Old 01-04-2010, 08:51 PM   #9991
Originally Posted by SteveL View Post
Why on earth is your track allowing the use of the new software in VTA? This is a spec class with a limited gear "window" to try to keep the cars all about the same speed. Kind of defeats the purpose of the class, don't 'ya think?
maybe they are letting non-RS users run 17.5 because that's how fast the RS can make a 21.5 into
inpuressa is offline   Reply With Quote
Old 01-04-2010, 08:53 PM   #9992
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
here is what i have found to keep up or out power the ae and mamba speedo's in 13.5 rubber tc..
drag 0ff
reverse off
brakes strength 100
neutral 16
motor bl-fw
throttle 5
voltage 2
push 0ff
timing 45
turbo 10
turbo delay .2
start rpm 1508
end rpm 7804
turbo ramp 1.0
sensored mode
track is 80x48 motor temp is 135 deg. after 6 min. of running
gearing was at a 9.02 fdr in a corally phi 09
battery was 5000 40c battery
motor was a duo with timing in middle hole.
send a pm if you need other questions answered... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 01-04-2010, 08:53 PM   #9993
Timmie's Avatar
Wow this thread is moving fast lol Just saw a post about old files. I thought I deleted all of them. I'll try that uninstaller program out..
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 01-04-2010, 08:56 PM   #9994
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Edit: original post updated.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-04-2010, 08:56 PM   #9995
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by theisgroup View Post
guys, not trying to be an ass. I know that this thread is moving real fast, but you need to look back through the thread for answers. if everyone just keeps asking question when the answer is there, this thread will soon become useless.
1. timing boost starts at "start rpm" and ends at "end RPM"
2. turbo boost starts after you hit full throttle for the "delay" length of time
3. ramp only affects turbo.
4. yes timing boost and turbo boost can overlap.
5. yes you can set delay to 0.
all confirmed by Randy and/or Jim in the last 30 or so pages
YES!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-04-2010, 09:01 PM   #9996
Moderator
J.Whiting's Avatar
Originally Posted by HarryLeach View Post
That's nice, but you left out a lot of info, start/end RPM, Turbo delay, Turbo ramp?
Not quite a complete profile without that info.
i know i just edited my post. i hit post early for some dumb reason... jeremy
Old 01-04-2010, 09:03 PM   #9997
theisgroup's Avatar
that's a secret. lol
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-04-2010, 09:04 PM   #9998
drag 0ff
reverse off
brakes strength 100
neutral 16
motor bl-fw
throttle 5
voltage 2
push 0ff
timing 45
turbo 10
turbo delay .2
start rpm 1508
end rpm 7804
turbo ramp 1.0
sensored mode
wow 9.0 fdr?
need like a 105/24 to get that.
Old 01-04-2010, 09:05 PM   #9999
Moderator
J.Whiting's Avatar
Originally Posted by inpuressa View Post
wow 9.0 fdr?
104/23 is what i was running... jeremy
Old 01-04-2010, 09:06 PM   #10000
Trader Rating: 38 (100%+)
...or maybe Tekin could publish clear instructions on their website so people don't have to use a forum to ask. Not to be an ass but I'm not going to try to dissect 30 or so pages to try to get an answer on how it works.
Tekin, what is the reason for keeping the turbo boost delay and not just having it start after the end RPM for timing boost? I assume overlapping of timing is not a good thing?
or8ital is offline   Reply With Quote
Old 01-04-2010, 09:08 PM   #10001
lol never thought I'd ever have to use those pinions again.
Old 01-04-2010, 09:08 PM   #10002
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Deleted...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-04-2010, 09:09 PM   #10003
or at least sticky the info until Tekin does so.
Old 01-04-2010, 09:12 PM   #10004
Originally Posted by PitNamedGordie View Post
No I believe you are wrong. What Randy was explaining how quickly the boost will ramp up depending on what Ramp you set.
Let's do the math:
If you select a Ramp of "2", and you have 40 degrees of timing set for Boost, the ESC will add 4 degrees (of the 40 degrees you set) every tenth of a second.
.1 sec - 4 degrees
.2 sec - 8 degrees
.3 sec - 12 degrees
.4 sec - 16 degrees
etc...until you reach 40 degrees...
40 @ 4 degrees every.10 sec = 40 degrees of timing in 1 second.
Meaning you will have reached the 40 degrees of boost in 1 second. That is your ramp time.
Ramp Settings:
1 = 2 degrees every 1/10th second - Slowest Ramp
2 = 4 degrees every 1/10th second - Faster Ramp
3 = 6 degrees every 1/10th second - Fastest Ramp
NOW...the ramp starts at your "Start RPM" and you will reach your boost setting at the "End RPM".
whewwwww deep breathe...
Now apply that to Start and End RPM...
So the shorter distance between the Start and End RPM and Ramp will determined how quickly you will add timing.
If you have a Start of 5000 RPM and an end of 10000 RPM you you will add 40 degrees of timing from 5000 RPM to 10000 RPM in about 1 second (if your acceleration is consistent...like on a straightaway).
Clear as mud?
my brains!
redbones is offline   Reply With Quote
Old 01-04-2010, 09:12 PM   #10005
Let's do the math:
.1 sec - 4 degrees
.2 sec - 8 degrees
.3 sec - 12 degrees
.4 sec - 16 degrees
Ramp Settings:
Clear as mud?
Which boost are you referring to? Timing Boost or Turbo Boost? Randy confirmed above ramp is only for turbo boost and not timing boost. The numbers you are using suggest timing boost so I don't think this info is correct.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
