Old 01-02-2010, 02:28 PM   #9676
Skiddins's Avatar
Originally Posted by mikky32 View Post
I drove today with the V203 IN MY tc with a 10,5 LRP X11 on 2 cell lipo.
I started gearing heavier but after testing a very light setup it was incredible.
I started at 8,2FDR, than 9,17FDR and also tested 10,4FDR.
Even with the 10,4FDR the car hath an incredible top speed.
I now need some power at the start.
Here is my current setup.
Boost 37
Turbo max
Throttle 5
Brake 85%
Turbo delay 0,2
Turbo ramping 3
RPM 7500 - 4990.
9,2FDR
Now do I want some extra power in the infield but I don't now what to do.
My motor temp stays under the 180F
Must I higher my top RPM and lower RPM?
Will this give me more power in the infield?
The top speed is incredible. The car flies but I want some more infield speed and I don't now how to get it.
As i lower my Boost I must gear a lot heavier. I loose a lot of top speed.
I changed my car setup and that also improved a lot but accelerating is still a bit to slow.
The brakes are improved a lot.
It brakes great.
I want to race on a bigger track to see what it can do.
The top speed is fantastic.
Tomorrow the race. wanted to film a bit but was to impressed with the V203.
My club member improved with the same setup today with 0,4sec a lap.
His first word after hitting the straight was WOOOOOWWW!!!!!
I must confess I haven't used the software yet, but I would start by dropping the low end RPM first.
What size track was this at?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-02-2010, 02:29 PM   #9677
Skiddins's Avatar
While we're here, how about someone's estimates for a 10.5 setup (Hacker, Tekin and LRP X12 motors) on the following track;
+ YouTube Video
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-02-2010, 02:32 PM   #9678
Skiddins
here is the track
http://www.youtube.com/watch?v=5k_a0cjLngU
I tried that but it field a bit slower so I made it a bit higher it a bit.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-02-2010, 02:37 PM   #9679
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
throttle 4
motor timing 5
timing boost 50
turbo 10 delay 3
start 2721 end rpm 10000 ramp 3
fdr 5.56 32 104 t2 007
this was for the main.i had limited time with it but with a few more runs and gearing it could be beter
this is the track and we ran it clockwise this time.the race is b main 13.5
+ YouTube Video
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 02:40 PM   #9680
20 SMOKE's Avatar
Hey Skid,try randy's 13.5 with a little lower timing boost,it should be a good starting point.play with the start and end rpm you will see the difference
Jamie W
Old 01-02-2010, 02:58 PM   #9681
Originally Posted by 20 SMOKE View Post
throttle 4
motor timing 5
timing boost 50
turbo 10 delay 3
+ YouTube Video
Are you the pole man?
why did he or you stop? have here no audio. lol
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-02-2010, 03:06 PM   #9682
20 SMOKE's Avatar
that was from 12/19,it is just to show the track.i was in the A
Jamie W
Old 01-02-2010, 03:13 PM   #9683
Ok.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-02-2010, 03:34 PM   #9684
Originally Posted by gortan View Post
hi...
i tried v203 today and was impressed with the difference...
i run an xray t2 009 TC with 2S... 10.5 redline and rs pro.
my v200 setup was:
12 boost
max turbo
0.7 delay
with temperature around 60^C
my v203 setup is
40 boost (4000-12000rpm ramp)
max turbo
0.5 delay
with temperature around 55^C
overall the car is faster...pulls harder and tops out higher...
the track is biggish.. 55Metres straight...
fdr is 5.29 on rubber asphalt.
would you change anything?
g
Originally Posted by Toolmannz2 View Post
Hi Gortan
so what motor timing were you using with this?
I'm using a redline 10.5T. I have not changed the motor timing out of the box.. so it must be 12.
With the current setup the temperature is only 55... so i guess it can handle a bit more abuse... Would it help to keep everything the same.. but increase the boost to 45 or 50?
g
gortan is offline   Reply With Quote
Old 01-02-2010, 04:08 PM   #9685
Originally Posted by TeamTekin View Post
In the plans to let you read some rpm data from the esc and see it in the hotwire.
would this be race legal in races that use efra rules?
regards
MartinBasse is offline   Reply With Quote
Old 01-02-2010, 04:08 PM   #9686
Originally Posted by Senna Racing View Post
I don't have a problem with that
I have been emailed the link and downloaded the zip file
But when I run it I just get what seems to be the older version
I'm running xp, is there a hidden file that I need to remove
like with vista?
I ran the setup.bat file instead of the setup.exe file. That removes the old stuff and puts in the new version.
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-02-2010, 04:14 PM   #9687
Skiddins's Avatar
Has anyone found that dragbrake causes much extra heat in the motor when using the RS Pro.
I stopped using it on my old SPX as it seemed to cause lots of problems with motors.
I might try it tomorrow at the track but would like to know if I'm going to be adding more heat if I use it.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-02-2010, 04:19 PM   #9688
Does the Novak booster cuts out in 17.5, 1s 12th scale also?
RoyU is offline   Reply With Quote
Old 01-02-2010, 04:20 PM   #9689
20 SMOKE's Avatar
it does add some heat,but nothing that most have complained except in 1/8
Jamie W
Old 01-02-2010, 04:38 PM   #9690
Danny-b23's Avatar
Well, after 2 days of testing, I settled on:
35 Drag Brake
75 Brake Strength
Throttle Profile 3
50 Boost
10 Turbo
0.1 Delay
3 Ramp
Start: ~5000
End: ~18000
5.88 FDR
Broke our track record again by about 3 tenths, and the car was super consistent.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
