Tekin RS ESC sensored
#9781
carnt beileve that that track want to ban v203, its only because the users of other speedo's are daft enough to not be running a tekin.
its like saying "I WAS SILLY ENOUGH TO BUY A BLUE SPEEDO WHICH I REGRET SO YOU CARNT RUN A TEKIN"
back to a serious note, ran v203 yesterday with 1s and i was blown away by how much power i now have, nimh now no longer have the advantage in stock class
thanks tekin
thanks tekin
#9783
A lot of brakes gets the motor hot, and when the motor's hot it runs less efficiently so you end up using more power to go the same speed. I think that's what drains the battery so much.
#9784
has anyone determined a sure fire way to gain starting points for a track? (eg. with v200 gearing for infield without turbo then turning on for the straight)
i read a fair few pages back someone using a formula to workout average RPM's.. is this the way to go or not really?
#9788
Has anyone encountered problems with the TQ booster and v203 firmware?
#9789
He said that a higher power booster (Novak) or a receiver pack fixes the problems.
#9790
When I ran my 1/12 with a Novak a while back it was doing the same thing. Found I was actually over geared. Dropped my gearing and it was still doing it. I then put the TQ Booster in and the problem went away. Not sure why though, I never was able to track down the cause.
#9792
Actually I neve claimed a high power booster(N___K) was working any better. In fact that booster is the one so far causing the most issues.
My suggestion was that if you're experiencing any radio issues while running a booster(any kind) to try a TX pack to see if that issue goes away. So far the phenomenon is a low VC hit where the booster can't keep up with demand.
#9793
BTW - this new software is FANTASTIC, once you find the "sweet spot". I worked with a few fellow racers, and we systematically found what settings seemed to work most efficiently. Start with one common set of settings amongst the group, and when you decide to make changes have one person make one set of changes, while someone else employs a different set of changes. Compare lap times after a few profile revisions, and you'll usually find a good middle ground that'll give you what you want...
#9794
Tested this combo extensively last night - no problems... What kind of problems did you experience? If you give us an idea of what was happening, you'll probably find the answers you'll need in a few short hours.
It's good to hear that you guys run your TQ booster without problems. Hopefully that means one less worry at my upcoming event.
