Old 01-05-2010, 11:55 PM   #10126
syndr0me's Avatar
Trader Rating: 32 (100%+)
Oh yeah, range was about 4000 - 10000
syndr0me is offline   Reply With Quote
Old 01-05-2010, 11:58 PM   #10127
Sigearhead's Avatar
Trader Rating: 68 (100%+)
MarkBrown:
I was reading your document and I have a question regarding motor timing. I am running a duo2. When you say to set up timing at zero degrees does that mean that I need to be about 3 notches from fully advanced on the duo2 to achieve true zero timing on that particular motor?
Also on the Novak SS series if you turn the tab all the way clockwise am I at zero? If I didn't mark the factory setting I just won't truly know the amount of timing I have?
Thanks in advance
Sigearhead is offline   Reply With Quote
Old 01-06-2010, 12:14 AM   #10128
Send a message via AIM to A-Ko
thanks for the docs
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 01-06-2010, 12:15 AM   #10129
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by syndr0me View Post
Now that I've run a Tekin with turbo and see how insane it is on the straights, it makes sense why my car 17.5 car was so damn slow in Vegas! I tried so many different combinations trying to get that SPv3 to not be a dog.
I ran the software tonight in 13.5. Track is about 96x42 (pic attached). It's definitely got the power in the middle I felt like the Tekin always lacked, which is a welcome change, and the turbo on the straights is no joke, it makes timing the sweeper a challenge. If there's more power to put down in the infield (in a sedan), I wasn't finding many places to do it. The motor rips hard like other ESC's out of the turns, but nothing that seemed any stronger than the SPX it replaced. On the straights, though, no question it's superior.
I actually found myself geared really high (near a 5.0) with a 13.5 DUO2 (timing 1 mark past center). Boost was 50, turbo 10/.2/ramp 2. The motor came off cool, like 135ish after 6 minutes w/fan. The same motor on the SPX (timing 2 marks past center) on profile 7 was happy around 6.5FDR, felt about as strong in the infield, came off around 165 w/fan, but had nothing on the Tekin on the straights.
Maybe I'd see more advantage in the infield with 17.5 or 1S pan cars? Not saying it's not great, just didn't feel like it was quite the game changer I'd hoped for. Either way, this is definitely my ESC of choice now.
We almost have the same setup except for your gearing and rpm ranges. I'm geared at 7.04. Ranges are 2500 - 12000 using throttle profile 4. Car has tons of infield speed.
I don't run turbo. No need to. Car keeps on pulling on the straights.
I noticed on DUO2s. It likes motor timing....
bukil is offline   Reply With Quote
Old 01-06-2010, 01:28 AM   #10130
lochness42's Avatar
Originally Posted by mikky32 View Post
What was your setup with the v3 motor? I now it must be geared quit heavy. It's than a lot faster than geared light.
Boost on 10 is working good with the v200.
I'm going to race the last ETS from this series.
Well I only ran 13.5T v3 on 3 races and all of them were with SPX. I was geared about 5fdr.
I will be only at Czech round of ETS.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-06-2010, 03:33 AM   #10131
do you have a starting point for fdr. with the 13.5 v3 and v203 software, i will go to the ets czech race aswell but dont have a motor to practice with
martin
MartinBasse is offline   Reply With Quote
Old 01-06-2010, 04:22 AM   #10132
lochness42's Avatar
martin
Well I have club race next week so I'll try new software. At this point only thing I knew was FDR usable with SPX.
It's great to know that someone else with Tekin will be there as well - will make setup testing easier. Definitely come to me at race
BTW I didn't manage to find you in entry list.
Pavel Balint
Old 01-06-2010, 05:05 AM   #10133
thats because i have intered today so i should be there now my last name is Laursen.
Old 01-06-2010, 06:02 AM   #10134
hanulec's Avatar
Trader Rating: 27 (100%+)
I guess we had a classical tekin vs lrp battle at Vegas...
I actually like that speed passion motor. it takes a ton of gear to get it moving --- but takes it w/o overheating. the lower my fdr got the faster it went. I settled on a 4.4 fdr but tried as high as 6.0.
I think your a little over geared w/ a 5.0 fdr / 13.5 duo / tekin v203. I'd recommend starting at w 7.0 fdr. you can get the car to jump out of the corners with a higher fdr and use turbo to make speed on the straight. with the v199/200 software a 6.2-6.6 fdr was really good.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-06-2010, 08:03 AM   #10135
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Originally Posted by grippgoat View Post
If you set the turbo delay to 0, though, you'd only have the ramp time to wait through. So balancing the ramp for normal corner exits versus standing starts and mistake recovery would be a bit of an issue, but maybe less of an issue than the version 200 turbo delay tuning. With version 200, if you made a mistake (I still make lots of them), or you have to lift off because of traffic coming onto the straight or something, it screws up the timer, and your turbo doesn't kick in.
I'd still think having RPM-based timing and RPM-based turbo would make the most sense, though.
-Mike
Interesting concept, but I'd rather have more control over timing curves in the midrange RPM range instead of the RPM at the end. Using turbo to ramp the timing first gives you three preset curves, and REQUIRES using full throttle to advance the timing. If you run on a track requiring any finesse through the turns, this idea wouldn't work very well since you might be left without any timing boost when you need it.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-06-2010, 08:31 AM   #10136
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
[email protected] DOCUMENT, THat should clear up alot of usuable space in forum,providing people read it first, and if nessesary ask q's later. Good job, and thankyou!!
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-06-2010, 09:08 AM   #10137
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
+1! A very useful tool for helping to educate users.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 01-06-2010, 09:35 AM   #10138
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Motor Timing: Launch
Motor timing is an absolute. Its effective throughout the entire range of the cars speed. This is the adjustment that should be made for the first few feet of car travel.
Timing Boost: Acceleration
The ideal start/end rpm for boost will depend on the platform/chassis being used along with track size and motor wind. The size of the range will also affect how the car pulls. A narrow rpm range will effectively produce a faster rate of boost vs. a wide range will have a slower rate of boost:
1000rpm start / 6000 end with 50 timing boost will provide 10 degrees of boost per 1000 rpm vs.
1000rpm start / 11000 end with 50 timing boost will provide 5 degrees of boost per 1000 rpm.
Spec Motors:
So far pan cars are using between 1,000 and 7,000 on most tracks. This is due to not having a gearbox and being direct drive.
TCs are showing a useable range of 2,000 to 13,000 on most tracks. This is due to having a reduction gear box.
Turbo Timing: Top speed
Turbo Delay: This is the time that must expire at wide open throttle to engage turbo. This is NOT dependant on RPMs in any way. Ideally this should be NO lower than .2 and in all likelyhood will be set at .4 or more. Tracks that have straights less than 80ft will likely NOT need turbo.
Turbo Ramp Rate: This is the literal ramp rate of whatever your turbo timing is set. So:
A turbo setting of 20 will give you the following reaction:
1.0 Ramp rate = 20 degrees in 1 second applied
2.0 Ramp rate = 20 degrees in .5 seconds applied
3.0 Ramp rate = 20 degrees in .30 seconds applied
So if you run timing it will just change the total applied, not the speed at which its applied.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-06-2010, 09:43 AM   #10139
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Randy... can you explain why "total timing" is no longer recommended to be at most 30? You can now set it to 40 or 50? Is it simply because you can set more boost with a LONGER delay, keeping temps down... where as before it would be too much too quickly?
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-06-2010, 09:50 AM   #10140
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Cpt.
Excellent question!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
