Old 01-05-2010, 12:20 PM   #10066
Originally Posted by theisgroup View Post
it's banned at the novak for 17.5 sportsman class
What are the chances the Kinetic will "become available" at the same time?
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-05-2010, 12:20 PM   #10067
mkdut's Avatar
Trader Rating: 19 (100%+)
Does anyone have a baseline setup for a WGT running a 13.5 Duo or Nemesis? Couldn't find one with the search function.
Also how about a baseline for a 12th running a 10.5 Duo? I did see some for other motors but want to see what else is out there.
mkdut is offline   Reply With Quote
Old 01-05-2010, 12:21 PM   #10068
Will the Novak also be banned from the races
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-05-2010, 12:27 PM   #10069
ottoman's Avatar
R/C Tech Charter Subscriber
Banned from the 17.5 touring car and sportsman 17.5 touring car classes.
ottoman is offline   Reply With Quote
Old 01-05-2010, 12:30 PM   #10070
Exactly! If v203 is banned it would make a grand coming out party for the Kinetic. Or, maybe they're just not ready yet and don't want to get smoked by Tekin?
Old 01-05-2010, 12:30 PM   #10071
oze
This is what I will start with in my 1:10 pan car with a 13,5T Orion motor and 2S:
Drag Brake 0
Reverse Strength off
Brake Strength 75
Neutral Width 5
Motor Type BL-FW
Throttle Profile 3
Voltage Cut Off 2
Push Control off
Timing Boost 45
Min RPM 3500
Max RPM 12500
Turbo Boost 10
Turbo Delay 0,8
Turbo Ramp 1
Roll out: 54 mm
I will first set the infield performance of the car by playing with Timing Boost, start and end RPM and gearing. Then I will decrease the turbo delay. This is on a 40 x 20 m fast and flowing track with medium/high grip.
I am sure this is NOT the right setup but good point to start.
With 1:12 10,5T SpeedPassion 1S:
Roll out 64,5
Drag Brake 0
Brake Strength 100
Neutral Width 5
Motor Type BL-FW
Throttle Profile 4
Voltage Cut Off 0
Push Control off
Timing Boost 40
Min RPM 3000
Max RPM 8000
Turbo Boost 10
Turbo Delay 0,8
Turbo Ramp 1
On the same track, and setup will be done on the same concept.
Once again: these are not proven setups, these will be my start points.
oze is offline   Reply With Quote
Old 01-05-2010, 12:35 PM   #10072
RLMW VQ's Avatar
the new software is great but its too fast. i think that 17.5 stock is just gotten to be too fast and needs to be slowed down and thats why its banned at the novak. when a 17.5 can run with a 13.5 down the straight that is just insane. and to be honest about it i ran 203 and the new years day race at trackside and if you didnt have a tekin with the software you where left standing still in the straight and in the infield you could get out of a conner faster that anyone eles if your car was set up to be able to handle the extra power that the software was giving you. but again its just too fast.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 01-05-2010, 12:39 PM   #10073
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Check out oze's 10.5 1/12 1S setup a few posts ago - seems like that would be a conservative starting point for WGT using either of the Epic motors.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-05-2010, 01:04 PM   #10074
mkdut's Avatar
Drag Brake 0
Brake Strength 75
Neutral Width 5
Motor Type BL-FW
Throttle Profile 3
Voltage Cut Off 2
Push Control off
Timing Boost 45
Min RPM 3500
Max RPM 12500
Turbo Boost 10
Turbo Delay 0,8
Turbo Ramp 1
Roll out: 54 mm
Roll out 64,5
Drag Brake 0
Brake Strength 100
Neutral Width 5
Motor Type BL-FW
Throttle Profile 4
Voltage Cut Off 0
Push Control off
Timing Boost 40
Min RPM 3000
Max RPM 8000
Turbo Boost 10
Turbo Delay 0,8
Turbo Ramp 1
Thanks I will give it a try. I will need to adjust the 1:10th setup for 1S which should be matter of setting the Max RPM to an appropriate level. Looks like I will have to drop the rollout down as well for both as the track I am going to is roughly 30 m in length.
Old 01-05-2010, 01:09 PM   #10075
oze
No, you have to increase the roll out both if you want to run with 13,5T with 1S instead of 2S or if you run 13,5T instead of 10,5T.
Old 01-05-2010, 01:32 PM   #10076
mkdut's Avatar
Got it.
Old 01-05-2010, 02:28 PM   #10077
Trader Rating: 16 (94%+)
I wonder if Tekin ever thought people would be saying this with the v203 software release... I bet their first reaction to this kind of statements was like, right, sure, whatever, and then now that more people are saying it's too fast, they are probably a little puzzled.
kn7671 is offline   Reply With Quote
Old 01-05-2010, 02:31 PM   #10078
LOW ET's Avatar
Trader Rating: 97 (100%+)
did anyone find out if the advanced and mamba's are banned from the races also?
LOW ET is online now   Reply With Quote
Old 01-05-2010, 02:43 PM   #10079
Low et
Originally Posted by mikel33 View Post
Correct. In the 17.5 classes and trans am those are out as well. 13.5, 12th and wgt anything goes.
MartinBasse is offline   Reply With Quote
Old 01-05-2010, 02:49 PM   #10080
RLMW VQ's Avatar
the reason i say too fast is because if you look at laps you take a class like 17.5 and brought them up to 13.5 times there needs to be a gap bettween the two.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
