously feel/hear/see the Turbo "hit" and the temp went down to 132*. Problem is, the Turbo was "hitting" just as I was getting off the throttle for the 180* corner and it ended up pushing me out and off my desired line more than it helped me in any way. I had to feather the throttle to "reset" my delay, in order to keep my line tight.
My thought is that with Timing Boost available up to 60, there is no way a 1s 17.5 car can "use" 50* + of timing advance in less than 65' (obviously dependent on gearing and track layout). When you run on a larger layout that may be helpful information. A delay of 0.8 will "hit" the Turbo at around 60' with a Timing Boost of 50 and a Rollout of 76.00mm
On my small track, I will be running NO Turbo and it works great. I'm only able to use a little more (5*) total timing than with v200 but I have better Low and Midrange throttle response, which helps with passing and general driveability! My fast lap with v200 was 6.925sec and with v203 was 6.889.
The though thing to admit is that "extra power" does you no good if you pile into to boards - all is lost. The truth about most of us club drivers is that on a big layout, we can probably use Turbo and have a larger grin between accidents. On a small layout, there is not a huge difference from a well tuned v200 car, just a little more responsiveness. That alone is a good thing for those rare occassions when we get a solid "clean" run.
Aaron
Great write up i must say
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 01-07-2010, 04:22 PM   #10234
Yes the only difference they have now is, is that the car starts in sensorles mode instead of sensord.
I'm glad that Tekin didn't do that. I have seen several guys wasting there qualifying spot in the finals because of the start.
The car had some starting problems when the soft start wasn't set right.
GM uses not as much timing as the Tekin.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-07-2010, 04:46 PM   #10235
reenmachine's Avatar
Trader Rating: 26 (100%+)
There's a bit of confusion here due to the fact that many commonly refer to Team Associated as AE (for Associated Electrics). I'm fairly certain that King of B Main was referring to Team Associated drivers, who would have been running the SXX Stock Spec.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-07-2010, 05:08 PM   #10236
LOW ET's Avatar
Trader Rating: 97 (100%+)
can someone tell me if this setup will be ok to start with,
90X40 carpet track
13.5 rubber touring
lrp x12 13.5 motor (2 dot stock timing insert)
drag brake 20
brake strength 100
timing 30
start roughly 2500
end roughly 7000
LOW ET is offline   Reply With Quote
Old 01-07-2010, 05:27 PM   #10237
the setup looks good.
Set the brake strength lower. The brakes with the v203 are very good. I use now 70 brake.
The boost i would set a bit higer for some more top speed. 45 to 50. As you do so, set your end RPM also higher. Around the 13000. Start rpm a bit higher. 3000-4000.
Gear a bit lighter than you did with the v200 and temp after a mint or 2. As the motor stays cool, you can gear a bit heavier.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-07-2010, 05:29 PM   #10238
LOW ET's Avatar
i was understanding the x12's don't like timing that high?
would i need to stretch the rpm out to 13,000 for a 90 foot straight?
Old 01-07-2010, 05:35 PM   #10239
as you set your top rpm higher you spreat the timing and the motor can handle more timing.
Set your rpm range big and temp the motor after each run anc as the motor stays cool ad some boost.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-07-2010, 05:35 PM   #10240
tandman's Avatar
Send a message via Yahoo to tandman
Hey guys, just trying to figure out what I need for touring car stock rubber tire. To run the latest software with all the boost and ramp up with the timing ranges, will the Tekin RS work or do I need the RS-Pro? Will there be a differnece between the 2 or is the pro just better for mod?
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 01-07-2010, 05:45 PM   #10241
The RS is good for tc stock. No problem with the V203.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-07-2010, 05:50 PM   #10242
Skiddins's Avatar
I still find the brakes to be a bit of a problem once the timing has ramped up a bit, and non-existant once the turbo has come in.
On small carpet tracks this isn't really an issue as the speed never gets high enough to warrant very hard braking or turbo.
I race on a track that would appear to be a bit bigger than the Speedworld track that Randy has mentioned.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-07-2010, 05:55 PM   #10243
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what motor skidd
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-07-2010, 06:10 PM   #10244
i used the turbo ad his max and my brakes worked a lot better than before but it was on a carpet track so i don't now as it is on higher speeds.
Nice track.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-07-2010, 06:42 PM   #10245
LOW ET's Avatar
i just made some adjustments according to your input and the motor is like a BEAST now
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
