Old 01-04-2010, 09:30 AM   #9901
Originally Posted by 20 SMOKE View Post
your the first that asked if you should turn off turbo,that is a good place to start,and drop 3 teeth on the pinion or a equivalent gearing with a bigger spur
Thanks Jamie
anybody else got any input?
008-Racer is offline   Reply With Quote
Old 01-04-2010, 09:33 AM   #9902
Official's Avatar
Need help in understanding about how much RPM i should set for End RPM.
Currently i'm using a 11.5T which is said to be the same as a brushed 23T motor. Is there a tool to check the RPM for brushless motor like the motormasters from muchmore?
Exp: A 23Turn brush motor stock untouch rpm is about 28000 ~ 30000 and after tuning and meddling with it i can get 49000 ~ 51000 rpms.
So how do i translate to a brushless motor????
Should end rpm be like 29000rpm????
Just want to know better to convert it.
Chassis :4WD = CEFX Photon,TA-05|2WD = Xevo, M05PRO, FF-03Pro, Kysho Evola M3, Kyosho V-One RRR Shimo, Team C TC02
ESC :Brushless - Tekin RS-Pro, Keyence Tachyon|Brushed - Tekin FX-Pro
www.hiro-seiko.com ; www.cefx.net
e-mail: [email protected]
Official is offline   Reply With Quote
Old 01-04-2010, 09:48 AM   #9903
kawirider's Avatar
Trader Rating: 14 (100%+)
Originally Posted by SteveL View Post
Jim,
Ironically, that picture you posted is also from our track! We do tend to push the envelope a little with Drew pushing us to be as fast as him. I will ask him about running the motor but I know he just received a number of brown can motors from another California company.
Your diagnosis about the motor being on it's way out before I got it sounds exactly like I wanted to hear. I double checked and I do indeed have version 203 loaded so that eliminates that option. I will back off on on the settings and keep trying as this is way too much fun. I use to love working on brushed motors but this has taken place of that pretty easily! Thanks for the great software ..............and cleaner hands!
i think he is right too steve. that motor just took a dump. my ballistic motor came off at less than 130 with a little less turbo setting in yours. i think we have been overgearing this cars all along. all three of our cars last nite looked like we stuck in a lower turn motor. that ballistic motor like the timing! i was overgeared somein the main, maybe 2 teeth still.
Associated T4, CRC Gen XL, Associated 10R5 WGT, jconcepts BJ4
Josh Evans
kawirider is offline   Reply With Quote
Old 01-04-2010, 10:11 AM   #9904
10.5 motors are nearer to a 12 turn single brushed than the 19t that is the "equivalent" so I think your 23t comparison is a bit off in the real world
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-04-2010, 10:26 AM   #9905
Default RS TEKIN V2.03 Settings Push???
Posted this 5/6 pages and got no response. Any comments on this .
Used the new software yesterday,After a bit of trial and error settled on the following. Car was awasomely quick and was the equal of most of the Nim cars.
Still not settled on the end RPM and range so may need a little tweaking. Also on one run had push set too 25.As it happened this was my fast run. But came too the conclusion why have push if you have Drag brake. Some one might want tooo comment on this one.Car was very quick on straight and a bit hot too handle out of the corners.
Also any thoughts on END RPM and minimum rpm range.???
Track carpet 100ft X 40FT (30mt x 12mt)
Fast and flowing.
Motor redline 10.5 timing set too zero rollout 67.2
car a speedmerchant rev5 l
drag 5
brake 100
rev off
neutral 5
bl-fw
throttle 4
push off
timing boost 45
turbo 10
1S lipo
turbo delay 0.5
sensored
end RPM 10,500
4278-----8569
ramp 2
tellan is offline   Reply With Quote
Old 01-04-2010, 10:29 AM   #9906
Official's Avatar
So how do i find out when is the rpm ending???
Old 01-04-2010, 10:32 AM   #9907
theisgroup's Avatar
i would look to the manufacture of the motor for it's kv rating, but if all else fails, try the novak site and see what their kv rating is for you turn of motor
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-04-2010, 10:39 AM   #9908
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Fast and flowing.
drag 5
brake 100
rev off
neutral 5
bl-fw
throttle 4
push off
timing boost 45
turbo 10
1S lipo
turbo delay 0.5
sensored
end RPM 10,500
4278-----8569
ramp 2
you cant use push if drag brake is on,it will create a delay in the drag brake.your close with the end try in the 8k with a 2500 start ramp3 and 5 turbo and delay on 3-4
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-04-2010, 10:44 AM   #9909
pakk's Avatar
Trader Rating: 79 (100%+)
There have been a few posts on battery fade. I have experienced it and I have seen others experience it this weekend.
What is causing excessive battery fade?
Is it too much RPM? Too much timing? Too much timing too fast?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-04-2010, 10:45 AM   #9910
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Fast and flowing.
drag 5
brake 100
rev off
neutral 5
bl-fw
throttle 4
push off
timing boost 45
turbo 10
1S lipo
turbo delay 0.5
sensored
end RPM 10,500
4278-----8569
ramp 2
These settings seem to be very close - try an RPM window (start-end) of 3500-8000, and maybe try using a throttle profile of 3 instead of 4 if the car is hard to control out of tighter corners. I'd also use drag brake w/o any push control - I had to add drag brake (I used a setting of 10) to get my car into corners with more accuracy.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-04-2010, 10:54 AM   #9911
oeoeo327's Avatar
It's too much timing in too short of a timespan. Set the turbo delay a little higher, set the start/end RPM a little tighter (the actual values will depend on the motor being used, but try to keep the window between 3000-4000 RPM), and keep the turbo ramp @ 2. For 1 cell cars, I wouldn't use more than 45 degrees of timing boost. If the car seems slow, you can probably increase the rollout a bit. I increased the rollout until the car felt "lazy", but lap times dictated otherwise...
The biggest point to keep in mind - make sure that the chassis is working well to see the greatest gains with the least amount of battery fade.
Old 01-04-2010, 11:04 AM   #9912
Trader Rating: 198 (100%+)
I wish I was there yesterday to help out. If Steve ran the Duo in hole 2 he had 20 degrees of timing on the motor. You want as little as possible with the new software. Make sure on your Ballistic you are in the minus side of the timing. If you are at N then you have 30 degrees on it. I really hate this timing misconception that is going on with some of these motor types.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 01-04-2010, 11:14 AM   #9913
what formula do you use to translate kv rating into RPM?
Old 01-04-2010, 11:20 AM   #9914
kawirider's Avatar
well, kevin, i had it behind the N for awhile, and it was just dog slow, i put it back at the N with the boost around 45 and the sucker was fast enough for me to break it then i know it should work like that, but it did. motor came off less than 130 degrees still. i am gonna work on it more on thurs. the difference in the speed is pretty surpising, especially in touring car.
Josh Evans
Old 01-04-2010, 11:47 AM   #9915
Trader Rating: 16 (94%+)
the problem with circuits down at the min voltage is that you can not predict the response of the circuit. unless the circuit was designed for low voltage. so you could have 10 units from the same batch and 1 would fail and 9 would work or 9 could fail and 1 could work.
I had Novak Booster Cut-Out issues with my WGT 13.5 car on the bench, low load with a main 1S battery voltage of 3.8V for testing after updating the software. After a full-charge on the battery I could not get the problem to reproduce on the bench, but after a few minutes on the track, I couldn't go an entire lap without a cutout.
On my 17.5 1/12 car using a Novak Booster, I had zero problems all day long. Not sure where the problem is, but a 2s 300mah Receiver battery cured my problems in WGT.
kn7671 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
