Old 01-04-2010, 04:20 PM   #9946
Trader Rating: 38 (100%+)
Originally Posted by liquiddog View Post
The Novak site says N is 30 degrees. Is that the same as 0 Deg on a Tekin motor? I only ask because it says in a Novak document that timing numbers from different motor manufacturers can mean different things.
I'm trying to figure this out because I have a 17.5T Ballistic I'm using with a RS Pro.
I think Tekin says "0" timing on their motors is 15 degrees (the sensor is set at 0 but it reads 15 degrees ahead??). Motor to motor translation seems like its difficult.
or8ital is offline   Reply With Quote
Old 01-04-2010, 04:54 PM   #9947
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Ffejdat View Post
I don't know what Trinity's 17.5 is rated at in Kv, but a Novak is rated at 2200Kv, gotta think Trinity is about the same...
Lots of people running the new tekin software at the track yesterday, at MMR, it was VERY fast, the 17.5 1s 12th sacle cars don't even look or sound the same as before. I did see a few people haveing trouble with their Novak boosters browning out or acting up, a few switched to TQ or some Hong Kong booster, and the issue went away...
Does this mean that the average max RPM of any given 17.5 is about 16,280 rpms? (2200 x 7.4)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-04-2010, 04:59 PM   #9948
Team Tekin
TY@TEAMTEKIN's Avatar
Roughly, yes.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 01-04-2010, 05:08 PM   #9949
as i set my rpm at 3000 to 12000. Can i gear than heavier than as i set my rpm at 3000 to 6000?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-04-2010, 05:19 PM   #9950
fire929's Avatar
Default Help
I'm looking for anyone taht has a clue on how to set the new vegas 2.0 v turbo, ramp, and rpm range settings.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 01-04-2010, 05:26 PM   #9951
stiltskin's Avatar
Trader Rating: 102 (100%+)
What are you looking for? What type of motor and class are you running?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-04-2010, 05:28 PM   #9952
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The last 30+ pages in this thread discuss the Vegas 2 software. Search for post by Randy Pike. But then again there have been dozens of setups posted...find one that works for you.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-04-2010, 05:57 PM   #9953
tpczx6's Avatar
Made up a excel doc to keep track of setting But can ony post as a word doc
hope its works for you guys
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 01-04-2010, 06:09 PM   #9954
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
with the same gearing you should see it pull more with the 12k,try it and you can see the difference in the rpm range.its hard to explain you have to see it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-04-2010, 06:14 PM   #9955
oeoeo327's Avatar
Trader Rating: 74 (100%+)
You should be able to use a lower FDR (gear heavier) using the wider RPM range. Tightenting the RPM settings causes the total amount of timing boost to come in sooner. For example, if you select 30 degrees of timing boost and a 3000-6000 RPM range, you're adding 10 degrees per 1000 RPM while the motor is operating between 3000 and 6000 RPM. If you select 12,000 RPM as the end point and the same 30 degrees of timing boost, you're adding 3.33 degrees per 1000 RPM while the motor is between 3000 and 12,000 RPM.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-04-2010, 06:28 PM   #9956
TfnG's Avatar
Trader Rating: 26 (100%+)
im having problems with the new software. installed it on my computer...but when i pull up the HotWire interface im not seeing any of the RPM adjustments. its showing current version to be 203...also shows older versions. all of my parameters are still the same as vegas 1.0, but i just dont see rpm adjustability???
also, when i pull it up the interface...i get a little window that pops up saying my speed control may contain software that is not compatible with this HotWire. is that normal?
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 01-04-2010, 06:30 PM   #9957
HarryLeach's Avatar
Send a message via AIM to HarryLeach
First, click on advanced, select 203 and update your speedo.
Then, once everything is done, close hotwire and reopen [a quirk in this new version]. Once it's back up, click the advanced tab, and you should have the RPM range adjustments.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-04-2010, 06:32 PM   #9958
Originally Posted by ddesros2 View Post
OK I've gone over this thread and loaded my cars with V203.
From all of this, this is what I take from it with V203 software:
1. Keep static motor timing small (0 to 10deg max!) (you want the torque at the start till boost kicks in)
2. Boost between 35 and 50 (less with lower turn)
3. RPM window to match approx speed of car through average corner speed
(ex: car is 10km/h in the corners = ~2560RPM on a 12th scale with 65 MMPR, start turbo ramp there...end near top speed 3/4 down the longest straight...adjust accordingly). 17.5TC 5000ish to 15000ish
4. Turbo only as last bit on long straight..no less than 0.5s delay.
5. Throttle profile to your driving style (best to use linear)
6. Some drag brake (brushless rolls freely). 10ish in 12th, 20-30ish in TC
7. Turbo ramp 1 or 2
8. 13.5 12th ~ 60 to 70mmpr (per track); 17.5TC ~ 5 to 6 FDR. Adjust per track.
Let me know if this makes sense to all of you out there.
Finally tested V203 on my local track today. It is high grip asphalt with a 30m straight and 4 x 180 degree turns. At the time two other cars were practicing one with a 4.5T motor and the other a 6.5T motor.
My details are as follows:
Chassis: TA-05 IFS CF
Motor: Tekin 10.5T
Battery: Intellect 4200 30C 2S
Drag Brake: 30
Reverse Strength: 100
Brake strength: 100
Neutral width: 20
Motor type: BL-DL (only during practice)
Throttle profile: 3
Voltage cutoff: 2
Push control: off
Timing boost: 50
Turbo boost: 10
Turbo delay: 0.5
End rpm: 15000
Start rpm: 2992
Turbo ramp: 2
Motor timing: 0
Ambient temp: 115F
Motor temp: 130F
esc temp: 3 lights
FDR: 6.47
Rollout: 30 mm
From stand still I had to go easy on the throttle to prevent burnouts. The same happened when punching the throttle midway through the corners. The car became a drifter! Infield power was incredible. So I reduced the EXP on my radio. With a solid front axle the car accellerates like a bullet. On the straight there was a continuous smooth accelleration all the way until I had to slam the brakes. In the end it outran both the 4.5T and 6.5T on the straight and infield. The only problem was that my wheel nuts kept falling off. Now I threadlock them in place. Awesome power. I don't need another motor to race in modified.
brrrrm is offline   Reply With Quote
Old 01-04-2010, 06:35 PM   #9959
Originally Posted by or8ital View Post
Sorry if this has been answered but this thread is all over the place and hard to follow. Hotwire says the ramp is as follows
1 = 2 degrees every 1/10th second
2 = 4 degrees every 1/10th second
3 = 6 degrees every 1/10th second
Is that every 10/th within the RPM range? How does this work with Turbo Boost? Does Turbo boost add all that timing at once where it is in the ramp?
Also, what is the ramp timing added to? 0 or the motor timing you have set? For example if I set the timing on the ESC to 50 and have ramp set to 3 does that mean it is 56 degrees after the first 1/10th?
Anyone?
Old 01-04-2010, 06:36 PM   #9960
WIITA's Avatar
Trader Rating: 42 (100%+)
Props to Tekin for making a wonderful product even better. I ran the new 203 this weekend and it is a very substantial increase in speed and torque. When I was running 1/12 on sunday, I had flash backs to last year when we were running 17.5 nimh. The one down fall this year with lipo in stock for me was the bottom end punch. This version alleviates that problem all together. Had plenty of low end which in crucial at the tracks I run at. I am thinking about doing some testing with a 13.5 in 1.12 on wednesday, Anyone care to share a good starting point for 13.5 1/12 on a medium but tight carpet course? Here is my setup I ran on sunday in 17.5 and it seemed to be very good:
End rpm 4500
st rpm 3000
boost 50
drag 0
push 25
turbo 0
profile 5
rollout 78mm
WIITA is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
