Old 01-02-2010, 05:40 PM   #9706
Originally Posted by 20 SMOKE View Post
i was playing with 1500-4000 and found around 2000 start was good
Ok but the motor timing is at 12 and can't be lower on my LRP X11 10,5T
And I drive 2 cell lipo so to be save.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-02-2010, 05:46 PM   #9707
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by LOW ET View Post
i know you said you didn't get to play with the settings but if you went to a 90' track would you lower the end rpm?
I think that's the concept. The lower the end RPM value, the faster the boost is applied. LMK if I'm wrong. I'll be playing with different values tomorrow to see what happens.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-02-2010, 05:58 PM   #9708
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Danny-b23 View Post
Not much. I tried a smaller RPM spread with heavier gearing and didn't like it all that much. I ended up dropping about 3 teeth on my pinion from where I started on Friday afternoon. Of course, my Speed Passion stuff should be here sometime in the next week or so, and this setup will be null and void for me.
I think the trickiest part for me will be finding which types of motors like which power band.
SP,esc and motor or just motor
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 06:01 PM   #9709
20 SMOKE's Avatar
10.5 had great rip,try the 10500 and around 3k start.i threw a 16000 at my 17.5 and it flatend out to early but a little more gear would have been ok,i think most setups will be very close with little changes to timing boost
Jamie W
Old 01-02-2010, 06:07 PM   #9710
Trader Rating: 5 (86%+)
Default 1/12 set up
I have tested at my track...70 x 30...it was clocked at 29 mph on the straight which may be 65 ft..which is pretty fast could be faster..it came off the track at 102 degrees..i think i need a little more straight a way speed and a little more pop in the infield my set up is as follows..
.2 turbo delay
end rpm 7000
start rpm 2437
turbo ramp 3.0
turbo boost 10
timing boost 41
throttle profile 3...
76 spur with 42 pinion..tires 42mm...the turbo kicks in a little late..can anyone give me any suggestions...13.5 orion vortex is the motor
obi wun is offline   Reply With Quote
Old 01-02-2010, 06:08 PM   #9711
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The ideal start/end rpm for boost will depend on the platform/chassis being used along with track size and motor wind. The size of the range will also affect how the car pulls. A narrow rpm range will effectively produce a faster rate of boost vs. a wide range will have a slower rate of boost:
1000rpm start / 6000 end with 50 timing boost will provide 10 degrees of boost per 1000 rpm vs.
1000rpm start / 11000 end with 50 timing boost will provide 5 degrees of boost per 1000 rpm.
Make sense?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-02-2010, 06:10 PM   #9712
20 SMOKE's Avatar
.2 turbo delay
end rpm 7000
start rpm 2437
turbo ramp 3.0
turbo boost 10
timing boost 41
what is the endbell timing.did you try to add a little more timing boost
Jamie W
Old 01-02-2010, 06:12 PM   #9713
i have not applied any boost on the endbell..would that make my turbo kick in sooner on the straight a way...what about my infield problem...what about the start and end rpm..r they ok
Old 01-02-2010, 06:14 PM   #9714
bigdadracing's Avatar
hey guys got a question about what program should i use for 13.5 turing car .meduim sized track and what gearing .the car is a t2008 with 1.7 fdr.thanks in advance for any help. also any setting for the hot wire would be aprecated
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline   Reply With Quote
Old 01-02-2010, 06:14 PM   #9715
Team Tekin
Randy_Pike's Avatar
Obi,
Please post your setup again, and what are you looking to gain?
Old 01-02-2010, 06:16 PM   #9716
Originally Posted by Randy_Pike View Post
Obi,
.2 turbo delay
end rpm 7000
start rpm 2437
turbo ramp 3.0
turbo boost 10
timing boost 41
Old 01-02-2010, 06:19 PM   #9717
Team Tekin
Randy_Pike's Avatar
Ok,
First off where is your motor timing set? If it's at 0, get rid of turbo for now and add 10 to the motor.
There is more than enough timing at hand without turbo.
Old 01-02-2010, 06:19 PM   #9718
20 SMOKE's Avatar
start with randys set up. geared around the 6-6.5fdr
Jamie W
Old 01-02-2010, 06:19 PM   #9719
Danny-b23's Avatar
Motors. I am getting a 13.5 and a 17.5, both Version 3.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 01-02-2010, 06:23 PM   #9720
Ok,
motor timing is at 0 ..so add motor timing and get rid of turbo.. do i need to increase timing boost or leave it at 41..will this give me more speed or more infield punch..how do i get more infield punch if this is solving my speed problem..also..is the start rpm 2437 and end rpm 7000 good..how would this effect things..should i change it
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
