Old 01-04-2010, 06:38 PM   #9961
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by or8ital View Post
Anyone?
It's my understanding that's only for turbo. Timing is ramped between the RPM ranges selected.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-04-2010, 06:46 PM   #9962
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
does the car get more agressive from throttle profile's 3 twords 5? higer more..better for low end punch etc? thanxx
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-04-2010, 06:47 PM   #9963
jkirkwood's Avatar
Awesome power, thanks Tekin, saved me $$$ again. Therefore buying another unit for another class.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 01-04-2010, 06:52 PM   #9964
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Sorry if this has been answered but this thread is all over the place and hard to follow. Hotwire says the ramp is as follows
1 = 2 degrees every 1/10th second
2 = 4 degrees every 1/10th second
3 = 6 degrees every 1/10th second
Is that every 10/th within the RPM range? How does this work with Turbo Boost? Does Turbo boost add all that timing at once where it is in the ramp?
Also, what is the ramp timing added to? 0 or the motor timing you have set? For example if I set the timing on the ESC to 50 and have ramp set to 3 does that mean it is 56 degrees after the first 1/10th?
The turbo ramp refers to turbo boost exclusively, the start/end RPM refers to timing boost exclusively. Turbo ramp timing is added in addition to the timing value you've set for timing boost. Both timing AND turbo are added to your motor timing, which can only be changed by adjusting the endbell. Using your scenario of 50 degrees of timing boost, if the turbo comes in after all 50 degrees of timing are added (i.e. a long turbo delay setting is used), then turbo ramp 3 would give you a total of 56 degrees of added timing 1/10th of a second after the turbo kicks in.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-04-2010, 06:58 PM   #9965
Trader Rating: 16 (94%+)
Originally Posted by InspGadgt View Post
So then does anyone know the kv rating of the Duo2 17.5? Tried looking on Team Epic's site and couldn't find it.
Sorry man - I have my box for a 13.5 Duo 2, not a 17.5.
Duo 2 13.5 Specs
RPM = 14089 @ 5.0V (2817.8 RPM per 1 volt)
Power = 56W @ 8.2k
Eff = 82.6% @ 12.5k
Torque = 113.5 Nmm
kn7671 is offline   Reply With Quote
Old 01-04-2010, 07:05 PM   #9966
Trader Rating: 38 (100%+)
Great explanation. Thank you! So what is the start RPM and end RPM used to determine? Is the timing boost added linear to that range? So for example if the timing boost is set to 50 is the timing boost 0 at the start RPM and 50 at the end RPM (and 25 somewhere in the middle)?
or8ital is offline   Reply With Quote
Old 01-04-2010, 07:06 PM   #9967
vazzo's Avatar
Trader Rating: 100 (100%+)
Is there a document that explains the functions of the speedy? Mainly the new functions like turbo and rpm? Why would I use a particular funtion, under certain conditions etc etc??
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 01-04-2010, 07:08 PM   #9968
I don't think it can be linear in that range, since when you increase timing, you increase RPM's as well...
Old 01-04-2010, 07:17 PM   #9969
Cheers
Adrian
Try http://rcfaq.weebly.com/tekin-rs--hotwire.html
brrrrm is offline   Reply With Quote
Old 01-04-2010, 07:20 PM   #9970
One more question, what happens if the turbo is set prior to all the timing boost being added? Does it get suddenly added in the middle or wait until the turbo delay after the highest RPM is set? I was having a problem this weekend with the turbo not kicking in until the middle of the straight despite having it set to .2 (and it wasn't kicking in for at least half a second).
Old 01-04-2010, 07:29 PM   #9971
TfnG's Avatar
Trader Rating: 26 (100%+)
Originally Posted by HarryLeach View Post
First, click on advanced, select 203 and update your speedo.
Then, once everything is done, close hotwire and reopen [a quirk in this new version]. Once it's back up, click the advanced tab, and you should have the RPM range adjustments.
i might be blind...but where is the advance tab? all im seeing is Current Settings, Show defaults, Apply settings, View versions, Update ESC.
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 01-04-2010, 07:32 PM   #9972
stiltskin's Avatar
Trader Rating: 102 (100%+)
Did you click on sensored mode?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-04-2010, 07:33 PM   #9973
fire929's Avatar
Originally Posted by stiltskin View Post
What are you looking for? What type of motor and class are you running?
Ta05, 17.5 motor technical track i believe 100x46ft asphalt med grip
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 01-04-2010, 07:33 PM   #9974
MikeXray's Avatar
Trader Rating: 73 (100%+)
its right above the apply settings button, if it's not there, you may not have the right version installed.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-04-2010, 07:36 PM   #9975
TfnG's Avatar
yes
the only thing above Apply Settings is where i choose Sensored or Unsensored mode. where it says current software it shows 203.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
