Old 09-08-2008, 08:23 AM   #991
Kenny L's Avatar
Trader Rating: 16 (100%+)
I've got 4 of them 3 pro's one reg ,and I've run every other brushless esc out there wouldn't run anything else but Tekin now. Placed seventh in 13.5 foam at the IIC these esc's are amazing With new updates coming they are only going to get better.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 09-08-2008, 08:52 AM   #992
Default Tekin forum
Hi all,
Does anyone else have big problems registering at Tekin forum? I've been sending emails to tekin but still no response or validated registration.......or they just don't like Dutch....lol
Z
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Old 09-08-2008, 09:11 AM   #993
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by LOSI SCOTT View Post
Hello everyone i am not liking what i am reading about this ESC. I am running novak gtb right now but was going to switch to tekin rs but some of the things i am hearing and reading are scaring me away from tekin! What do you all think?
Not really sure what would scare you away? Out of all the posts in this thread i think you could count on one hand the number of people who've had issues w/ the speedo. I have 4 of them now, 2 pros and 2 non pros. Last time i ran it was the best race in my recent history and i have to attribute it to the speedo because it's the only thing i changed in the car (went from novak to tekin). The thing i like the most is the level of adjustability (when using hotwire), there is nothing even close to it out on the market today.
I've been a novak guy since my first t4 and t1x back in the day, but I'm all tekin now, i've sold or mothballed all my other brands of speedos tekin in everything i drive (i run b1's in my micro, well almost everything i have a sensored micro esc in my mod micro ).
Forgot to mention, when i did the swap even without adjusting for the weight loss on one side of the car i ran 12.4 where my times were normally 13.4 using the gtb, go figure.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-08-2008, 09:13 AM   #994
YmeBP's Avatar
Originally Posted by m3ndo5a View Post
Can anyone state what the parmeters are on the Hotwire ESC timing settings......like what does the numbers represent . min~max......what would be the timing degrees on the speed controller by each click.
Do a search for timing in this thread, there was a post a couple pages back that had the direct map of percent to degrees.
Old 09-08-2008, 09:34 AM   #995
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
correct me Tekin if im wrong:
1%= .3 degrees
2%= .6 degress
every % = .3 degrees of timing
5%= 1.5
10%= 3 degrees
15%= 4.5 degrees
every 5% = 1.5 degrees
every 10%= 3 degrees
Old 09-08-2008, 11:26 AM   #996
It doesn't scare me away. The service is great and a club member has one to and it goes fast.
Also other Tekin products are verry good.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-08-2008, 11:39 AM   #997
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're not getting into the forum it's not becuase we don't like you! LOL
If your email looks suspiscous we won't approve it. Gmail is a killer and we don't like it much.
Shoot me a pm with your forum id and the e-mail that you used.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-08-2008, 01:22 PM   #998
m3ndo5a's Avatar
1%= .3 degrees
2%= .6 degress
5%= 1.5
10%= 3 degrees
15%= 4.5 degrees
Thanks for the post(twice 508), how did you figure this out?
So being 100% = 30* timinig in Sl mode
And from what I understand this is more so adapted to the sensoreless mode
or the sensored only disable, which I found out this morning was the reason I could not launch my car. I check the Box (enable)and now it take off like a bullet.
With it being enable the timing setting(HW) is not effected until the harness come off or broken, which I learn the car better be moving in the event it does happen.
So in the enable mode the ESC is runnning timing from the motor "if there is adjustable timing on the motor " if not it just running whatever lock timing the motor have.
In disable mode it will start off S with the harness and switch to SL which would uses the timing for HW.
I believe I will leave the ESC in enable mode, since it will switch anyway if the harness is effected.
m3ndo5a is offline   Reply With Quote
Old 09-08-2008, 01:36 PM   #999
mo
mo's Avatar
Hey guys. I've posted my RS settings for TC, 4wd offroad and 2wd offroad at http://sites.google.com/site/jmoberl...ekin-rs-setups if anyone is interested.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-08-2008, 02:18 PM   #1000
mutley001's Avatar
Cool, cheers mo.
Don't suppose you have a setup for 10.5 TC do you?
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 09-08-2008, 02:27 PM   #1001
mo
mo's Avatar
Same as 13.5. I run the motors at max timing and I would start with a 5.2:1 ratio with the 10.5 and go from there.
Old 09-09-2008, 08:10 AM   #1002
PM sent.
Old 09-09-2008, 10:38 AM   #1003
mutley001's Avatar
Cheers Mo
ARC R11 2017
ARC R10 2013
Team EAM
Old 09-09-2008, 04:41 PM   #1004
Low_E's Avatar
Send a message via MSN to Low_E
Could someone inform me on the Tekin waranty-rules?
(LRP gives life-time warranty, what does Tekin?)
I've been looking on their site but haven't found it yet.
THX in advance.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 09-09-2008, 04:52 PM   #1005
TRF415boy's Avatar
THX in advance.
Technically LRP doesn't offer lifetime warranty anymore !
"Due to a new leading decision of the Federal Court of Justice saying a lifelong guaranty is no longer permitted - the LRP Limited Lifetime Warranty is from now on converted into a 25 Years Warranty."
That was back in december.
However this is still a long time for a speedo...
Tekin offers a 120 days warranty, which is plenty enough to spot any faulty units. So in fact it's the same as a 25 years warranty as i any case the LRP warrants defective units and not user mistakes...
TRF415boy is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
