Old 01-04-2010, 10:15 PM   #10021
jkirkwood's Avatar
I think many are trying to over think how to set the new version. Set it up using Randy's suggestions and then go the the track and make one change at a time and see what the changes do for you. Use the lap timer as your dyno. The fastest lap times without blowing up your motor is the settings you should use!
MongooseKY, come see me at the track, I'll get you set up. I'm not familiar with your current configuration so I don't want to give you something that might blow your stuff up.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 01-04-2010, 10:17 PM   #10022
Originally Posted by andrewdoherty View Post
When you say didn't work Ruben, could it have anything to do with race length? 6 minutes vs 8 minutes . . .
Andrew ..... when I said the "Novak Booster didn't work" I ment it did not work properly. I could pull the throttle 3-4 times before I would loose throttle. The esc would light all the led's solid and the transponder light would go out. No throttle for a few seconds and then throttle again and the cycle would start over.
schurcr is offline   Reply With Quote
Old 01-04-2010, 10:51 PM   #10023
HB Moose's Avatar
Originally Posted by Cpt.America View Post
I gathered up a couple of quick ballpark numbers for those interested in the duo2 17.5 and 13.5 numbers. Hopefully they help when thinking about boost rpm settings. Where you set it, and how wide you make it, will depend on car/application, tracksize and shape...etc. This is dirty math based on kv rating x voltage. 5 is what is listed, 8 is what i picked for a mostly charged battery... somewhere half way in the middle of your race.
duo2 13.5 = 14,000 rpm @ 5.0v
duo2 13.5 = 22,400 rpm @ 8.0v
2800kv
(edit: but I also found this that shows 17,300 rpms for a 13.5 duo - http://www.rctech.net/forum/attachme...mg_4288-1-.jpg )
duo2 17.5 = 11,000 rpm @ 5.0v
duo2 17.5 = 17,600 rpm @ 8.0v
2200kv
Somebody please correct me if im wrong... but I really want to know what the overall maximum RPM of these motors are so that I can get an accurate picture in my head of where to set my boost RPM settings too.
Im thinking that the rpm settings should be a factor of Kv but those numbers are unloaded. I think I need to make a load flywheel chassis dyno to test gearing vs timing. This new version just gave us more variables to play with.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 01-04-2010, 10:52 PM   #10024
That was already my plan I figured I'd see what the crowd here had to say so we could theorize from there.
mongooseky is offline   Reply With Quote
Old 01-04-2010, 11:30 PM   #10025
Run, Mongooseky, Run like the wind. This place is turning into a Death Spiral. Just follow Randy, he knows the way!!
Did you mean Boost or did you mean Turbo? How does the ramp rate work with Boost? Does the delay start after the end RPM? Round and Round, Round and Round.
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-04-2010, 11:34 PM   #10026
Send a message via AIM to A-Ko
The way this software is quickly changing, it would be nice to have specific details for stock, SS and mod racing and how the profiles can be used to adjust for those specific motors. Not on this thread but on the Tekin site. To go through a ton of pages to weed between accurate and inaccurate information, is not healthy for THIS top of the line ESC.
It is kind of like Dr Frankenstein's monster, you just don't know or understand the direction it will rampage in. Benchmark ranges would be nice.
Sure make one change at a time on the track, assuming we have a local track or ozite rolled out in the basement, I don't. I can explain and justify a day of racing, explaining a day of practice at a track 90 min away.... now that is a difficult story.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 01-05-2010, 12:20 AM   #10027
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Well it appears for 17.5 v203 won't be allowed at the novak race.. Does anyone have a good place to start for 17.5 duo on v200 on what I would assume is close to a 100ft straightaway.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 01-05-2010, 12:28 AM   #10028
Skitee's Avatar
So does that mean the black diamond and mamba max pro won't be allowed either ? Just curious since they both do something similar to what 203 does.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-05-2010, 12:33 AM   #10029
Damnit Man's Avatar
Send a message via MSN to Damnit Man
How would they tech for 203?
Damnit Man is offline   Reply With Quote
Old 01-05-2010, 12:35 AM   #10030
racer x 1's Avatar
Trader Rating: 27 (100%+)
what would be the best 13.5 motor for this esc? im hearing the new lrps are the hott ticket.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-05-2010, 12:49 AM   #10031
Skitee's Avatar
I don't think the X-12 is the best choice for v203, apparently they don't like too much timing advance in the speedo. LRP has told users of the SPX that they shouldn't run the X-12 over profile 6.
I'm guessing the Redline motors or Duo's would still be the better choice to fully exploit the potential of v203
Old 01-05-2010, 12:51 AM   #10032
bukil's Avatar
Trader Rating: 39 (100%+)
Wow.
bukil is offline   Reply With Quote
Old 01-05-2010, 12:51 AM   #10033
Pretty easy to tell when they are 5 car lengths behind you and then 5 car lengths ahead of you by the end of the straight.
redbones is offline   Reply With Quote
Old 01-05-2010, 12:51 AM   #10034
marcel p's Avatar
Send a message via MSN to marcel p
the advance electronics works way diferent.
its nog working with high rpm.s
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 01-05-2010, 12:51 AM   #10035
Damnit Man's Avatar
I am running the Novak Ballistics with pretty good results in 17.5 with 203.
Donovan P.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
