Old 01-05-2010, 07:45 AM   #10051
Default 10.5 set up using 2.03 looking for set up for 17.5
Track carpet 100ft X 40FT (30mt x 12mt)
Fast and flowing.
Motor redline 10.5 timing set too zero rollout 67.2
car a speedmerchant rev5 l
motor redline 10.5 timing at zero
Using these settings on 10.5 also looking for a duo 2 17.5 set up .Would you change any thing ???????
Rollout 88mm ???????
drag 10
brake 100
rev off
neutral 5
bl-fw
throttle 3
push off
timing boost 40
turbo 15
1S lipo
turbo delay 0.4
sensored
end RPM 8500
start RPM 2750
ramp 2
tellan is offline   Reply With Quote
Old 01-05-2010, 08:22 AM   #10052
razzor's Avatar
Having read every post so since the 203 release unlike others, i see a trend.
Most issues seem to be from guys chasing to get the turbo working and ignoring the advice to get the setup good with boost timing and only then using turbo if needed on long tracks or straights.
Another is guys setting there boost with iether too much timing or making it ramp up too fast and in too low a start rpm.
Randy and a few others have given very good base setups that the guys can work from but again a lot of guys are too lazy to read through the thread.
Its one thing to ask a question to benefit all of us but we are getting so many of the same questions repeated.
If guys can take the time to read then this thread wont grow so fast and we will get even better feedback.
sorry for the rant just my 2 cents...
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-05-2010, 08:27 AM   #10053
Originally Posted by 20 SMOKE View Post
with the same gearing you should see it pull more with the 12k,try it and you can see the difference in the rpm range.its hard to explain you have to see it
Originally Posted by oeoeo327 View Post
You should be able to use a lower FDR (gear heavier) using the wider RPM range. Tightenting the RPM settings causes the total amount of timing boost to come in sooner. For example, if you select 30 degrees of timing boost and a 3000-6000 RPM range, you're adding 10 degrees per 1000 RPM while the motor is operating between 3000 and 6000 RPM. If you select 12,000 RPM as the end point and the same 30 degrees of timing boost, you're adding 3.33 degrees per 1000 RPM while the motor is between 3000 and 12,000 RPM.
Ok thanks,
I was starting with only the Boost but I missed a lot of top speed. I think that I was geared to light when I see all the other setups.
I went back to almost the same gearing as with the V200.
Start RPM around the 4000 end RPM around the 17000.
The first few meters were also to slow I think because I was geared to light.
I think the motor doesn't make that much RPM's ad the start to compensate the light gearing.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-05-2010, 08:35 AM   #10054
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Well it has been less than one week and the Vegas 2 software has been prohibited to be run in the 17.5 class at the 2010 USORC and at my local track in the 17.5 class also.
Tekin did too good of a job!
I'm not bitching about these decisions...just commenting on how truly fast the V203 can make you.
And for those that like to run these two classes it'd be great to be able to save profiles.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-05-2010, 08:43 AM   #10055
I think that I can go faster with a 17,5T with 2 cell lipo than a 10,5T 5 cell what we drove last year. Tekin did great.
I think a bit to great to keep the car on the track.
I'm going to ask if I may use a 13,5T motor ad the next race instead the 10,5T motor. And I believe that I can keep up with the others with the Tekin RS Pro
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-05-2010, 10:13 AM   #10056
Mário Ribeiro's Avatar
Send a message via MSN to Mário Ribeiro
Hi there,
I´m considering the aquisition of a new speedo for my Associated B4. I´m currently using a GM Genius 120 with CS 9.5T motor, but i´m moving this combo to my Xray T3.
I have some options... Speed Passion, Tekin RS Pro or another GM.
I´m considering the RS Pro. Besides Tekin motors, what other brand do you recomend ? Can i use a Speed Passion V3 7.5T ?
Thanks.
Viper R/C Solutions | Gens Ace | UMDEZ
http://www.viper-rc.com | http://www.umdez.com | http://www.gensace.com
Mário Ribeiro is offline   Reply With Quote
Old 01-05-2010, 10:16 AM   #10057
oze
I use Tekin RS Pro with Speedpassion 10,5T. Work well together. Altough I have not tried this combo with the new firmware. I am sure they will work well, just have not tried them yet.
oze is offline   Reply With Quote
Old 01-05-2010, 10:36 AM   #10058
The new software can handle all the motors.
You only need to find the right setup but that counts for every speedo.
Why not a Tekin motor? In a off road car it's better than the open motors with all that sand.
I think that You want 2 Tekins when you have field the power. LOL
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-05-2010, 10:41 AM   #10059
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Mário Ribeiro View Post
Hi there,
Thanks.
with a 7.5 that will be in dual mode and you miss the turbo timing boost,if you kep the 9.5 it is bordeline for sensored mode and you get the timing boost and could be faster with this setup
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-05-2010, 10:44 AM   #10060
I'm not enjoying hearing about the trend of banning v203. There are other ESC options available that offer similar types of improvements. The Novak Kinetic will be out soon and will give another option to all racers. I really support my Tekin guys and their products. At the same time, I hope the Kinetic gets out ASAP. That's the only way we can keep things moving forward apparently? Then we can have the head to head battle I trust all the Novak owners are salivating for.
If we're all having to change over to Brushless/LiPo and Software ESC's, why push back the other way right in the middle of the transition? If they're not going to let things develop, why do it in the first place? Tekin set the benchmark so far, no question. Everbody else better get off their @$# if they want a piece.
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-05-2010, 10:55 AM   #10061
Krio's Avatar
Trader Rating: 150 (99%+)
There is no reason you can't run a 7.5 in sensored mode. I run all my motors on sensored only from my 17.5's down to my 6.5 in my b44. There is a vast difference in how you setup a mod motor with sensored only, but I prefer it over dual mode every time I compare the two.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 01-05-2010, 11:12 AM   #10062
20 SMOKE's Avatar
there is a difference in on and offroad
Jamie W
Old 01-05-2010, 11:42 AM   #10063
Trader Rating: 16 (94%+)
I guess I've missed it, but who is talking of Banning the Tekin v203 software?
The earlier issue of talk about the Advanced ESC being distributed by CRC being banned, or not allowed at an event, was that CRC went to a large race event and sprung it on everyone as a secret weapon against the entire field. To add to the issue, it was uavailable for purchase from anywhere or anyone at the time. With Tekin, the Tekin RS and RS Pro have been available for some time now, and the software for this improvement is freely available to anyone.
kn7671 is offline   Reply With Quote
Old 01-05-2010, 11:52 AM   #10064
theisgroup's Avatar
it's banned at the novak for 17.5 sportsman class
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-05-2010, 11:53 AM   #10065
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Ya gotta follow the thread man. You remind me of Donnie in The Big Lebowski.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
