Old 01-02-2010, 06:23 PM   #9721
bigdadracing's Avatar
thanks for the info so what i need too do is set the motor at 10 degrees and no turbo .i also heard there a new program for the speedo witch i could download with my hot wire???
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 01-02-2010, 06:31 PM   #9722
Trader Rating: 23 (100%+)
I have tested at my track...70 x 30...it was clocked at 29 mph on the straight which may be 65 ft..which is pretty fast could be faster..it came off the track at 102 degrees..i think i need a little more straight a way speed and a little more pop in the infield my set up is as follows..
.2 turbo delay
end rpm 7000
start rpm 2437
turbo ramp 3.0
turbo boost 10
timing boost 41
throttle profile 3...
76 spur with 42 pinion..tires 42mm...the turbo kicks in a little late..can anyone give me any suggestions...13.5 orion vortex is the motor
Based on your roll out of 72.92mm, the motor would be turing 10,750 prm to reach 29 mph. Should the end rpm be set higher or should the turbo be set higher, or both to reach a greater speed on the straight? I know you can increase pinion size to get the extra top end, but that would make it more sluggish coming out of a corner, correct?
This is very interesting as our track is almost the same length and I am going to be running the new software for the first time tomorrow.
SteveL is offline   Reply With Quote
Old 01-02-2010, 06:40 PM   #9723
wallyedmonds's Avatar
where is the instruction manual for this im so lost lmdao i dont know where to start and end ok im old.
wallyedmonds is offline   Reply With Quote
Old 01-02-2010, 06:40 PM   #9724
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the new software is on the homepage of tekin
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 06:41 PM   #9725
20 SMOKE's Avatar
what are you running
Jamie W
Old 01-02-2010, 06:43 PM   #9726
1/12 13.5 mid size track (fast cats)
Old 01-02-2010, 07:31 PM   #9727
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Randy_Pike View Post
1000rpm start / 6000 end with 50 timing boost will provide 10 degrees of boost per 1000 rpm vs.
1000rpm start / 11000 end with 50 timing boost will provide 5 degrees of boost per 1000 rpm.
Make sense?
That is exactly how I was looking at it. Tag recommended a higher end rpm to smooth out my acceleration and I think you just confirmed that. Thanks.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-02-2010, 07:57 PM   #9728
20 SMOKE's Avatar
comes in slower and smother,higher would probably work on low traction as well
Jamie W
Old 01-02-2010, 07:58 PM   #9729
Originally Posted by 20 SMOKE View Post
click the end rpm backspace and type what the rpm you want click calculate then select the start rpm and update
By update you mean "apply setting"? When I click on "apply setting" and click on current settings the rpms go back to the default settings. And if I close Hotwire and open it again, the rpm settings go back to the default setting. I must be not doing it right.
RoyU is offline   Reply With Quote
Old 01-02-2010, 08:05 PM   #9730
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
you have to set high end rpm's then hit the calulate rpm's. then hit ok or cancel... then choose you low side rpm... hit apply setting's .. this should save your setting. this i what i found out you need to do. i was having the same issuse's
want to say thanks to randy and the tekin staff. very good program this time out. was running against the ae and mamba speedo's this weekend. i had plenty of power everywhere to keep up or out power them everywhere.... thanks for everything randy..... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 01-02-2010, 08:18 PM   #9731
20 SMOKE's Avatar
there is a check box under the end rpm you type in click it after it calculates set the start and then update
Jamie W
Old 01-02-2010, 08:19 PM   #9732
Its not saving the rpm settngs. Unless everytime you Hotwire it goes into the rpm default setting.
Old 01-02-2010, 08:25 PM   #9733
20 SMOKE's Avatar
are you getting the setting you want and then apply,don't unhook the esc go back and see if it stays,mine was doing it they weren't saving i had to close the hotwire and reopen with it connected to the esc and set the rpm range and it stayed
Jamie W
Old 01-02-2010, 08:27 PM   #9734
The ideal start/end rpm for boost will depend on the platform/chassis being used along with track size and motor wind. The size of the range will also affect how the car pulls. A narrow rpm range will effectively produce a faster rate of boost vs. a wide range will have a slower rate of boost:
Make sense?
It function (start/end rpm) use to (timing boost) or (turbo timing)?
mugend5r is offline   Reply With Quote
Old 01-02-2010, 08:34 PM   #9735
Make sense?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
