Old 01-02-2010, 09:35 PM   #9751
Chris Adams's Avatar
Sent this to Randy but figured its useful for everyone.
The setup that Yang posted for 13.5 2s is the one that he and I came up with. I drove and told him what it needed. He jacked with it as I had no clue it was available... went to practice with my vegas 200... We didn't have too much time to mess with it but im sure tomorrow when we are actually racing we will be able to find a good setup for a carpet track.
I do think that a narrower gap in the rpm range is more violent but allows for greater speed within a small area like carpet and the wider gap will be more suited for a much larger track such as asphalt. I do not think that the difference in the gap will be really big between setups... maybe 2000 rpms... Turbo should be what you want to get your top end out of.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 01-02-2010, 09:51 PM   #9752
tallyrc's Avatar
Originally Posted by cyanyde View Post
I believe you'll be one of the first to find the right setup. Most people here simply thinks timing = power. The fact is timing should be added where REQUIRED.
only seems logical that the majority of timing would be needed somewhere above the midpoint of the practical rpm range of the motor ~15k in our application.. also seems like a curve rather than a linear progression of timing would be better as i cant recall ever seeing power output being linear.. like i said. i might have to buy one of them data loggers by orange..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 01-02-2010, 10:02 PM   #9753
Grenade10's Avatar
Trader Rating: 37 (100%+)
Tally, I spent a full day with the data logger in two oval cars prior to loading the new Tekin software, and had a lot of interesting data to look at. I believe it made me faster, atleast for the first day.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-02-2010, 10:08 PM   #9754
Send a message via AIM to munrath
Randy - Congrats to you and the team for this latest software. I must say I've been using the SPX for some time now and last night the track record was broken by .3 tenths per lap using the Tekin ESC and the new software. Some were dropping times as much as .6 tenths per lap. The shop sold out of them yesterday and guys were scrambling to borrow the speedo's from other racers. If you didn't have it you were packing up and going home as it was truly a beast on the track.
Thanks,
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 01-02-2010, 10:11 PM   #9755
Ok, I think I solved my problem with saving my RPM settings. It seems I need to click the appropriate boxes more that once, like 2x.
For the start RPM, can I enter my own RPM values or only the RPM values that shows up?
RoyU is offline   Reply With Quote
Old 01-02-2010, 10:32 PM   #9756
alangking_306's Avatar
Default emergency
hai randy seem i like a problem with my new software i am using futaba 3pks when i push trothle my ride reverse pls now i am at trek a half day cant solve the problem thanks
4pk,PT 2549804,V one R4,,RB matrix,nova 353,3st (RRRR,mega, evo2 history)
JBRCC -Black Crow Racing Team-
alangking_306 is offline   Reply With Quote
Old 01-02-2010, 10:37 PM   #9757
tallyrc's Avatar
check your motor wires A.B.C. to A.B.C.
Old 01-02-2010, 10:48 PM   #9758
wire connection is ok
Old 01-02-2010, 10:49 PM   #9759
before this with vegas no problem
Old 01-02-2010, 10:53 PM   #9760
pakk's Avatar
Trader Rating: 79 (100%+)
anyone experiencing excessive battery fade?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-02-2010, 11:01 PM   #9761
tallyrc's Avatar
thought it was just me and all the new power.. hmm
Old 01-02-2010, 11:04 PM   #9762
mikel33's Avatar
Trader Rating: 2 (75%+)
Couple questions for Randy (or anyone else that knows for that matter):
1) What is the relationship (if any) between throttle profile and how the timing boost is applied?
2) Should the turbo boost be an even multiple of the turbo ramp - if using setting 3 (6 deg/10th of a sec) should I be at 6, 12, or 18 on turbo boost?
This is an excellent product, job well done by Tekin.
michael.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 01-02-2010, 11:04 PM   #9763
tallyrc's Avatar
reverse servo, turn off reverse so esc is set to only forwark/brake then send to esc and recalibrate your radio..... maybe
Old 01-02-2010, 11:23 PM   #9764
still cant i dont know what happen may be my esc have prblem
Old 01-02-2010, 11:30 PM   #9765
tpczx6's Avatar
Can someone post a screen shot of the interface or please list all the names of the setting on the interface. Thanks
I have so far
Drag Brake
Brake Strength
Neutral width
Voltage cutoff
Motor type
Throttle Profile
Reverse Srrength
Push Control
all on sliders
and in a box to right
1s or 2s
sensored or not
turbo delay
Please add or post a screen shot if you can
I hope to have one to try on Sunday
Thanks again
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
