Old 09-05-2008, 03:47 PM   #976
Originally Posted by sportpak View Post
Call Tekin dirrectly and ask to talk to Charlie. I had the same problem. Your Hotwire has old drivers installed and your computer doesn't recognize it because the software you install dosn't match the hardware. Charlie will help you reconfigure the hardware to get it working with the software. He stepped me through it and I would have never figured it out myself.
I will call them next week.
thanks all
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-05-2008, 09:29 PM   #977
davepull's Avatar
Originally Posted by Krio View Post
I have a futaba 3pk w/ spektrum and I also had to reverse my throttle in order to complete setup with both my Rs and Rs pro. In the manual for the mamba max, it explicitly notes that you will have to reverse the throttle on futaba radios to work. Must be a similar case
k when I first got my 3pks I didn't have to reverse the throttle that was in profile 1 but wh,en I change to another profile i have to reverse. wierd but I have noticed no difference in performance.
davepull is offline   Reply With Quote
Old 09-05-2008, 10:34 PM   #978
Krio's Avatar
Trader Rating: 150 (99%+)
I know this is the onroad thread, but just wanted to relay what happened today with my rs in my b4 with a 17.5. I slid out in an off camber corner and was rolling backwards down the slope...apparently fast enough that the rs was in sensorless mode (running hybrid mode). Tried to get on the throttle, but it cogged badly and I had to wait till it rolled all the way down, slowed, and went back to sensored before getting on the throttle. Maybe something can be added in the next update that if the motor is spinning backwards the esc automatically uses sensored when in hybrid mode.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 09-05-2008, 10:40 PM   #979
davepull's Avatar
i had a lrp do that.
Old 09-06-2008, 07:01 AM   #980
TRF415boy's Avatar
It shouldn't be doing that, I suspect your sensor cable wasn't plugged in properly? It's easy to check, with the speedo in neutral, turn the motor manually and watch the last 3 led alternatively get dimly lit as the motor turns...
TRF415boy is offline   Reply With Quote
Old 09-06-2008, 01:47 PM   #981
I got reply from Tekin and they send me a new one. I must send this one back.
I tested first some things they asked me and that didn't work.
I want to thank every body for there help and Tekin for helping me so soon.
Tekin has a great service and i will keep using Tekin products. I have never got such a good service.
Thank you all.
Greetings Emiel
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 09-06-2008, 03:01 PM   #982
RC MARKET's Avatar
Thank you all.
Greetings Emiel
OK !
RC MARKET is offline   Reply With Quote
Old 09-07-2008, 01:10 AM   #983
Originally Posted by stocker View Post
I know Randy is helping me on this, but just to see if anyone has experienced a similar situation as me.
I am getting a 'internet connection not found' message when clicking 'update' on the Hotwire software? My internet works fine, not sure why I am still getting this despite uninstalling and reinstalling multiple times.
No one has this problem but me huh...
stocker is offline   Reply With Quote
Old 09-07-2008, 10:50 AM   #984
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hey Stocker,
I spoke to our engineer about this. The version of Hotwire software you have goes about checking for internet differently then the update that's coming out.
Currently the hotwire will look for you network card, internet, then ping our site. The update now just pings the site to verify internet.
Make sure that once you plug in the Hotwire(no speedo) go ahead and click on "check for updates."
Make sure you're running the latest software. The current one can find conflicts in certain network settings and come to the conclusion that there's no interent.
I'll post something when the new Hotwire software is out.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-07-2008, 06:48 PM   #985
double post!
Old 09-07-2008, 06:49 PM   #986
Randy Thanks. Looking forward to the new software!
Old 09-08-2008, 05:30 AM   #987
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by Randy_Pike View Post
Hey Stocker,
Is that "Update" option to update the Hotwire software or update the settings in the ESC?
ta_man is offline   Reply With Quote
Old 09-08-2008, 05:48 AM   #988
m3ndo5a's Avatar
Can anyone state what the parmeters are on the Hotwire ESC timing settings......like what does the numbers represent . min~max......what would be the timing degrees on the speed controller by each click.
m3ndo5a is offline   Reply With Quote
Old 09-08-2008, 05:49 AM   #989
LOSI SCOTT's Avatar
Trader Rating: 70 (99%+)
Hello everyone i am not liking what i am reading about this ESC. I am running novak gtb right now but was going to switch to tekin rs but some of the things i am hearing and reading are scaring me away from tekin! What do you all think?
________F.T.R________
FACTORYTRACKSRACEWAY.COM
KYOSHO
MURFDOGG MOTOR WORKS
PUNCH IT..................
Slow is Smooth___Smooth is FAST...........
LOSI SCOTT is offline   Reply With Quote
Old 09-08-2008, 06:24 AM   #990
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
I GOT THREE TEKINS.. 2 pros and one regular. All perform better then expected!! Thanks tekin
still fishing
ALBERTO is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
