Old 01-02-2010, 04:40 PM   #9691
TrevCoult's Avatar
My settings from 12th scale 10.5 at Tamworth today, taken from my post on RCRaceChat. Approx. 30m x 12m track.
Version 203 - Vegas2
Tekin Redline 10.5 - 0 deg - 66mm/rev
SMC 4900 50C LiPo
Sensored LiPo - no cut-off set
Drag Brake 6
Reverse Strength Off
Brake Strength 96
Neutral Width 5
Motor Type BL-FW
Throttle Profile 2
Voltage Cutoff 0
Push Control Off
Timing Boost Max
Rev range - 2821 to 11495
Turbo Boost 5
Timing Delay 0.5 at 2.0 ramp-up
I always kept the top of the rev range high, but lowered the start revs a couple of times to try to get the power to come in less aggressively as there was plenty of it! Same reason for a negative curve on the throttle profile, my car was not the best handling today so I was trying to calm it down a little.
With the settings above I had no problem keeping up with the NiMh cars, in fact was quicker than most in my heat.
Quote from today by SlowerOne:
"Overall a real step forward, and I can see now why the AE BD killed in 13.5 at Vegas! If this is what they had... Thanks Tekin, more power and speed for free!!"
I couldn't say it better myself so I thought I'd just repeat it!
Quite a few drivers visited my laptop today to use my HotWire and every single one was seriously impressed with V203. (They've all registered and downloaded 203 properly by the way.)
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 01-02-2010, 04:43 PM   #9692
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Danny-b23 View Post
Well, after 2 days of testing, I settled on:
35 Drag Brake
75 Brake Strength
Throttle Profile 3
50 Boost
10 Turbo
0.1 Delay
3 Ramp
Start: ~5000
End: ~18000
5.88 FDR
Broke our track record again by about 3 tenths, and the car was super consistent.
what kind of track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 04:55 PM   #9693
Danny-b23's Avatar
Originally Posted by 20 SMOKE View Post
what kind of track
Small. Like 50x30.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 01-02-2010, 05:01 PM   #9694
cyanyde's Avatar
Originally Posted by mikky32 View Post
.....The top speed is incredible. The car flies but I want some more infield speed and I don't now how to get it.
As i lower my Boost I must gear a lot heavier. I loose a lot of top speed.....
If you've gone as low as 10+FDR and still hunting for infield speed there is something definitely off with the setup. Don't forget to make use of physical motor timing also since the new version runs alot cooler.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 01-02-2010, 05:09 PM   #9695
stiltskin's Avatar
Trader Rating: 102 (100%+)
Not a bad day at the track today. I really wanted to play around with the settings but I honestly had to learn how to drive my car again. This software is ridiculously fast. Instead of working on different settings, I ended up updating other cars and trying to explain how the new software works. I did manage to TQ and drop my best time by 7 seconds. I still have a lot to learn and I'm still blowing corners. The torque is amazing for 17.5. ROAR can't make me run mod, but Tekin just did. Here's what I ran in 17.5 / rubber / carpet. Track is 96x40:
Duo2 timing: 0
Throttle: 3
Boost: 50
Turbo: 10
Delay: 0
Ramp: 2
Drag: 30
End RPM: 12000
Start: 6680
FDR: 5.76
Motor came off at 180 and ran hard all day. I'd like to smooth it out a little more, so I'll be playing with RPMs tomorrow. Great stuff Tekin.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-02-2010, 05:15 PM   #9696
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Guys, it seems that there are a few boosters for 1s that aren't handling the load with this latest software update. So far nobody that is running a tx pack is having any issues, just the booster guys. So if you're having radio issues, glitches, slow servos or p/t issues swap to a tx pack and see if that fixes your issue.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-02-2010, 05:16 PM   #9697
Motor has 12 timing.
That's not the problem. I compete with the SPX and that one is also fast in the infield. I have after 10 meters advantage.
Than I run away from the rest faster and faster.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-02-2010, 05:18 PM   #9698
What's the procedure for setting up the start and end rpms? Can't seem to keep the entered start and end rpms.
RoyU is offline   Reply With Quote
Old 01-02-2010, 05:20 PM   #9699
Originally Posted by blackdog View Post
Hi
I just downloaded the new software and Im kinda lost. I'm am looking for a base setting .car is a TC5, reedy lipo (5000) 35c with 21.5 novak and Im running vta in St.Catherines Ontario (Niagara indoor ) .Im not sure of the track size but it is a a far size track that changes every weekend.
I have set all base setting to what I had previously
Im going to use the 203 version ???
End RPM I set to 4000 and start RPM to 13000 I have no clue if this would be ok or not
Turbo ramp is at 2
LMK
Thanks in advance
Matt
Blackdog,
Don't know if anyone has replied to you yet? You have the start and end RPM's reversed. You need the Start @ 4000rpm and End @ 13000rpm
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-02-2010, 05:24 PM   #9700
20 SMOKE's Avatar
click the end rpm backspace and type what the rpm you want click calculate then select the start rpm and update
Jamie W
Old 01-02-2010, 05:33 PM   #9701
20 SMOKE's Avatar
Small. Like 50x30.
did you play with end rpm and start
Jamie W
Old 01-02-2010, 05:37 PM   #9702
Can it be that my rpm range is to short?
I have now 7500 - 4900.
As I go 10500 -5000 I think that I will have more power in the infield
I will try it tomorrow.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-02-2010, 05:37 PM   #9703
LOW ET's Avatar
Trader Rating: 97 (100%+)
Duo2 timing: 0
Throttle: 3
Boost: 50
Turbo: 10
Delay: 0
Ramp: 2
Drag: 30
End RPM: 12000
Start: 6680
FDR: 5.76
i know you said you didn't get to play with the settings but if you went to a 90' track would you lower the end rpm?
LOW ET is offline   Reply With Quote
Old 01-02-2010, 05:39 PM   #9704
20 SMOKE's Avatar
i was playing with 1500-4000 and found around 2000 start was good
Jamie W
Old 01-02-2010, 05:40 PM   #9705
Danny-b23's Avatar
Not much. I tried a smaller RPM spread with heavier gearing and didn't like it all that much. I ended up dropping about 3 teeth on my pinion from where I started on Friday afternoon. Of course, my Speed Passion stuff should be here sometime in the next week or so, and this setup will be null and void for me.
I think the trickiest part for me will be finding which types of motors like which power band.
Danny Buck
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
